Innlegg.no - Siste ordet 1
fargoth
Denne forsvant veldig fort, så jeg reposter
Jeg har tenkt til å kjøpe nye ram-brikker (2x2gb) til pc'en. Er det sånn at jeg kan kjøpe hva jeg vil, eller må jeg kjøpe en bestemt type?Hvordan finner jeg evt ut hva jeg skal kjøpe?DxDiag her:Skjult tekst: (Marker innholdet i feltet for å se teksten):
------------------System Information------------------Time of this report: 1/24/2009, 13:49:38 Machine name: 29ER Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158) Language: English (Regional Setting: Norwegian (Bokmål))System Manufacturer: System manufacturer System Model: System Product Name BIOS: BIOS Date: 10/02/06 12:55:57 Ver: 08.00.12 Processor: Intel® Core™2 CPU 6600 @ 2.40GHz (2 CPUs) Memory: 2032MB RAM Page File: 432MB used, 3490MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0c (4.09.0000.0904)DX Setup Parameters: Not found DxDiag Version: 5.03.2600.2180 32bit Unicode------------DxDiag Notes------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. Sound Tab 1: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found.--------------------DirectX Debug Levels--------------------Direct3D: 0/4 (n/a)DirectDraw: 0/4 (retail)DirectInput: 0/5 (n/a)DirectMusic: 0/5 (n/a)DirectPlay: 0/9 (retail)DirectSound: 0/5 (retail)DirectShow: 0/6 (retail)---------------Display Devices--------------- Card name: NVIDIA GeForce 9800 GT Manufacturer: NVIDIA Chip type: GeForce 9800 GT DAC type: Integrated RAMDAC Device Key: Enum\PCI\VEN_10DE&DEV_0605&SUBSYS_C9803842&REV_A2 Display Memory: 512.0 MB Current Mode: 1920 x 1200 (32 bit) (60Hz) Monitor: Plug and Play Monitor Monitor Max Res: 1600,1200 Driver Name: nv4_disp.dll Driver Version: 6.14.0011.8120 (English) DDI Version: 9 (or higher)Driver Attributes: Final Retail Driver Date/Size: 12/26/2008 00:08:00, 6168960 bytes WHQL Logo'd: Yes WHQL Date Stamp: n/a VDD: n/a Mini VDD: nv4_mini.sys Mini VDD Date: 12/26/2008 00:08:00, 6301344 bytesDevice Identifier: {D7B71E3E-4545-11CF-4A44-8BE903C2CB35} Vendor ID: 0x10DE Device ID: 0x0605 SubSys ID: 0xC9803842 Revision ID: 0x00A2 Revision ID: 0x00A2 Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: EnabledDDraw Test Result: Not run D3D7 Test Result: Not run D3D8 Test Result: Not run D3D9 Test Result: Not run-------------Sound Devices------------- Description: SoundMAX HD Audio Default Sound Playback: Yes Default Voice Playback: No Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_1988&SUBSYS_104381E1&REV_1004 Manufacturer ID: Product ID: Type: WDM Driver Name: ADIHdAud.sys Driver Version: 5.10.0001.6240 (English) Driver Attributes: Final Retail WHQL Logo'd: Yes Date and Size: 5/18/2007 10:01:50, 304640 bytes Other Files: Driver Provider: AnalogDevices HW Accel Level: Full Cap Flags: 0xF5F Min/Max Sample Rate: 100, 192000Static/Strm HW Mix Bufs: 33, 32 Static/Strm HW 3D Bufs: 33, 32 HW Memory: 0 Voice Management: Yes EAX™ 2.0 Listen/Src: Yes, Yes I3DL2™ Listen/Src: Yes, YesSensaura™ ZoomFX™: Yes Registry: OK Sound Test Result: Not run---------------------Sound Capture Devices--------------------- Description: SoundMAX HD Audio Default Sound Capture: No Default Voice Capture: No Driver Name: ADIHdAud.sys Driver Version: 5.10.0001.6240 (English) Driver Attributes: Final Retail Date and Size: 5/18/2007 10:01:50, 304640 bytes Cap Flags: 0x41 Format Flags: 0xCCC-----------DirectMusic----------- DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS DLS Version: 1.00.0016.0002 Acceleration: n/a Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port Registry: OK Test Result: Not run-------------------DirectInput Devices------------------- Device Name: Mouse Attached: 1 Controller ID: n/aVendor/Product ID: n/a FF Driver: n/a Device Name: Keyboard Attached: 1 Controller ID: n/aVendor/Product ID: n/a FF Driver: n/a Device Name: EP2 Int Attached: 1 Controller ID: 0x0Vendor/Product ID: 0x1038, 0x0100 FF Driver: n/aPoll w/ Interrupt: No Registry: OK-----------USB Devices-----------+ USB Root Hub| Vendor/Product ID: 0x8086, 0x2830| Matching Device ID: usb\root_hub| Service: usbhub| Driver: usbhub.sys, 8/3/2004 22:08:44, 57600 bytes| Driver: usbd.sys, 8/23/2001 13:00:00, 4736 bytes----------------Gameport Devices----------------------------PS/2 Devices------------+ HID Keyboard Device| Vendor/Product ID: 0x1038, 0x0100| Matching Device ID: hid_device_system_keyboard| Service: kbdhid| Driver: kbdhid.sys, 8/3/2004 21:58:36, 14848 bytes| Driver: kbdclass.sys, 8/3/2004 21:58:34, 24576 bytes| + Terminal Server Keyboard Driver| Matching Device ID: root\rdp_kbd| Upper Filters: kbdclass| Service: TermDD| Driver: termdd.sys, 8/4/2004 00:01:08, 40840 bytes| Driver: kbdclass.sys, 8/3/2004 21:58:34, 24576 bytes| + HID-compliant mouse| Vendor/Product ID: 0x0461, 0x4D16| Matching Device ID: hid_device_system_mouse| Service: mouhid| Driver: mouclass.sys, 8/4/2004 00:05:44, 23040 bytes| Driver: mouhid.sys, 8/23/2001 13:00:00, 12160 bytes| + Terminal Server Mouse Driver| Matching Device ID: root\rdp_mou| Upper Filters: mouclass| Service: TermDD| Driver: termdd.sys, 8/4/2004 00:01:08, 40840 bytes| Driver: mouclass.sys, 8/4/2004 00:05:44, 23040 bytes----------------------------DirectPlay Service Providers----------------------------DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not runDirectPlay Test Result: Not runRegistry: OK-------------------DirectPlay Adapters-------------------DirectPlay8 Serial Service Provider: COM1DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 - -----------------------DirectPlay Voice Codecs-----------------------Voxware VR12 1.4kbit/sVoxware SC06 6.4kbit/sVoxware SC03 3.2kbit/sMS-PCM 64 kbit/sMS-ADPCM 32.8 kbit/sMicrosoft GSM 6.10 13 kbit/sTrueSpeech™ 8.6 kbit/s-------------------------DirectPlay Lobbyable Apps-------------------------------------------------Disk & DVD/CD-ROM Drives------------------------ Drive: C: Free Space: 35.3 GBTotal Space: 70.0 GBFile System: NTFS Model: SAMSUNG HD403LJ Drive: D: Free Space: 9.2 GBTotal Space: 50.0 GBFile System: NTFS Model: SAMSUNG HD403LJ Drive: E: Free Space: 44.2 GBTotal Space: 60.0 GBFile System: NTFS Model: SAMSUNG HD403LJ Drive: F: Free Space: 108.9 GBTotal Space: 201.6 GBFile System: NTFS Model: SAMSUNG HD403LJ Drive: Y: Model: TSSTcorp CD/DVDW SH-S182D Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Norwegian (Bokmål)), 8/3/2004 21:59:54, 49536 bytes--------------System Devices-------------- Name: Intel® Management Engine InterfaceDevice ID: PCI\VEN_8086&DEV_29A4&SUBSYS_820B1043&REV_02\3&11583659&0&18 Driver: C:\WINDOWS\system32\DRIVERS\HECI.sys, 2.00.0015.1110 (English), 6/19/2006 07:18:56, 43264 bytes Name: Intel® P965/G965 PCI Express Root Port - 29A1Device ID: PCI\VEN_8086&DEV_29A1&SUBSYS_00000000&REV_02\3&11583659&0&08 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:48, 68224 bytes Name: Intel® P965/G965 Processor to I/O Controller - 29A0Device ID: PCI\VEN_8086&DEV_29A0&SUBSYS_00000000&REV_02\3&11583659&0&00 Driver: n/a Name: Microsoft UAA Bus Driver for High Definition AudioDevice ID: PCI\VEN_8086&DEV_284B&SUBSYS_821A1043&REV_02\3&11583659&0&D8 Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5012 (English), 10/27/2004 14:21:36, 138240 bytes Name: Intel® ICH8 Family PCI Express Root Port 5 - 2847Device ID: PCI\VEN_8086&DEV_2847&SUBSYS_00000000&REV_02\3&11583659&0&E4 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:48, 68224 bytes Name: Intel® ICH8 Family PCI Express Root Port 1 - 283FDevice ID: PCI\VEN_8086&DEV_283F&SUBSYS_00000000&REV_02\3&11583659&0&E0 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:48, 68224 bytes Name: Intel® ICH8 Family SMBus Controller - 283EDevice ID: PCI\VEN_8086&DEV_283E&SUBSYS_821A1043&REV_02\3&11583659&0&FB Driver: n/a Name: Intel® ICH8 Family USB2 Enhanced Host Controller - 283ADevice ID: PCI\VEN_8086&DEV_283A&SUBSYS_81EC1043&REV_02\3&11583659&0&D7 Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 26624 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 142976 bytes Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:05:44, 74240 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytes Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/3/2004 23:56:44, 7168 bytes Name: Intel® ICH8 Family USB2 Enhanced Host Controller - 2836Device ID: PCI\VEN_8086&DEV_2836&SUBSYS_81EC1043&REV_02\3&11583659&0&EF Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 26624 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 142976 bytes Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:05:44, 74240 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytes Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/3/2004 23:56:44, 7168 bytes Name: Intel® ICH8 Family USB Universal Host Controller - 2835Device ID: PCI\VEN_8086&DEV_2835&SUBSYS_81EC1043&REV_02\3&11583659&0&D1 Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 20480 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 142976 bytes Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:05:44, 74240 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytes Name: Intel® ICH8 Family USB Universal Host Controller - 2834Device ID: PCI\VEN_8086&DEV_2834&SUBSYS_81EC1043&REV_02\3&11583659&0&D0 Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 20480 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 142976 bytes Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:05:44, 74240 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytes Name: Intel® ICH8 Family USB Universal Host Controller - 2832Device ID: PCI\VEN_8086&DEV_2832&SUBSYS_81EC1043&REV_02\3&11583659&0&EA Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 20480 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 142976 bytes Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:05:44, 74240 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytes Name: Intel® ICH8 Family USB Universal Host Controller - 2831Device ID: PCI\VEN_8086&DEV_2831&SUBSYS_81EC1043&REV_02\3&11583659&0&E9 Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 20480 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 142976 bytes Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:05:44, 74240 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytes Name: Intel® ICH8 Family USB Universal Host Controller - 2830Device ID: PCI\VEN_8086&DEV_2830&SUBSYS_81EC1043&REV_02\3&11583659&0&E8 Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 20480 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 142976 bytes Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:05:44, 74240 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytes Name: Intel® ICH8 2 port Serial ATA Storage Controller - 2825Device ID: PCI\VEN_8086&DEV_2825&SUBSYS_821A1043&REV_02\3&11583659&0&FD Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 3328 bytes Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (Norwegian (Bokmål)), 8/3/2004 21:59:42, 25088 bytes Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:44, 95360 bytes Name: Intel® ICH8 4 port Serial ATA Storage Controller - 2820Device ID: PCI\VEN_8086&DEV_2820&SUBSYS_821A1043&REV_02\3&11583659&0&FA Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 3328 bytes Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (Norwegian (Bokmål)), 8/3/2004 21:59:42, 25088 bytes Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:44, 95360 bytes Name: Intel® ICH8/ICH8R Family LPC Interface Controller - 2810Device ID: PCI\VEN_8086&DEV_2810&SUBSYS_00000000&REV_02\3&11583659&0&F8 Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 35840 bytes Name: Intel® 82801 PCI Bridge - 244EDevice ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_F2\3&11583659&0&F0 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:48, 68224 bytes Name: Standard Dual Channel PCI IDE ControllerDevice ID: PCI\VEN_197B&DEV_2363&SUBSYS_81E41043&REV_02\4&18CD42CE&0&00E4 Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (Norwegian (Bokmål)), 8/3/2004 21:59:42, 25088 bytes Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:44, 95360 bytes Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 3328 bytes Name: Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet ControllerDevice ID: PCI\VEN_11AB&DEV_4320&SUBSYS_811A1043&REV_14\4&1FAF5EA3&0&20F0 Driver: n/a Name: VIA OHCI Compliant IEEE 1394 Host ControllerDevice ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\4&1FAF5EA3&0&18F0 Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/3/2004 22:10:10, 61056 bytes Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/3/2004 22:10:08, 53248 bytes Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 00:05:44, 61824 bytes Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 00:05:44, 60800 bytes Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 14:46:40, 6400 bytes Name: NVIDIA GeForce 9800 GT Device ID: PCI\VEN_10DE&DEV_0605&SUBSYS_C9803842&REV_A2\4&2B9C2F50&0&0008 Driver: n/a------------------DirectX Components------------------ ddraw.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 266240 bytes ddrawex.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 27136 bytes dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 10496 bytes d3d8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 1179648 bytes d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 8192 bytes d3d9.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 1689088 bytes d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 436224 bytesd3dim700.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 825344 bytes d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 590336 bytes d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 350208 bytes d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 47616 bytesd3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 34816 bytes dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 33040 bytes dplayx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 229888 bytesdpmodemx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 23552 bytes dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 42768 bytesdpwsockx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 57344 bytesdplaysvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:50 30208 bytes dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:50 18432 bytes dpnet.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 375296 bytesdpnlobby.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:04 3584 bytes dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:04 3584 bytes dpvoice.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 212480 bytesdpvsetup.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:50 83456 bytes dpvvox.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 116736 bytes dpvacm.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 21504 bytesdpnhpast.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 35328 bytesdpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 60928 bytesdpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 53520 bytes dinput.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 159232 bytes dinput8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 181760 bytes dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 44032 bytesdiactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 394240 bytes joy.cpl: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 68608 bytes gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 76800 bytes pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:05:44 35328 bytes dsound.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 367616 bytesdsound3d.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 1294336 bytes dswave.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 19456 bytes dsdmo.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 181760 bytesdsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 71680 bytes dmusic.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 104448 bytes dmband.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 28672 bytesdmcompos.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 61440 bytes dmime.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 181248 bytesdmloader.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 35840 bytes dmstyle.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 105984 bytes dmsynth.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 103424 bytesdmscript.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 82432 bytesMicrosoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 11/22/2008 01:07:21 473600 bytesMicrosoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 11/22/2008 01:07:17 2676224 bytesMicrosoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 11/22/2008 01:07:17 2846720 bytesMicrosoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 11/22/2008 01:07:18 563712 bytesMicrosoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 11/22/2008 01:07:18 567296 bytesMicrosoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 11/22/2008 01:07:18 576000 bytesMicrosoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 11/22/2008 01:07:19 577024 bytesMicrosoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 11/22/2008 01:07:19 577536 bytesMicrosoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 11/22/2008 01:07:19 577536 bytesMicrosoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 11/22/2008 01:07:20 578560 bytesMicrosoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 11/22/2008 01:07:21 578560 bytesMicrosoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 11/22/2008 01:07:21 145920 bytesMicrosoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 11/22/2008 01:07:21 159232 bytesMicrosoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 11/22/2008 01:07:22 364544 bytesMicrosoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 11/22/2008 01:07:22 178176 bytesMicrosoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 11/22/2008 01:07:20 53248 bytesMicrosoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 11/22/2008 01:07:21 12800 bytesMicrosoft.DirectX.dll: 5.04.0000.2904 English Final Retail 11/22/2008 01:07:20 223232 bytes dx7vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 619008 bytes dx8vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 1227264 bytes dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 2113536 bytes mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 13:00:00 924432 bytes mfc42.dll: 6.02.4131.0000 English Final Retail 8/3/2004 23:56:44 1028096 bytes wsock32.dll: 5.01.2600.2180 English Final Retail 8/3/2004 23:56:48 22528 bytesamstream.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:42 70656 bytes devenum.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 59904 bytes dxmasf.dll: 6.04.0009.1125 English Final Retail 8/3/2004 23:56:44 498205 bytesmciqtz32.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 35328 bytes mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:58 148992 bytes msdmo.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 14336 bytes encapi.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 20480 bytes qasf.dll: 9.00.0000.3250 English Final Retail 8/3/2004 23:56:46 237568 bytes qcap.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 192512 bytes qdv.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 279040 bytes qdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 385024 bytes qedit.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 562176 bytesqedwipes.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:26 733696 bytes quartz.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 1287680 bytes strmdll.dll: 4.01.0000.3928 English Final Retail 8/3/2004 23:56:46 246302 bytes iac25_32.ax: 2.00.0005.0053 English Final Retail 8/3/2004 23:56:58 199680 bytes ir41_32.ax: 4.51.0016.0003 English Final Retail 8/3/2004 23:56:58 848384 bytes ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/3/2004 23:56:44 120320 bytesir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/3/2004 23:56:44 338432 bytes ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/3/2004 23:56:44 755200 bytes ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/3/2004 23:56:44 200192 bytesir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/3/2004 23:56:44 183808 bytes ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/3/2004 23:56:58 154624 bytesmswebdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 204288 bytes ks.sys: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/4/2004 00:05:44 140928 bytes ksproxy.ax: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/3/2004 23:56:58 130048 bytes ksuser.dll: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/3/2004 23:56:44 4096 bytes stream.sys: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/4/2004 00:05:44 48640 bytesmspclock.sys: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/4/2004 00:05:44 5376 bytes mspqm.sys: 5.01.2600.2180 Norwegian (Bokmål) Final Retail 8/4/2004 00:05:44 4992 bytes mskssrv.sys: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/4/2004 00:05:44 7552 bytes swenum.sys: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/4/2004 00:05:44 4352 bytes mstee.sys: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/3/2004 21:58:40 5504 bytes ipsink.ax: 5.03.2600.2180 Norwegian (Bokmål) Final Retail 8/4/2004 00:05:44 16384 bytesmpeg2data.ax: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:58 118272 bytes ndisip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:05:44 10880 bytesstreamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:14 15360 bytesmsvidctl.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 1428480 bytes slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:18 11136 bytesnabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:30 85376 bytesccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:18 17024 bytes vbisurf.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 30720 bytes msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:05:44 17408 bytes kstvtune.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 61952 bytes ksxbar.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 43008 bytes kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 90624 bytesvfwwdm32.dll: 5.01.2600.2180 English Final Retail 8/3/2004 23:56:48 53760 byteswstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:22 19328 byteswstdecod.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:48 50688 bytes------------------DirectShow Filters------------------WDM Streaming VBI Codecs:NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180CC Decoder,0x00200000,2,1,,5.03.2600.2180WST Codec,0x00200000,1,1,,5.03.2600.2180DirectShow Filters:WMAudio Decoder DMO,0x00800800,1,1,,WMSpeech Decoder DMO,0x00600800,1,1,,Mpeg4s Decoder DMO,0x00800001,1,1,,WMV Screen decoder DMO,0x00800001,1,1,,WMVideo Decoder DMO,0x00800001,1,1,,WMV9 Advanced Profile Decoder,0x00600800,1,1,,Mpeg43 Decoder DMO,0x00800001,1,1,,Mpeg4 Decoder DMO,0x00800001,1,1,,Annodex Mux Filter,0x00200000,1,0,dsfAnxMux.dll,CMML Decode Filter,0x00800002,1,1,dsfCMMLDecoder.dll,CMML Raw Source Filter,0x00600000,0,0,dsfCMMLRawSource.dll,FLAC Decode Filter,0x00600000,1,1,dsfFLACDecoder.dll,FLAC Encode Filter,0x00200000,1,1,dsfFLACEncoder.dll,Native FLAC Source Filter,0x00600000,0,0,dsfNativeFLACSource.dll,Ogg Demux Packet Source Filter,0x00600000,0,0,dsfOggDemux2.dll,Ogg Mux Filter,0x00200000,1,0,dsfOggMux.dll,OGM Decode Filter,0x00600000,1,1,dsfOGMDecoder.dll,Speex Decode Filter,0x00600000,1,1,dsfSpeexDecoder.dll,Speex Encode Filter,0x00200000,1,1,dsfSpeexEncoder.dll,Subtitle VMR9 Filter,0x00800002,1,1,dsfSubtitleVMR9.dll,Theora Decode Filter,0x00600000,1,1,dsfTheoraDecoder.dll,Theora Encode Filter,0x00200000,1,1,dsfTheoraEncoder.dll,Vorbis Decode Filter,0x00600000,1,1,dsfVorbisDecoder.dll,Vorbis Encode Filter,0x00200000,1,1,dsfVorbisEncoder.dll,WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000ffdshow MPEG-4 Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0002.1997Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0002.1997RealPlayer Video Filter,0x00200000,1,1,rdsf3260.dll,6.00.0013.0045ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0002.1997DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250Audio Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055Cucusoft DataExtractor 3,0x00200000,1,0,DataExt.dll,1.00.0000.0005Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001Benison Audio Render,0x00200000,1,0,ds_filter.ax,AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180Benison Video Render,0x00200000,1,0,ds_filter.ax,WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180MP4 Source,0x00600000,0,0,MP4Splitter.ax,1.00.0000.0002ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000Pmp Splitter,0x00600001,1,0,PmpSplitter.ax,1.00.0001.0001FLV Splitter,0x00600000,1,1,FLVSplitter.ax,1.00.0000.0001Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2180Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000Haali Media Splitter,0x00800001,0,1,splitter.ax,1.07.0359.0022Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.07.0359.0022WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000Disk Record Queue,0x00200000,1,1,wmedque.dll,9.00.0000.2980VGM - Video Decoder,0x00600000,1,1,vgmv2k2dx.ax,1.00.0011.0014MP4 Splitter,0x00600000,1,1,MP4Splitter.ax,1.00.0000.0002Color Converter,0x00200000,1,1,declrds.ax,9.00.0000.2980Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.3250ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250Xvid MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180CoreAAC Audio Decoder,0x00800000,1,1,cau.ax,1.01.0000.0642Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180Ogg Source,0x00600001,0,0,OggSplitter.ax,1.00.0000.0000Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180Haali Video Renderer,0x00200000,1,0,dxr.dll,RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0001.0001WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487VAMPD Filter,0x0050000f,1,1,vampd.ax,2.00.0000.0000File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.07.0359.0022WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000DirectVobSub,0x00200000,2,1,VSFilter.dll,1.00.0001.0003RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001DirectVobSub (auto-loading version),0x00800002,2,1,VSFilter.dll,1.00.0001.0003ffdshow VFW decoder helper,0x00200000,2,1,ffdshow.ax,1.00.0000.0001DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180PG Filter,0x00200000,1,1,pgf.ax,Ogg Splitter,0x00600001,1,1,OggSplitter.ax,1.00.0000.0000Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.07.0359.0022AC3Filter,0x40000000,1,1,ac3filter.ax,0.06.0008.0000AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180VGM - Splitter,0x00600000,1,1,VgmSplt.ax,1.00.0011.0019DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180RealPlayer Transcode Filter,0x00600000,0,0,rdsf3260.dll,6.00.0013.0045Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0002.1997Screen Capture filter,0x00200000,0,1,wmesrcwp.dll,9.00.0000.2980PVG Filter,0x00200000,1,1,pvgf.ax,ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.32509x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000FLV Source,0x00600000,0,0,FLVSplitter.ax,1.00.0000.0001StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0013.0045AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180MPEG4 Video Splitter,0x00600000,1,1,MP4Splitter.ax,1.00.0000.0002VGM - BGR Converter,0x00400000,1,1,vgmbgr.ax,1.00.0003.0004QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250Video Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980Pmp Source,0x00600001,0,0,PmpSplitter.ax,1.00.0001.0001RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0001AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180MPEG4 Video Source,0x00600000,0,0,MP4Splitter.ax,1.00.0000.0002CyberLink QuickTime Source Filter,0x00200000,0,2,Quicktime.dll,1.00.0000.1016Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000Haali Video Sink,0x00200000,1,0,splitter.ax,1.07.0359.0022Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180VGM - Audio Decoder,0x00600000,1,1,VgmAudioDecX.ax,1.00.0006.0009Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003WDM Streaming Tee/Splitter Devices:Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.2180WDM Streaming Data Transforms:Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180Video Compressors:MSScreen encoder DMO,0x00600800,1,1,,WMVideo9 Encoder DMO,0x00600800,1,1,,MSScreen 9 encoder DMO,0x00600800,1,1,,DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0002.1997Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2180Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180Intel Indeo® Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180Audio Compressors:WM Speech Encoder DMO,0x00600800,1,1,,WMAudio Encoder DMO,0x00600800,1,1,,IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.2180Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.2180Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.2180Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.2180IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180PCM,0x00200000,1,1,quartz.dll,6.05.2600.2180Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180DSP Group TrueSpeech™,0x00200000,1,1,quartz.dll,6.05.2600.2180Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2180Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180Midi Renderers:Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180WDM Streaming Capture Devices:SoundMAX HD Audio,0x00000000,0,0,,WDM Streaming Rendering Devices:SoundMAX HD Audio,0x00000000,0,0,,BDA Rendering Filters:BDA IP Sink,0x00200000,1,1,,5.03.2600.2180WDM Streaming Mixer Devices:Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,BDA CP/CA Filters:Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180WDM Streaming Communication Transforms:Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.2180Audio Renderers:Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180DirectSound: SoundMAX HD Audio,0x00200000,1,0,quartz.dll,6.05.2600.2180WDM Streaming System Devices:SoundMAX HD Audio,0x00200000,19,3,,5.03.2600.2180BDA Receiver Components:BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.2180
Hvis du kan sende en link til hovedkortet ditt så får vi vite hva du kan bruke :)
Skal jeg ta ansvaret for Forumtreff '10-tråden?
Awesome.
Jeg skrev reglene. Jeg kjenner dem.
Dette er ikke en tråd for å gjøre andre oppmerksom på dine tråder hvor du ber om hjelp eller svar. Dette er en chattetråd. Skulle det derimot være usedvanlig relevant til det som diskuteres der og da(her og nå mtp. sisteside) kan du selv vurdere om det er noe som burde bli bragt til de andre SO brukerenes oppmerksomhet!
DxDiag her:
System Information
Machine name: 29ER
Processor: Intel® Core2 CPU 6600 @ 2.40GHz (2 CPUs)
Memory: 2032MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x0605
Revision ID: 0x00A2
Revision ID: 0x00A2
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID:
Product ID:
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
EAX 2.0 Listen/Src: Yes, Yes
I3DL2 Listen/Src: Yes, Yes
Sensaura ZoomFX: Yes
Registry: OK
Cap Flags: 0x41
Format Flags: 0xCCC
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
PS/2 Devices
| Service: kbdhid
| Service: TermDD
| Service: mouhid
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
TrueSpeech 8.6 kbit/s
Drive: C:
Free Space: 35.3 GB
File System: NTFS
Drive: D:
Free Space: 9.2 GB
File System: NTFS
Drive: E:
Free Space: 44.2 GB
File System: NTFS
Drive: F:
File System: NTFS
Drive: Y:
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
DSP Group TrueSpeech,0x00200000,1,1,quartz.dll,6.05.2600.2180
Midi Renderers:
BDA CP/CA Filters:
Audio Renderers:
RAM er tricky business! Du må ha en helt spesiell type.
Meh, trodde ikke det å ha allergi var så ille som dette.. Vondt i ørene, rennende nese, helt sår i ganen etter at jeg har nyst sikkert 16-17 ganger etter hverandre pluss tørre og kløende øyne.
Blir værst når jeg er inne på rommet mitt hvor jeg har åpent vindu 24/7, så kanskje jeg har fått pollenallergi. Får krysse fingrene for at det ikke er greia.
