Gormers Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 guuuud jeg hører på *input genre here plx* og lager bilder jeg nesten ikke forstår meg på selv oO http://open.spotify.com/track/6l7XkDCbTjkL2K5jJlutVn Er sangen ødelagt eller noe..? http://misteroo.deviantart.com/art/Super-P...-Peach-40193933 Lenke til kommentar
Gal_ape Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 (endret) guuuud jeg hører på *input genre here plx* og lager bilder jeg nesten ikke forstår meg på selv oO http://open.spotify.com/track/6l7XkDCbTjkL2K5jJlutVn Er sangen ødelagt eller noe..? Tror ikke det. Etter å ha lest litt rundt tror jeg denne sjangeren kalles Drone. Evt. er det noisecore etter mitt syn.. Sakset fra Last.fm profilen: "His solo and collaborative work ranges from challenging improvisations, ambient textures, and blistering walls of sound. " Endret 7. august 2009 av Gal_ape Lenke til kommentar
- FuzioN Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 Navnet ble HCG. Lenke til kommentar
AltF4 Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 (endret) From outside, Kevin Drumm's pummeling noise pieces are tempestuous instigators, violent sonic windstorms whose manifest destiny is to upturn, agitate, and provoke. From inside -- the route to which is best accessed by listening passively and resisting the urge to tussle with the music -- Drumm's dense swathes of static seem to mutate and fracture with an incredible nuance. If Sheer Hellish Miasma is equivalent to Drumm's dentist's chair, then these subtle textural changes are his mild anesthetic, providing just enough distraction to keep the focus off the mounting tension. It's a disarming trick, the effects of which are fully revealed when the album's 48 minutes of unrelenting caterwaul yield to its fourth and final cut, a gorgeous drone piece named "Cloudy," which seems triply sublime after so much sneakily accumulated momentum and aggression. Rare is the deliverance more satisfying than this; rarer still is the record more adequately named. ~ Mark Pytlik, All Music Guide Dete er et så interessant syn på musikken at jeg skulle ønske jeg gadd høre på hele greia noen ganger for å se om jeg kunne kanskje lære noe nytt. Bare Egil Band it is. At dette er spilt inn på gitar er enda mer imponerende. Endret 7. august 2009 av AltF4 Lenke til kommentar
Error Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 (endret) Cheers! Edit: Se på top 5 listen, og så ser du på det albumet som er øverst. Noen likheter? Endret 7. august 2009 av Error Lenke til kommentar
psyched Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 God natt evry one Lenke til kommentar
Gal_ape Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 Dete er et så interessant syn på musikken at jeg skulle ønske jeg gadd høre på hele greia noen ganger for å se om jeg kunne kanskje lære noe nytt. Tror det kreves en del egen vilje for å kunne gjøre det, egentlig. Nå var det litt spesielt i kveld for min egen del mht. "åndelig" tilstedeværelse og humør. Lenke til kommentar
- FuzioN Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 Ny PC-hobby; Special Forces. Lenke til kommentar
Gal_ape Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 (endret) Men igjen, for de som virkelig liker lyden av feedback anbefaler jeg å sjekke ut Prurient, som for det aller meste kun jobber med en mikrofon og en forsterker *edit* Når vi først er inne på obskure sjangre: Jeg lo. Endret 7. august 2009 av Gal_ape Lenke til kommentar
AltF4 Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 Dete er et så interessant syn på musikken at jeg skulle ønske jeg gadd høre på hele greia noen ganger for å se om jeg kunne kanskje lære noe nytt. Tror det kreves en del egen vilje for å kunne gjøre det, egentlig. Nå var det litt spesielt i kveld for min egen del mht. "åndelig" tilstedeværelse og humør. Jepp. Med tanke på alt det andre jeg liker som jeg hører for lite på så virker Kevin Drumm som en aldri så liten overkill. Den techno(?)låta du postet for en stund tilbake har jeg forsåvidt hørt mye på, jeg greier ikke helt legge den fra meg. Lenke til kommentar
Error Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 (endret) Fy faen, rett før jeg bestemmer meg for å skru av PC'en og gå og legge meg ser jeg plutselig en jævel av en edderkopp som løper i en rasende fart oppover veggen, og den må ha vært rett ved beina mine i en ukjent periode. Jeg kan bare si en ting, og det var at jeg skvatt som bare rakkern. Jeg hater de små krypene, og jeg får helt hetta når disse gigantiske velger å besøke rommet mitt fra tid til annen. Heldigvis lå det en avis på rommet mitt, så jeg brettet den sammen og med en kjapp fulltreffer var det lite liv igjen i den edderkoppen. Edit: Uansett, jeg går og legger meg nå. Pleier skjeldent å være mer enn en av de store edderkoppene som er på rommet samtidig, så inntil videre tror jeg at jeg kan sove trygt. Endret 7. august 2009 av Error Lenke til kommentar
Eplefe Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 Da har jeg nettopp varmet nye flasker og byttet bleier. Aah, the joys of children. Jeg tar kvelden nå, og satser på at iPoden min overlever til jeg sovner. 8D NIGHTYNIGHT, forumister og rævsleikere. ^_^ Lenke til kommentar
Gal_ape Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 AltF4, tenker du på denne? Syns selv at det er den absolutt beste av Italoboyz! Lenke til kommentar
AltF4 Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 (endret) Går til sengs selv, overraskende sent det skulle bli da! Natta folk og fe. Gal_ape: Jepp. særlig rundt 2:20 og fremover en stund. Endret 7. august 2009 av AltF4 Lenke til kommentar
Lakus Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 Neeeeei! Ikke Italoboys! "Litt" lei av den musikken nå Natt Eplers. (og F4) Lenke til kommentar
Gal_ape Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 Og der slenger mr crazy musikksmak og kunstneriske påvirkninger seg i køya og gitt! Snakkes i morgen tidlig folkens Lenke til kommentar
Laland Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 Good night everybody!(Peter Griffin stemme, episoden PTV) Lenke til kommentar
- FuzioN Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 Hvilken film? A: The Dark Knight B: Slumdog Millionaire C: Zack and Miri make a Porno D: Sin City Lenke til kommentar
Lakus Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 fremdeles Sin City Lenke til kommentar
Laland Skrevet 7. august 2009 Rapporter Del Skrevet 7. august 2009 The Dark Knight. Og nei, jeg sier ikke det utifra hypen til Arkham Asylum. Lenke til kommentar
