Call of Duty: Modern Warfare 2!
Ukentlig avstemning frem til realase
313 stemmer
  1. 1. Når skal du kjøpe spillet?
    • På realase
      127
    • Har forhåndsbestilt
      97
    • Blir julegave
      77
    • Vet ikke
      41
    • Ser ann anmeldelsene
      16
    • skal ikke ha det
      58
Å dele scans fra spillmagasiner er et klart brudd på åndsverkloven. Linker til og vedlegg av scans har blitt fjernet. Norges lover gjelder også på forumet. Materiale beskyttet av opphavsretten skal ikke postes på forumet.
Snorre :)
Endret av Snorre
May 14, 2009 - Details on Infinity Ward's anticipated upcoming shooter Modern Warfare 2 were made available in the most recent issue of Game Informer. The article tells how the game's campaign mode will feature Captain 'Soap' MacTavish, who returns from Call of Duty 4: Modern Warfare, as a non-playable character, and will continue on with the tale of the previous game.
The game's campaign stages, according to the article, will be more open and varied, though the overall length of the campaign will be roughly similar to the six to 10 hour duration of Modern Warfare. Gameplay mechanics will include climbing the icy slopes of a mountain with ice picks and riding on snowmobiles. There'll also be some sort of shift in the way enemies attack. No longer will seemingly endless waves spawn in until you step across an invisible line. Settings will range from a snowy mountaintop in Russia to Rio de Janiero, Brazil, which will be a more sprawling level than any present in Modern Warfare.
A new mode in the game, called Special Forces, will consist of a number of isolated stages not tied to the narrative. There was no indication of precisely how many of these Special Forces stages would make it in, but according to Game Informer it'll be a "major part" of the game. More interestingly, while the story campaign will be single-player only, the Special Forces maps will allow two players to run through co-operatively.
Details about Modern Warfare 2's multiplayer element were scarce, though Infinity Ward told Game Informer it wanted to emphasize making players famous based on their accomplishments in matches.
Herregud som jeg gleder meg til dette spillet kommer.
Fire in the sky!!
Gleder meg noe enormt, er det bare jeg som elsket singelplayeren i COD4?
Den er det noen av det beste som finnes der ute, eneste minus for meg er fiendene repspawner, men ellers klaffer alt. Husker så godt sniperoppdraget og når atombomben gikk av, det hadde jeg aldri trodd :D
Heads up on what you can expect over the course of the next week.
All this week, leading up to the Eastern Conference Finals on May 24th there are 15 second ads for the World Premiere gameplay trailer of Modern Warfare 2.
Thursday, May 21st -
GTTV on Spike TV will be showing a sneak preview of the full trailer on their show and reminding you to be on the look out on May 24th for the full trailer to hit. Their sneak peak will have some exclusive scenes from the full trailer & will remind you to check out the full version on May 24th.
Sunday, May 24th -
This is when it all goes down. If you're watching the Eastern Conference Finals you'll get the first look at Modern Warfare 2 gameplay which tells you to go to ModernWarfare2.com for the full unedited trailer.
Immediately following that, ModernWarfare2.com will be updated with the glorious full & unedited version of the first gameplay trailer for Modern Warfare 2. THIS IS THE ONE TO WATCH!
I just wanted to make sure you all we're up to speed with what to expect and what to be on the look out for this week! See you May 24th!
Litt info fra 402 om hva vi kan vente oss de neste dagene. Gleder meg mildt sagt til søndag nå.
Du spilte på vel på easy din pingle :p Jeg har enda ikke klart alle banene på veteran og har vel sånn smått gitt opp den achievementen. Gjør meg igrunn ingenting at SP delen var så kort som den var, når den leverte så utrolig mye bedre historie enn bortimot alle FPS'er der ute. Som utviklerne sa, de var ikke interessert i å forlenge SP delen bare for å gjøre det. De hadde en historie å fortelle og gjorde det.
Uansett hadde de replay value iform av achievments og den arcade versjonen med online ranking.
Tror jeg passerte 10 timer på veteran på COD 4 til 360, dem siste oppdragene var dødens!! Kjenner mangen som sliter med COD4 på hardened på pc :D, og jeg sleit nesten ikke på veteran på 360!! :D
Har gitt opp det aller siste med det du skal redde en VIP-gjest i det flyet :p
Endret av Toman85
hehe, godt mogleg ;-)
Men, det er til dags dato ikkje eit einaste spel som har gitt meg så mange timar online. Berre synd at eg sug balle for tida. Spelet har nok kvilt på hylla for lenge.
Ny video!
Gledar meg til 24. mai!
Gjest Slettet+130498
begynner virkelig å se fram til dette spillet i høst. gleder meg til å få se full gameplay trailer og går rundt med et håp om at de dropper kjøretøy fra mp. går greit med scripte scener i sp men kjøretøy har ikke noe i mp å gjøre. håper også på å få et rainbow six lignende våpen meny opplegg hvor vi velger våpen og utstyr før vi starter oppdragene, gjerne da med litt flere valg enn det var på r6. kan vi ønske oss en zombie mode også? gjerne med flere kart :rolleyes:
blir foresten exp systemet fra mp også lagt inn i sp delen? hadde vært kjekt med ranks osv i sp.
Zombie mode kan de styre unna. La Treyarch styre med det. Ikke at jeg tror det kommer uansett. Ser mye mer frem til moden de har i MW2. Special Forces mode blir bare fantastisk morsomt. En haug med korte baner lik siste banen i MW1 blir bare fantastisk. Håper som deg de ikke prøver å dytte noen kjøretøy inn i MP delen. MP delen fra nr 1 var bortimot perfekt, så skulle ikke være så mye å gjøre der annet enn å lage nye baner og pusse opp community delen. Noe ala det systemet de har klart å få til med Killzone.com hadde vært bra. Et ranking system over hvem som er den beste spilleren i verden osv. Online Achievements burde også legges til. Selve gameplayet håper jeg ikke de gjør for mye endringer på. Nye våpen, nye perks og litt balansering. Ellers håper jeg det gamle ordtaket "if it's not broken" osv er veien de går.
Endret av Konamixx
Her finner du den nye teaseren. Orgasmisk. :)
ps: Ja, jeg vet at det finnes en tag for gametrailers videoer, men det ville ikke fungere for en eller annen rar grunn.
Noen screencaps fra videoen:
Skjul
Se navnet på "varebilen". Russisk?
Se det russiske flagget på armen til soldaten
Dette ser så porno ut.
Mohawk
Rio baby :) Legg merke til mohawken
Ser at han mørke og fyren med mohawk går igjen i to bilder her. Mulige med-soldater eller motstandere?
Endret av Villanden
Nr 1 vil jo være best i verden ja. Er vel det som er poenget med å være nr 1.
K/D ratio og acc vil jo være et måleinstrument for dette. Poeng kan også være måling for dette. Men må jo være basert på last week eller noe i den duren. Slik at ikke en som har akkumulert poeng fra dag en kan bli slått av en som begynte 5 mnd etter spillet er sluppet om man er god. Er vel forferdelig mange måter å måle dette på. Håper bare IW implementerer måling for slik.
