Gears of War Kafèen
Lakus
Nå har det dukket opp scans fra en Gears 3 preview på nettet. Jeg går ut i fra at det ikke er lov å poste scans på forumet, så dere får finne dem selv. :)
Det er mulig at det er bullshots, men de gir iallefall et godt bilde av omgivelsene vi kommer til å få oppleve i Gears 3.
Gjest Bruker-127711
Hvorfor skal ikke det være lov?
Har da vært postet flere av de her før, mener jeg.
Endret av Bruker-127711
  • 2 uker senere...
Da skal jeg teste Gears 2 igjen i morgen tenker jeg. Bare for å se hvor landet ligger.
Gears of War 2 Title Update 6 Detailed Release Notes
The following fixes and improvements are included in Title Update 6.
Improvements
Title Update 6 makes these new improvements:
  • Adds a new public multiplayer match option called Social Xbox LIVE (aka player matches), open to anyone who owns all downloadable maps (that is, All Fronts Collection). We’ll be having a promotion that will dramatically reduce the cost of the All Fronts Collection.
  • You can join Social Matches in progress and can quit any time without penalty, although players who quit a match early don’t receive earned experience (XP) from that match.
  • Social matchmaking lets your party join a match in progress. If a match is not found, your party hosts a new match, filling any empty player slots with bots.
  • Social Matches automatically cycle to the next map without further matchmaking.
  • Teams are rebalanced between matches based on XP level without splitting parties.
  • If you quit, your spot is taken by a bot until a new player joins the match. That new player can join while the match is in progress.
  • If you join a match in progress, you are assigned a team based on XP level and party size.
  • If you join a match in progress, you replace a bot at the earliest opportunity: at the first bot’s death for respawning game types (for example, Annex) and at round completion for Warzone, Execution, and Wingman.
  • Social leaderboards become part of the War Journal.
  • Renames Public Matches to Ranked Xbox LIVE Matches to differentiate these from Social Xbox LIVE Matches, and adds some improvements to these matches.
  • Improved host selection using bandwidth testing and previous hosting data has been added.
  • Before the match begins, teams are balanced based on XP without splitting parties.
  • Renames Private Matches to Custom Xbox LIVE Matches and makes these matches invite-only.
  • Adds the ability to join Horde sessions that are in progress.
  • In Social Horde, you can join a session in progress through matchmaking and you are able to continue your session from the last wave you failed without starting over.
  • In Ranked Horde, you can join a session in progress only through invites.
  • If you join a session in progress, at the end of the session you receive the score you achieved during the time you spent in the session.
  • Improves the precision of weapon selection using the D-pad.
  • Improves client-side hit detection for ballistic weapons.
Exploit Fixes
Title Update 6 fixes these possible exploits, where under certain circumstances:
  • Execution rules could be ignored when using certain weapon types.
  • On the Subway map, you could get outside of the playable environment by sliding into cover and rolling between a train car and the side of tracks.
  • On the Blood Drive map, you could get outside of the playable environment in various locations.
  • Players could grief other players on Submission, Annex, King of the Hill, and Guardian games by preventing the objective from being completed while racking up experience. Title Update 6 adds match time limits to each of these game types to prevent this practice.
General Fixes
Title Update 6 fixes these other issues as well:
  • An issue that could cause your profile to be overwritten, erasing XP level, and achievement progress.
  • An issue that could cause a campaign save slot to be overwritten if you previously chose to continue without saving and then signed in.
Balancing
Title Update 6 makes these balancing changes:
  • Changes the Gnasher Shotgun pellet pattern to increase hit consistency.
  • Changes the Guardian game type to select the leader based upon XP level (highest to lowest).
  • Oh, also... firing delays after roadie run and evades are reduced.
