LittleDevil LD PC-V8 ATX/HPTX Watercoolig PC case with 10 expansion slots pic inside!
What's the delivery time on something like this?
I'm pretty sure the regular black outside, black inside with 4-Way motherboard tray and _with_ window is 3-7 days or something, seeing it's in stock. But if you have to make one _without_ a window the delivery time would probably increase. If we are talking about several weeks I might just buy the standard version with window.
Also, how would ordering the case without a window affect the price?
There is no substitute for cubic inches... :tease:
If you want good cooling with low noise you need alot of cooling area, so you need large radiator(s)
And theeses cases are made with high end systems in mind. If you want a htpc or just a web browsing (and other light uses)machine you dont need anything like this and you dont need watercooling. An AMD A3850 ish system with a passive cpu heatsink, passive power supply and SSD, cooled by just a couple of low rpm case fans is plenty and will be VERY quiet
No, theese cases are for big systems with multiple radiators.
4400 - 4600,- litt avhengig av kursen. Dette er da for kabinettet, frakt og moms.
Det er dyrt, men ikke noe blodpris. Hvis man ser hva andre store kabinetter koster (da tenker jeg på kvalitet, slik som Lian Li). Jeg bestiller vel i dag tenker jeg.
Syns det var en real pris jeg. Blir nok dette i min neste build om jeg bestemmer meg for å gå vannkjølt.
I use a pair of Watercool Mo-Ra 2 Pros. I scoff at your tiny radiators.
But seriously. Despite the size of my rads, they are compact. They won't fit inside a case, no, but they stand by themselves with a small footprint. Why someone would choose to use 4 or 5 small rads and cram them all inside a giant case... I just don't get it.
AquaComputer is now selling 840mm rads. Still small, but it's a step in the right direction. Less rads, better use of space, reduction of needless complexity, more appealing dimensions: that's where I want the future to go. A move toward elegance rather than whale-ish girth.
However I was wondering a little about what has been done to reduce sounds coming from devices such as Hd's and non water cooled Graphic cards? Does the cases have any sound dampening at all?
No, the case was made specifically for watercooling and has no sound dampening. It also lacks other things like thumb screws, dust filters, rubbered cable routing holes, etc.
To be honest the LD case is really nice, but if you're putting that amount of money down you must consider all the options, which also include mountainmods.com and caselabs.net. Neither of which have any kind of HDD sound dampening, but there are pros and cons with all 3 manufacturers.
http://www.youtube.com/watch?v=KLTu1CcQx1w
  • 1 måned senere...
