probem i Easy CD Creator
swaisi
Hei. Instalerte nettop Easy CD Creator Basic 5.0, men når jeg starter et prosjekt, kommer denne meldingen fram:
"Cannot create creator
Error returned 0x80040154"
Kan jeg værsåsnill å få hjelp til å fikse dette plagende problemet???
Takker for alle svar...
46-0-2: Error: "Cannot create creator! ...0x80040154" (020326-000000)
Question
This information applies to the following product(s):
Easy CD Creator 5.1x Platinum Suite
This information applies to the following operating system(s):
Windows XP only
Answer
When I attempt to launch an Easy CD Creator project I receive a message
"Cannot create creator! Error returned 0x80040154"
This information applies when the following is true.
Easy CD Creator installs successfully
When exploring the folder C:Program Files Common FilesAdaptec SharedCDEngine, There are no files present with a .dll extension.
You have installed Easy CD Creator 5.1
You can determine which version you have by:
1. Go to "Start" then "Programs" then "Roxio Easy CD Creator" and select
"Project Selector"
2. Move your mouse over "Make a Data CD" and then select "Data CD Project"
3. Go to "Help" and then "About"
4. The window that opens will show your current version.
ANSWER:
WARNING: THE NEXT STEP INVOLVES EDITING YOUR SYSTEM REGISTRY. WE STRONGLY RECOMMEND YOU EXPORT YOUR REGISTRY BEFORE ATTEMPTING ANY EDITING. EDITING YOUR REGISTRY INCORRECTLY CAN CAUSE IRREPARABLE SYSTEM DAMAGE.
To export a copy of your registry, please do the following.
1. Go to "Start" then "Run", type "regedit" and click "OK"
2. Locate and left click "File" in the upper left hand corner of the Registry editor
3. Click "Export" (Export range All should be selected)
4. Choose a location on your hard drive and give the file a name.
5. Click "Save"
Your registry should now be backed up in a .reg file to the location you specified. From this point, please continue starting with step 1 in your registry editor.
1. Double click the "Hkey_Local_Machine folder" this will expand or open the folder
2. Locate the software folder, "Right Click" on this folder and choose "Permissions"
3. Select "Add", type in "Administrator" and click "OK"
4. Make sure that Administrator is "highlighted" under Group or Usernames
5. Under Permissions for Administrator, please check "Allow" for Full Control
6. Select "Apply" then "OK"
7. Select "Add", type in "System" and select "OK"
8. Make sure that System is "highlighted" under Group or Usernames
9. Under permissions for System, please check "Allow" for Full Control
10. Select "apply" then "OK"
11. Please exit the registry, by choosing "File" from the top left hand corner of the window and click "Exit"
12. Insert the Roxio Installation CD in your CD drive. (If asked if you would like to install choose "No")
13. Click the Start button then right click "My Computer" and select "Explore." If you are running in Classic mode, "My computer" should be on your desktop
14. Open the Roxio install CD by Clicking on the CD drive it resides in
15. Locate and double click the folder "Engsetup"
16. Double click the file Engsetup.exe and click the "Install" Button
17. Allow the installation to complete and restart your computer
Once your computer restarts, please launch an Easy CD
Du får prøve dette. Håper du får til
