[Løst] Verdivurdering! 2 X Asus Radeon HD5770 og 1 stk HAF922 Kabinett
Trenger en verdivurdering av dette.. Alt er kjøpt i November 2009.
Skjermkort : 2 x Asus HD5770 - Crossfire
Kabinett : 1 X Coolermaster HAF 922 med ekstra vifte + Nzxt lcd viftekontroller.
(Betegnelse på grafikk kortene)
EAH5770/2DIS/1GD5
Groundbreaking DirectX 11 Gaming Experience!
- ASUS Exclusive Voltage Tweak Technology
- Breakthrough DX11 Graphics Card
- New Generation 40nm GPU & 1GB GDDR5 Memory
- Eyefinity Technology for 3-monitor output!
Graphics Engine ATI Radeon HD 5770
Bus Standard PCI Express 2.0
Video Memory DDR5 1G
Engine Clock 850 MHz
Memory Clock 4.8 GHz ( 1.2 GHz DDR5 )
RAMDAC 400MHz
Memory Interface 128-bit
CRT Max Resolution 2048 x 1536
DVI Max Resolution 2560 x 1600
D-Sub Output Yes x 1 (via DVI to D-Sub adaptor x 1 )
DVI Output Yes x 2 (DVI-I)
HDMI Output Yes x 1
DisplayPort Yes
HDCP Support Yes
Adapter/Cable Bundled 1 x DVI to D-Sub adaptor
1 x CrossFire cable
Software Bundled ASUS Utilities & Driver
Note The card size is 9 inches x 5 inches
Hva kan jeg få for dette i salg.
