MSI 648F Neo-L P4 hovedkort
Som en av de første, om ikke den første, lanserer MSI et hovedkort basert på SiS 648FX chipset. Det byr på standard funksjoner som 800 MHz FSB, DDR400 RAM og AGP8X, og har også en del ekstra snacks på lur.
PRESS RELEASE
NEW MSI 648F Neo-L mainboard:
Experience the first SiS based platform supporting Pentium 4, 800 MHz FSB and DDR400 memory
July 2003
MSI launches a new platform based on SiS 648FX chipset, the MSI 648F Neo-L, supporting 478 Intel Pentium 4 Processors with Hyper-Threading Technology up to the next generation Prescott CPU and new standards like 800 MHz FSB and DDR400 memory. To optimize the system performance new technologies like SiS® HyperStreaming and SiS® MuTIOL 1G are integrated. Moreover, you have the advantages of MSI CoreCell Chip and MSI CoreCenter software utility, including hardware monitor, system alert and instinctive UI of overclocking.  The most complete solution available today against a very competitive pricing for system manageability and stability for average users and performance enthusiasts alike!
MSI 648F Neo-L has 3 DIMM slots, supporting up to 3.0GB DDR400 SDRAM, 1 AGP8X port and a 10/100Mbps Ethernet LAN controller. MSI 648F Neo-L is also most flexible when it comes to upgrading your computer it has 6 PCI expansion slots. Optional is. MSI 648F Neo-L also is equipped with integrated 5.1 Channel audio for home entertainment.
MSI CoreCell Chip brings 4 technical features: MSI Speedster, MSI BuzzFree, MSI PowerPro and MSI LifePro. The Speedster technology of MSI CoreCell Chip contains the most flexible BIOS options for overclocking, including async mode of FSB and memory frequency, 0.05V increment for memory voltage adjustment and the minimal increment of 0.0125V for Vcore.
MSI BuzzFree technology examines current system utilization and temperature before leveraging thermal requirement & fan speed. It dramatically reduces up to 50% of system noise and the annoying buzz. Further it improves the quality of audio and video appreciation. Now you can really enjoy playing games or watching DVD movies.
MSI PowerPro technology is a power management solution that moderates power consumption up to 67%. It assures the motherboard stability and empowers O.C. capability.
MSI LifePro technology prolongs motherboard, CPU and fan life by maintaining them under best condition. It detects and manage motherboard utilization, eliminates the possible factors and keeps away from system crash.
The MSI 648F Neo-L also supports features such as:
S-Bracket (Optional)
With the integrated SPDIF socket and the support of Optical Fiber and Coaxial cables, the S-Bracket? brings you the best experience of 5.1 Channel surround sound.
D-Bracket 2 (Optional)
This device helps the user diagnose computer hardware problems from outside of the computer chassis, eliminating the trouble of having to open up the chassis every time. The D-Bracket 2 has a combination of 4 LED light signals that are either green or red, representing 16 different troubleshooting functions during boot up.  The new D-Bracket 2 also includes two USB 2.0 ports.
Live Update 2
MSI Live Update 2 includes several useful and powerful applications such as MSI Live BIOS, MSI Live Driver, MSI Live VGA BIOS, MSI Live VGA Driver and MSI Live Utility, which help you to download and update the latest version of BIOS and driver automatically.  You do not have to spend much time in searching the whole website to find the drivers you need.
Se også hovedkortets produktside.
