minne til stasjonær
Selvfølgelig må du ha riktig klokkefrekvens.
Fra Asus sine sider:
4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1600/1333/1066 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
* DDR3 Memory Ultra Low Voltage support
** Due to OS limitation, when installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
***Due to CPU spec., AMD 100 and 200 series CPUs support up to DDR3 1066MHz. With ASUS design, this motherboard can support up to DDR3 1333MHz
**** Refer to www.asus.com for the memory QVL (Qualified Vendors Lists).
Endret av Sacro
