Få et script til å fungere i battlefield 2
Jeg prøver å få en enkel hotkey til å fungere i battlefield 2 med programmet AutoHotkey, men uten hell.
Koden:
#Persistent
#InstallKeybdHook
SetKeyDelay, 75, 75
x::
    Send, z
Return
Googlet problemet, og fant noe her:
Why do Hotstrings, Send, and Click have no effect in certain games?
Some games use DirectInput exclusively. As a side-effect, they might ignore all simulated keystrokes and mouse clicks. To work around this, try one of the following (or a combination):
* Use SendPlay via: 1) the SendPlay command; 2) using SendMode Play; and/or 3) the hotstring option SP.
* Increase SetKeyDelay. For example:
SetKeyDelay, 0, 50
SetKeyDelay, 0, 50, Play
* Try ControlSend, which might work in cases where the other Send modes fail.
Er det noen som vet hva som skal til for å få scriptet til å fungere i battlefield 2?
Endret av Treasure
