Airplay iOS 4.3 Stream Pc to Iphone
Jeg må si at AirPlay (Share over the air) fungere veldig greit streaming fra pc på en Iphone med iOS 4.3 eneste er at det er selvsagt bare formatene til Apple som støttes.
PS! for at det skal fungere må du har iTunes 10.2 og akitvere Hjemmedeling deretter må du gå inn på telefonen din og under instillinger på ipod skrive inn din apple id.
Dette fungere selvsagt også med appletv & ipad 1/2 /m iOS 4.3 (+direkte 1080p til hdmi tv.)
  Sitat
Get even more play out of AirPlay — the wireless technology that lets you stream content from your iPhone' date=' iPad, or iPod touch to your HDTV via Apple TV.1 In addition to music, movies, and photos, AirPlay now streams video from your Photos app. So you can shoot a home video and instantly share it with everyone in the room. Even AirPlay-enabled apps and websites get the big-screen treatment with iOS 4.3. And if your photos are the feature presentation, you can play a slideshow with all the stunning themes available on Apple TV.[/quote']
  Sitat
* Frequency response: 20Hz to 20,000Hz
* Audio formats supported: HE-AAC (V1 and V2), AAC (8 to 320 Kbps), Protected AAC (from iTunes Store), MP3 (8 to 320 Kbps), MP3 VBR, Audible (formats 2, 3, and 4, Audible Enhanced Audio, AAX, and AAX+), Apple Lossless, AIFF, and WAV
* User-configurable maximum volume limit
* Dolby Digital 5.1 surround sound pass-through with Apple Digital AV Adapter (sold separately)
  Sitat
* Video mirroring and video out support: Up to 1080p with Apple Digital AV Adapter or Apple VGA Adapter (cables sold separately)
* Video out support at 576p and 480p with Apple Component AV Cable; 576i and 480i with Apple Composite AV Cable
* Video formats supported: H.264 video up to 720p, 30 frames per second, Main Profile level 3.1 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps per channel, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file format
  tiboine skrev (På 6.3.2011 den 20.48):
uff. vanskelig å få noe til å virke med itunes.
  iChristian skrev (På 6.3.2011 den 21.02):
Hæ?
Kan ikke si at det er vanskelig å få ting til å fungere med iTunes, er det noe spesielt du ikke får til da eller?
Airplay fungere mot apple sine nyeste utstyr som iphone 3gs,4 ipad, appletv & ipod.
Disse har mulighet til å kobles til anlegg / tv (kabel) som gjør at du kan stream musikk / video fra pc/mac.
