Spaz Skrevet 11. juli 2003 Del Skrevet 11. juli 2003 Abit har nettopp sluppet ut nye BIOS filer. Følgende er nytt: 1. Please use AWDFLASH 8.23D or later to update NF7 series BIOS. With incorrect AWDFLASH version, the GUID will be erased, and leads to IEEE1394 peer to peer function failed. AWDFLASH 8.23K is included in this BIOS package. 2. Fixed the exclamation point under Motherboard Resources of Device manager in Windows XP when use USB keyboard/mouse and set as"Support via BIOS". 3. Fixed the intermittent sirens when getting into Windows 2000 or XP with both "Shutdown when CPUFAN Fail" and "CPU Shutdown Temperature"enabled in PC Health Status. 4. Calibrated the readings of "CPU Over Temp. Protect" option in SoftMenu III. 5. Fixed the problem that SATA BIOS string is wrongfully connected with PCI add on card BIOS. 6. Fixed system freeze problem in S-ATA BIOS initial while using display card on PCI slot. 7. Fixed the problem if FAN speeded too slow, system would hang at BIOS screen or at watching the status in PC health Status screen. BIOS Compile Date: 7/2/2003. Revision: 1.0~1.2 http://fae.abit.com.tw/eng/download/bios/nf7-s.htm Revision: 2.0 http://fae.abit.com.tw/eng/download/bios/nf7-s2.htm Jeg er faktisk imponert over hvor ofte Abit slipper ut nye BIOS filer og fikser forskjellige ting Lenke til kommentar
