Mohammed karikaturene
Mohmmed karikaturene?
174 stemmer
  1. 1. Var det riktig å tegne Mohammed tegningen?
    • Ja, selvfølgelig. det er jo ytringsfrihet...
      155
    • Nei, et sted går grensen. Noe må kunne holdes "uberørt"...
      13
    • Vet ikke, egentlig kan folk gjøre hva de vil så lenge jeg ikke blir berørt.
      6
Islam er en totalitær politisk ideologi som instruerer sine følgere til å drepe alle som ikke vil slutte seg til islam. Islam som ideologi, med koranen som manifest, er i strid med Norsk lov og burde forbys. Strengt tatt er koranen ulovlig, da det er forbudt å oppfordre til drap, men ingen politikere har mot til å ta dette opp.
kill the polytheists wherever you find them and capture them and besiege them and sit in wait for them at every place of ambush. But if they should repent, establish prayer, and give zakah, let them [go] on their way. Indeed, Allah is Forgiving and Merciful.
They wish you would disbelieve as they disbelieved so you would be alike. So do not take from among them allies until they emigrate for the cause of Allah . But if they turn away, then seize them and kill them wherever you find them and take not from among them any ally or helper.
Indeed, Allah has purchased from the believers their lives and their properties [in exchange] for that they will have Paradise. They fight in the cause of Allah , so they kill and are killed. [it is] a true promise [binding] upon Him in the Torah and the Gospel and the Qur'an. And who is truer to his covenant than Allah ? So rejoice in your transaction which you have contracted. And it is that which is the great attainment.
Fight those who believe not in Allah nor the Last Day, nor hold that forbidden which hath been forbidden by Allah and His Messenger, nor acknowledge the religion of Truth, (even if they are) of the People of the Book, until they pay the Jizya with willing submission, and feel themselves subdued.
Det som skjer i verden handler mer om angrep & hevn fremfor relegion.
tenk 2 sidig. hvor mange muslimer blir drept hverdag uten at det gjør media noe vondt.
når en muslim blir drept = ingenting. når en ikke-muslim blir drept: lets go!
At det var? Det var altså derfor verdenssamfunnet hjalp til i frigjøringen av Kuwait og frigjøringen av Irak fra diktatorstyret under Saddam Hussein. Det er derfor verdenssamfunnet har støttet Kurderne i deres kamp mot de som forfølger dem? At det er mulig å være så blind ...
Red.: Det er også derfor verdenssamfunnet er i harnisk, når idiotiske muslimske ledere, med folket i ryggen steiner jenter som er blitt voldtatt.
Endret av NikkaYoichi
  • Liker 4
Men det er jo andre muslimer som dreper muslimene. Og dessuten reagerer media når uskyldige muslimer blir drept.
Du kaller det "frigjøring" jeg vet ikke om du har sett sannheten bak støtten. hvor mange folk tapte livet ved den såkalte frigjøringen ? hvor mange kvinner ble voldtatt? hvor mange barn ble drept? , hvor mange menn ble straffet i fengslene? om du sammenligner så var denne frigjøringen mye værre enn saddam systemet.
Det samma gjentar seg i Libya nå, dem ville lage et flyforbudsone så har dem begynt å skyte sivile dem også.
Peace2, ofte må en revolusjon gjennom en fase der det er verre enn det var før, men etter det blir det mye bedre. Håper vi.
Og om du tror at USA skyter ned sivile med vilje så har du alvorlig lite viten om politikk, USA jobber veldig for å opparbeide tillit i verdenssamfunnet uten å miste sin posisjon i det.
Thou eg og ser at de ikke følger FN-mandatet til punkt og prikke, men eg mener også at det ikke burde vere en FN avgjørelse, men en NATO. Men de fikk det gjennom, selv om Kina og Russland.
Hvor mange tapte livet under Saddams styre?
Hvor mange kvinner ble voldtatt under Saddams styre? Hvor mange av disse ble henrettet etter å ha blitt voldtatt, fordi de hadde a)hatt sex utenfor ekteskapet, b)vært utro?
Hvor mange barn ble drept under Saddams styre?
Hvor mange menn ble straffet i fengsler under Saddams styre? Hvor mange ble drept? Hvor mange fikk armer og eller føtter kuttet av som straff?
Hvor mange barn ble brukt som barnesoldater av Saddams styrker? Hvor mange sivile ble brukt som levende skjold av Saddams styrker?
Jeg snakker jo om det som HAR skjedd , jeg snakker ikke om dem gjorde med vilje / ikke , men tallene var store. jeg er ikke noe politikk intressert, jeg tok saken som et eksempel.
Dersom eg, ved ett uhell skulle komme til å skli, falle bort til vinduet og velte en murstein liggende der og en forbipasserende får denne i hodet, vert skyldig i mord? /moralsk sett, ikke juristisk sett fra norsk- og/eller andre lovverk/ Forandrer det noe om denne mursteinen klarer på en merksnodig måte å drepe tusen andre mennesker? Går ut i fra det ettersom du skrev "[..]Men tallene var store.[..]"
Isåfall er ikke dette ett eksempel, og da har eg ikke regnet med at USA er veldig mange personer, alle med forskjellige meninger og moralske sett. (vel kanskje ikke men, men...)
Jeg har klasifisert de fleste personlighetene her inne:
Noen vil spørre og lære det er et mindretall . dem spør får svar & legger til det i sin kunskap om relegion.
Så er det en andre gruppen , anti-relegion gruppa:
Dem vil kun spre kurropsjon og vil at alt skal være dårlig ved å spre flest mulig uenigheter & konflikter i samfunnet. inviterer dem til foredrag kalt peace confrance 2011, det vil bli i Oslo 16,17,18. sitteplass kan reserveres på islamnet.no sine sider.
De fleste aktive her er antirelegion gruppa (over 90%). dem som ikke vil lære.
Det skader meg abslutt ingenting hvor mange dem er / hvor mye dem støtter hverandre for poenget er at hvis dem aksepterer Gud er det for dems fordel. hvis dem ikke gjør har dem tatt på seg ansvaret. mitt oppgave her var bare å informere så ikke dem kommer å sier at jeg ikke sa i fra.
så jeg ser for meg at det er mye energi å spare der. for det dem sier vil ikke forandre virkligheten noe.
mulig det vil føre til hat & uenigheter. men ser ikke det positive i det. Jeg har varslet flere ganger så jeg føler at meldingen min har kommet frem. det er opp til hver enkelte om den vil akseptere Gud eller ikke. ( ikke Guder for ekte Gud er en, det finner man fort ut )
01 Si: «Han er Gud, Én.
002 Gud, den Evigvarende.
003 Ikke har Han avlet noen, ei heller er Han selv blitt avlet.
004 Ingen er Hans like.»
001 Ved tidens makt!
002 Mennesket kommer visselig til kort! (til tap)
003 Unntatt er de som tror og lever rettskaffent, som legger hverandre sannheten på hjertet, og standhaftighet.
Koran
Gudene er mange, og Gudinnene like så. At du sier noe annet, viser at du ikke vet noen ting om saken.
Du er også anti-religiøs mot 99,999% av verdens religioner. Du er mot polyteisme, du er mot ateistiske religioner, paganisme, satanisme osv.
Det eneste som skiller deg fra de andre anti-religiøse her på forumet er synet ditt på Islam.
  • Liker 5
Peace2 er tilhenger av verdens eneste religion som kaller medlemmer av andre religioner ved navn, og omtaler dem som "de verste krek", "perverse" og instruerer sine følgere til å drepe disse "people of the book" (jøder og kristne) hvor enn man finner dem, og kjempe mot dem til de villig betaler Jizya i ydmykhet, og føler seg underlegne for muslimene.
Litt av en respekt for religion må jeg si. Islam sier at alle andre religioner tar feil, og sier direkte at Guden deres hater kristne og jøder. Muslimsk dobbeltstandard, pakket inn i den falske "vi er fredelige muslimer" fasaden.
Vi ser over hele verden hvor fredelige muslimer er.
http://chromatism.net/bloodyborders/
  • Liker 3
usaklig kan man bli når en bjeffer på alle forby passerende biler...
vær oppmerksom på at det du sier kan medføre til at du havner under dette når du påstår at det fins flere Guder.
059 «Hold dere for dere selv i dag, dere syndere!
060 Gjorde Jeg ikke en avtale med dere, Adams barn, at dere ikke skulle tjene Satan, han er for dere en klar fiende,
061 og at dere skulle tjene Meg? Det er rett vei.
062 Han har ført en stor mengde av dere vill.
063 Tenkte dere da ikke? Dette er helvete, som dere ble stilt i utsikt.
064 Ta i dag den stekende ild fordi dere var vantro!»
065 På denne dag vil Vi sette dem segl på munnen. Men deres hender vil tale til Oss, og deres føtter avlegger vitnesbyrd om det de har pådratt seg.
066 Om Vi ville, kunne Vi utviske deres øyne. Da ville de nok løpe om kapp med veien, men hvordan skulle de se?
067 Om Vi ville, kunne Vi omskape dem på stedet, så de ikke kunne gå verken frem eller tilbake.
068 Den Vi gir et langt liv, lar Vi reduseres kroppslig (snur Vi om i skapningen). Forstår de da ikke?
069 Vi har ikke lært ham dikterkunsten, det passer seg ikke for ham. Dette er bare en formaning, og en klar Koran,
070 så han kan advare de levende, så at ordet kan iverksettes overfor de vantro.
071 Har de da ikke sett at Vi har skapt kveg for dem ved Våre henders verk, som er deres eiendom?
072 Og Vi har temmet det for dem, noen av dem kan de ride på, andre kan de spise.
073 Også annen nytte har de av dem, og de gir drikke. Vil de da ikke vise takknemlighet?
074 Men de har lagt seg til guder utenom Gud, for at de kanskje måtte bli hjulpet.
075 Men de kan ikke yte dem hjelp, skjønt de for dem er en tilstedeværende hærskare.
076 La ikke deres tale bedrøve deg! Vi kjenner til det de holder hemmelig, og det de bærer åpent frem.
077 Har da ikke mennesket bemerket at Vi har skapt ham av en sæddråpe? Men så, så blir han stridbar og kranglete, klart og åpent.
078 Og han tar et eksempel for Oss, og har glemt sin skapelse. Han sier: «Hvem skal gi liv til morkne ben?»
079 Si: «Han skal gi dem liv, som frembrakte dem første gang! Han kjenner til all skapning.
080 Han som gir dere varme av grønne trær, og se, dere kan tenne opp med dem.
081 Evner ikke Han, som skapte himlene og jorden, å skape deres like? Jo, sannelig, Han er Skaperen, den Allvitende.
082 Hans bud, når Han ønsker noe, er at Han sier til det: 'Bli!' – og det blir.
083 Ære være Ham, i hvis hånd herredømmet over alle ting beror, til Hvem dere blir brakt tilbake!»
Endret av peace2
1) Alle tyske nazisoldater sverget troskap til føreren av det tredje riket.
2) Alle tyske soldater var ikke onde psykopater og nazister.
3) Jeg henviser til nazisoldater som ondskapen selv. Se pkt. 1
Bytt ut "tyske nazisoldater" med muslimer, og du vil se at regnestykket fortsatt stemmer.
Al Wala' Wal Bara' (Love and Hate for Allah's Sake)
http://qa.sunnipath.com/issue_view.asp?HD=1&ID=801&CATE=3
Jeg er ikke araber, din gud gjelder ikke for meg. Du klarer aldri å skremme meg, for din gud er den yngste og svakeste av alle guder. Det du sier medfører skam og vanære for deg.
Endret av Abigor
