NET Framework 2.0 fix problemer
Hei.
Pga av et eksternt system må jeg installere en fix til .NET Framework 2.0
jeg prøver å installerere KB923028 FIX: Error message when you run a .NET Framework 2.0 Remoting application: "Unhandled Exception: System.AccessViolationException"
Får følgende feilmelding: because the program to be upgraded may be missing, or the upgrade patch may
update a different version of the program. Verify that the program to be
upgraded exists on your computer and that you have the correct upgrade patch.
Er det noen som har vært borti dette problemet før??
