Den herlige Samsung Galaxy S II tråden! Prat i vei...
Byxxi
CyanogenMod virker veldig interessant ut. Håper det er muligheten å få disse funksjonene i den vanlige firmwaren (spesielt Phone Goggles).
CyanogenMod (pronounced sigh-AN-oh-jen-mod), is a customized, aftermarket firmware distribution for several Android devices (See above for supported devices & how to install CyanogenMod on said devices). Based on the Android Open Source Project, CyanogenMod is designed to increase performance and reliability over Android-based ROMs released by vendors and carriers such as Google, T-Mobile, HTC, etc. CyanogenMod also offers a variety features & enhancements that are not currently found in these versions of Android.
Features:
Phone Goggles
Phone Goggles provides to the end user the ability to filter its outgoing communications and avoid any unwilling call or SMS to be sent. Several settings can be configured: the way the user will be informed that his communication has been blocked (and whether or not is allowed to unlock the blocking), the period during which the communications will be filtered, the type of phones that will be filtered (Work, Mobile, Other)
OpenVPN:
Incognito Mode
For times when you want to browse in stealth mode, CyanogenMod offers the incognito browsing mode. Here's how the incognito mode works: Webpages that you open and files downloaded while you are incognito aren't recorded in your browsing and download histories.
All new cookies are deleted after you close all incognito windows that you've opened.
Hvordan skrive denne ro.camera.sound.forced=0? Hva skal man skrive den med? Notepad? Og så kalle den local.prop og legge den inn på rett plass?
Here is a quick tip for the Samsung Galaxy S2 users that want to make the camera silent. Good point is that this technique doesn’t delete anything on the phone and is pretty simple to follow. Involves only adding a one line of code to a file.
So, here you go:
Step 1: First check that if there is a file called "local.prop" exist in the /data/ folder (i.e. "/data/local.prop").
Step 2: In case this file doesn’t exist then create one.
Step 3: Open the file and add the following line:
Step 4: Now reboot the SG2 and camera application should be completely silent!
Step 5: To restore the sound either delete the "local.prop" file or change the code line to as follow (that you entered earlier):
ro.camera.sound.forced=1
Jeg lastet ned programmet "Blade Buddy" fra Market og gjorde det med det. Husk at du må restarte telefonen etter du har endret verdiene for at endringene skal tre i kraft.
Ok, takker :thumbup:
MEN hva er forskjellen mellom vanlig og pro utgaven?
Ser ikke forskjell jeg.
Bruk kabelen du fikk med telefonen, drag and drop hvor du vil. Og la musikkspilleren ta seg av organiseringen. Mulig du må gjøre en innstats på organisering av spillelister selv
Kan man da altså gå inn i iTunes, kopiere alle filene og lime inn i en av de mappene på mobilen?
So, here you go:
Får ikke av kamera lyden jeg med det programet. Har fått satt ro.camera.sound.forced=0 og, og save in RAM og restartet mobilen.
MEN lyden er der fortsatt :hmm:
Usikker på hvordan det funker med itunes, men om du har alle filene et sted, så kan du bare dra de inn i telefonen. Mulig du bare kan markere, og drag&drop med itunes også.
Legger musikkfilene seg da automatisk i musikkavspilleren og organiseres?
hei, kan noen svare på om jeg må legge apps i mapper når de 7 sidene tar slutt?
Du må jo ikke legge de i mapper. Det er forøvrig bare hjemmeskjermene som er begrenset til 7 stykk, app-draweren har så mange sider som det er apps.
Endret av SBS
Takk Lionel!
Er det andre enn meg som synast at lockscreenen er jævli treig til tider? Opp til mellom 1 og 2 sekund delay...
Andre som har vore borti det/ veit korleis ein kan løyse det?
Skjer med stock lockscrren og Lockscreen widget
Ja dessverre er dette ganske vanlig, det kommer visst av at det tar tid å "vekke" prosessoren etter at den klokker seg ned til 200mhz i dvale. Legg merke til at den våkner insta når den står til lading, eller du spiller av musikk f.eks.
Det er ikke slik på de fleste andre telefoner jeg har vært borti, selv om de også naturligvis klokker ned i dvale. Dette er mitt første ønske til fixing fra Samsung sin side.
Et alternativ er å bruke "softlocker" som holder mobilen utenfor dvale, men dette krever selvfølgelig sitt av strøm. Test det og se hva du syns eventuelt :)
Håper virkelig en update kommer snart. Min tlf holdt.i ca 4-5timer idag etter jeg brukte nettet i.ca 3 timer. Blir ikke akkurat imponert av denne driten...
Jeg tror ingen update i hele verden kan hjelpe deg. Om det kommer en update vil den aldri kunne øke levetiden på ditt batteri med 19-20 timer uansett, lykke til videre...
om denne dritt telefonen av et batteri for et løft på 3 timer,så burde jeg vell streng tatt vært overlykkelig
Det er helt på tryne at vi som har kjøpt oss denne dingsen for 5000-6000 kroner må tukle med så mye,for at en tlf skal holde i 12-15 timer,altså for en dag.
Hvis det er for mye å be om, så vet ikke jeg.
Såpass burde man klarte å få til, hvis dette er ment til å være den beste telefonen så langt på markedet. Hva hjelper det om du ikke kan bruke den mer enn 1/4 av dagen , så må du drive å gå rundt med et ekstra batteri eller 2 for den saks skyld.
Rett og slett håpløst
fy faen så sur jeg blir,at det holder på å koke over for meg
Endret av madman88
Gjest
