Hva menes med RAMDAC (eller: Er jeg blitt lurt?)
Ang. mitt skjermkort; Gainward FX PowerPack! Model Pro/660 TV oppgir Gainward følgene specs:
Processor nVIDIA GeFORCE FX 5200
Enginne Clock 250 + MHz
Frame Buffer 64 MB
Memory Type Fast DDR
Memory Width 64 bit
Bandwidth 2.5 GB/sec
RAMDAC 400 MHz
Maximum Resolution @ 85 Hz 2ß48 x 1536
AGP 8X
Rendering Pipelines 4
Texels/Clock 4
Men jeg får oppgitt: Core 250 Memory: 280
Kortet er demokjøpt på komplett... er dette defekt???
RAMDAC speed is a frequency at which the RAMDAC processes the pixels and sends the video signals to to the monitor. The "speed" depends on current video mode. When the RAMDAC speed is given as a parameter of a graphics card, this is the maximum speed which the RAMDAC may achieve. This parameter is not a measure of the card's performance - it simlpy reflects the maximum monitor refresh rate which may be achieved by the card. Actually the RAMDAC works near to its speed limit only in very high resolution modes.
Nei. Du har ikke blitt lurt. Er ikke sikker på hva ramdac selv er men fant dette på google. virker som det har noe med å kjøre om til analoge signaler. Høyere ramdac, desto høyere oppløsnig kan du kjøre.
Random Access Memory Digital-to-Analog Converter
<hardware> (RAMDAC) A combination of three fast DACs with a small SRAM used in graphics display adapters to store the colour palette and to generate the analog signals to drive a colour monitor. The logical colour number from the display memory is fed into the address inputs of the SRAM to select a palette entry to appear on the output of the SRAM. This entry is composed of three separate values corresponding to the three components (red, green, and blue) of the desired physical colour. Each component value is fed to a separate DAC, whose analog output goes to the monitor, and ultimately to one of its three electron guns (or equivalent in non-CRT displays).
DAC word lengths range usually from 6 to 10 bits. The SRAM's wordlength is three times the DAC's word length. The SRAM acts as a colour lookup table. It usually has 256 entries (and thus an 8-bit address). If the DAC's word length is also 8 bits, we have a 256 x 24-bit SRAM which allows a selection of 256 out of 16777216 possible colours for the display. The contents of the SRAM can be changed while the display is not active (during display blanking times). The SRAM can usually be bypassed and the DACs can be fed directly by display data (for true colour modes).
dette er kansje til utenom tema,men ser at du klager over 3d mark score din.
da jeg så spek på kortet ditt,er det ikke sikkert at du får så mye mere med det kortet du har nå(3d mark)
båndbredde på 2.5 er veldig dårlig(ikke for og kritisere deg)men det er jo dårligere enn mx 440.di hadde vel ca 4-5 i båndbredde.
ge-forec 2 mx 400 har ca 2.8 i båndbredde,så du har kansje et low end fx 5200-kort.
så prøv og selge det,og kjøp nesten hva som helst så får du mye mere i 3dmark.
geforce ti 4200-4400-4800 er jo mye bedre(men ikke directx 9)
fins jo billig demokort på komplett.
eller ati 9500-5600-9700(non pro)
da får du 5000-8000 mere i 3d mark.
bare et forslag... :)
