Asus P8P67 Evo + Corsair A70 = 2 vifter på max.
Gjest Slettet+3165
Gjest Slettet+3165
Hei og hå!
Sliter med at jeg ikke får justert en Corsair A70 på et Asus P8P67 Evo-hovedkort
Adresserte dette problemmet i SB-tråden (se her), uten å få så mye svar. Sendte så epost til Asus Support og etter litt frem og tilbake fikk jeg følgende svar:
(Warning! Massive wall of text!)
Dear Valued Customer,
The CPU fan header cannot control a thee pin fan, only a 4 pin PWM fan.
If you have not already done so, please read this:
http://event.asus.com/2011/SandyBridge/notice/
Please do not remove any previous conversation from this email / Vänligen radera inget från denna mailkonversation
---------- Original Message ----------
Sent : 2011-02-18 10:37:09
To : "[email protected]"
Subject : RE: <TSD> Motherboard P8P67 EVO [iD=RWTM20110218329498693-797]
[CASEID=TM2011021801503]
I am using a Corsair A70, with a 3-pin fan connection.
Subject: Re:<TSD> Motherboard P8P67 EVO [iD=RWTM20110218329498693-
797]
To: henrik
Date: Fri, 18 Feb 2011 16:00:42 +0800
Thank you for contacting ASUS Customer Service.
My name is Nils and it's my pleasure to help you with your problem.
Do you use a 4 pin PWM fan or a three pin fan?
Sent : 2011-02-17 19:32:24
Subject : <TSD> Motherboard P8P67 EVO
[CASEID=WTM20110218329498693]
Apply date : 2/17/2011 7:29:49 PM(UTC Time)
[Contact Information]
*Name : Henrik
*Email Address :
Phone Number :
City :
*Country : Norway[Norge]
[Product Information]
*Product Type : Motherboard
*Product Model : P8P67 EVO
*Product S/N :
Place of Purchase :
*Date of Purchase : 2011/1/14
[Motherboard Specification]
*Motherboard Revision : P8P67 EVO
*Motherboard BIOS Revision : 1204
[VGA Card Specification]
*VGA Card Vendor : Zotac
*VGA Card Model : GTX 460
*VGA Card Chipset : GTX 460
*VGA Card Driver : Nforce 266.58
[CPU Specification]
*CPU Vendor : Intel
*CPU Type : 1155
*CPU Speed : 3,3 ghz
[Memory Specification]
*Memory Vendor : Kingston
*Memory Model : ddr3 sdram
*Memory Capacity : 8 GB
[HDD Specification]
HDD Vendor :
HDD Model :
HDD Capacity :
[Add-on Card Specificatio]
Add-on Card Vendor :
Add-on Card Type :
Add-on Card Model :
*Operating System : Windows 7 64bit
[Problem Description]
I can't adjust my CPU FAN speed in any way, it always goes at a 100%.
I have tried disabling q-fan controller, reinstalling fanxpert, adjusting fan speed in
bios and so on.
I read something about that this problem occured in Windows 7 for some user, but
when they switched to Windows XP, they didn't have any problem.
I have tried running AI suite in windows xp, with no luck there either.
Adding a picture showing no fan speeds under the fan speed test function in the
right.
Syns dette virker helt urimelig, at jeg ikke skal kunne justere viftene mine bare fordi jeg mangler PWM?
Har ikke vært noe problem på foregående sokkler.
Noen andre som får justert hastigheten med 3pin på SB?
Endret av Slettet+3165
Har samme hk/kjøler oppsett selv, og samme problem. Sys fan kontaktene kan imidlertid voltreguleres så jeg endte opp med å koble viftene fra cpu-kjøleren der og bruke en (mye mer stillegående) kabinettvifte i cpu fan...
Idiotisk opplegg av asus. Forhåpentligvis får jeg byttet det inn i et msi eller gb kort når s1155 hovedkort kommer tilbake på markedet...
Gjest Slettet+3165
Ja, endte me å gjør noe lignede selv, bare at jeg kobla cpu viftene til en akasa viftekontroll.
kobla en nexus vifte som sviver på ca max 900 til cpu kontakten.
forsåvidt har jeg fått en mail til om at det kan mulig det går an ved en bios update.
  • 4 uker senere...
Gjest Slettet+3165
Har samme problem med A70 på Asus P8P67 med siste bios. Har noen funnet ut av dette?
Som sagt ble løsninga:
"bare at jeg kobla cpu viftene til en akasa viftekontroll.
kobla en nexus vifte som sviver på ca max 900 til cpu kontakten."
Ellers som også nevnt, så kan det være det kommer en oppdatering i en fremtidig BIOS.
Ingen av de nåværende biosene fikser problemet.
Ja, dette er selvfølgelig en mulighet. Selv har jeg byttet viftene til noen mindre støyende jeg hadde liggende. MEN jeg synes ikke dette er en gyldig løsning. Asus bør få fingeren ut og ordne det for oss! :realmad:
For øvrig går det nok an å lage en liten krets, noe ala denne, og få det til å fungere tilfredsstillende. Kretsen fungerer visst til hastighetsregulering, men RPM-signalet blir noe forstyrret. Jeg ønsker meg full funksjonalitet (som om viften hadde 4-pin plugg), men har dessverre ikke elektronikkunnskapene til å konstruere kretsen selv.
  • 2 måneder senere...
Etter å ha irritert meg over dette en stund gikk jeg til innkjøp av en relativt billig greie (under NOK 40). Det er en liten viftestyringsenhet av denne typen.
Den fungerer som forutsatt, men krever at minimumsspenningen på vifteutgangen settes høyt nok til at viften snurrer.
Ellers bærer den litt preg av å være billig. En gang i mellom lager den en lav, men ubehagelig pipelyd (det kan for så vidt hende jeg ikke har lokalisert lydkilden korrekt).
Alt i alt er jeg middels fornøyd. Hovedkortet har fått funksjonalitet det burde hatt i utgangspunktet, som selvsagt er positivt, men jeg må ha en liten blå drit inni maskinen, som attpåtil piper.
Gjest Slettet+3165
Jeg har faktisk bytta hovedkort til B3-revisjon.
Egentlig var jeg ute etter et Gigabyte kort, for å slippe dette våset igjen, men endte opp Asus igjen.
Årsak: lite utvalg av annet enn Asus med p67 m-atx.
Ble du kvitt problemet ved å bytte til rev. B3? Jeg har nemlig den revisjonen, uten at det har hjulpet meg. Nå har jeg ikke oppgradert bios i det siste (siden jeg kjøpte viftestyringen), så kanskje de rett og slett har fikset det?
Gjest Slettet+3165
Jeg satt sammen PCen igår, har faktisk ikke sett så mye mer på det enn at jeg testet og boote opp pcen :-)
Skal holde deg oppdatert.
