[Løst] Er 430w nok?
Hei, er litt i tvil om 430w er nok.
Skal ha disse komponentene:
SAMSUNG DVD±R/RW/RAM DL 22X SATA BULK SVART
ASUS M4A87TD USB3 AM3 ATX
ASUS GEFORCE GTX 460 DIRECTCU 1GB GDDR5 PCI-E DVI/HDMI
AMD ATHLON II X4 640 3.0GHZ 2MB SOCKET AM3 BOX
CORSAIR 4GB DDR3 VALUE SELECT PC10666 1333MHZ (2X2GB)
SAMSUNG SPINPOINT F3 500GB SATA/300 7200RPM 16MB
Vet ikke om RAM har så mye å si men tok det med alikevel :new_woot:
Takker for svar.
Endret av mr.saxy
http://www.hardwaresecrets.com/article/Corsair-CX430-Power-Supply-Review/1200
This unit features active PFC, of course, and doesn’t come with a modular cabling system. The cables are protected with nylon sleeves and the unit comes with the following cables and connectors:
* Main motherboard cable with a 20/24-pin connector, 23.6” (60 cm) long
* One cable with two ATX12V connectors that together form an EPS12V connector, 23.6” (60 cm) long
* One cable with one six/eight-pin connector for video cards, 23.2” (59 cm) long
* Two cables, each with two SATA power connectors, 16.5” (42 cm) to the first connector, 5.9” (15 cm) between connectors
* One cable with three standard peripheral power connectors and one floppy disk drive power connector, 16.5” (42 cm) to the first connector, 5.9” (15 cm) between connectors
Den strømforsyningen har ikke mange nok kabler til å drive skjermkortet ditt, som trenger 2 stk 6-pins PCI-E kontakter. Den første strømforsyningen til Corsair som gjør det er TX650 så vidt jeg vet.
Endret av HaakonNordengen
