Vet ikke om dette er riktig kategori, men here it goes.
Tok meg en sjekk på windows oppgavebehandling og fant 2 Csrss.exe filer. Er dette vanlig? Er redd det ligger noe dritt å gjemmer seg i de dypere windowsfilene.
Edit: Kan noen foreslå et godt gratis scanneprogram mot malware etc?
Verdt å nevne at jeg kjører en;
Multicom Compal NBLB2
Intel i5 duo 2,4 ghz
ATI Radeon HD 5650 1GB
Windows 7 Ultimate
Microsoft security essentials
Endret av Rgrehq543qh
jfgi plz kthx!?
What is csrss.exe doing on my computer?
The Microsoft Client Server Runtime Server subsystem utilizes the process csrss.exe for managing the majority of the graphical instruction sets under the Microsoft Windows operating system. As such Csrss.exe provides the critical functions of the operating system, and its termination can result in the Blue Screen of Death being displayed.
Csrss.exe controls threading and Win32 console window features. Threading is where the application splits itself into multiple simultaneous running tasks. Threads supported by csrss.exe are different from processes in that threads are commonly contained within the process, with various threads sharing resources within the same process. The Win32 console is the plain text window in the Windows API system (programs can use the console without the need for image display).
In mobile devices such as notebooks and laptops, the process csrss.exe is closely dependent on power management schemes implemented by the system as defined under the Control Panel option.
csrss.exe is a system process that is needed for your Windows system to work properly. It should not be removed. Check Windows now to identify removable processes that are slowing down your computer.
Endret av BlueEAGLE
