Math Commando
Math Commando er et matteprogram, som fungerer på en måte som en kalkulator, bare at man kan lage "scripts" til programmet som utfører kommandoer som er listet i scriptfilen.
Screenshots
Screenshot av /help
Screenshot av slutten av et script
Liten scripting tutorial.
Math Commando scripting-tutorial.
Important: One command per line.
1. Avaible cmds: ma*, ma/, ma+, ma-, ma_pros1, ma_pros2, ma_pros_sale
2. T1/T2 (Number 1 / Number 2)
3. Optional comment on each CMD
All scripts requires script-information, script-information can be put into the program by typing the following
commands (ONCE per line).
[N: Name of the script] and [M: Author of the script]
The following command will ask the program to multiply 5 with 7 and add the following comment: "5 x 7 is awesome c:"
"ma*"5"7""5 x 7 is awesome c:"
I have included a test script which you can learn from, to look how the testscript works
then write "/script load test" inside the application.
Eksempelscript (en side fra matteboken tetra 9)
[N: Tetra s.118]
[M: Erlend Ellingsen]
"ma*"400"0,01"34a"
"ma*"600"0,01"34b"
"ma*"250"0,01"34c"
#OPG 35
"ma*"4000"0,01"35a"
"ma*"1340"0,01"35b"
"ma*"95"0,01"35c"
#OPG 36
"ma*"500"0,03"36a"
"ma*"900"0,03"36b"
"ma*"1500"0,03"36c"
#OPG 37
"ma*"200"0,04"37a"
"ma*"3000"0,04"37b"
"ma*"90"0,04"37c"
#OPG 38
"ma*"500"0,07"38a"
"ma*"1200"0,07"38b"
"ma*"36000"0,07"38c"
#OPG 39
"ma*"50"0,08"39"
Nedlastning
MathCMD.zip
