I'M 13 YEARS OLD!
vivastar
http://forum.ecoustics.com/bbs/messages/8829/190511.html
Haha
Hello im 13 years old and i know how to solve this problem go to Properties graphic options and then click ROTATOION set it to normal this may be caused by a misfunction in the computer or a inappropriate button pressed but as u see before pressing back to normal it would be on another degree usually 180 HOPE THIS HELPS!!
I don't see the relevance of putting "I'm 13 years old" with that post, do you?
I bet the guy who claims to be 13 years old isn't even 13. his probably some old sicko who loves little boys.
Endret av vivastar
"thankyou very much 13 year old!! you solved our problem. we just were tapping the mouse or something and it flipped upside down then we got bad headaches standing on our heads while trying to use the computer. sum1 broke their neck but they're fine now. Cheers. "
