iPhone Bluetooth Handsfree: Telefonen velger automatisk feil kanal
I bilen min har jeg koblet Handsfree til iPhone'en min igjennom Bluetooth.
iPhone kan da velge mellom tre lyd kanaler:
1. Vanlig høytaler og mikrofon på telefon (Holde innpå øret)
2. Hansfree innebygd i telefonen
3. Hansfree i bilen igjennom blåtann
Når jeg ringer ut velger den alltid 3.
Når jeg motar en ekstern samtale velder den alltid 2.
Er det noe muligheter for å stille inn at når den motar eksterne samtaler så velger den automatisk 3. ?
Endret av cyclo
Tittel forbedret
After you've paired a Bluetooth device* to work with iPhone, you must make a connection to have iPhone use the device for your calls. To connect with a third-party Bluetooth device, see the documentation that came with the device.
When iPhone is connected to a Bluetooth device, all outgoing calls are routed through the device by default. Incoming calls are routed through the device if you answer using the device, and through iPhone if you answer using iPhone. In some cases, your contacts list transfers to the car kit and you can start a call by looking up a contact on the car kit's display.
Once you have paired iPhone with a Bluetooth car kit, iPhone connects to the car kit automatically when you start your car (if you have iPhone with you and Bluetooth is turned on).
Only one Bluetooth device at a time can connect with iPhone.
