Noen som vet å forklare meg dette?(lyd-install fra console)
Har planer om å legge inn den ALSA driveren, så jeg lastet ned denne filen fra http://www.alsa-project.org : alsa-driver-0.9.4.tar.
Så er det dette med at jeg ikke har kommt så langt med dette å legge inn ting og tang fra terminal. Så da trenger jeg hjelp. Så nå tar jeg å legger ut install.txt fila som følger med og håper på at det er noen som vet å hjelpe meg slik at jeg får lagt inn den driveren.
ps. har ett intigrert lydkort i et asus p4pe hk, er ikke sikker på typen.
ps. visst det er til noen nytte så har jeg kernel 2.4 ett eller annet.
Quick install
1) You must have full configured source for the Linux kernel which you
want to use for the ALSA drivers. Note that ALSA drivers are part
of the kernel, so there is necessary to resolve all symbol dependencies
between the used kernel and ALSA driver code. Partly installed kernels
(for example from distributor makers) can be unuseable for this action.
2) You must turn on sound support (soundcore module).
3) Run './configure' script.
If you have ISA Plug & Play soundcard, use --with-isapnp=yes switch.
If you want sequencer support, use --with-sequencer=yes switch.
If you do not want OSS/Free emulation, use --with-oss=no switch.
If you want turn on debug mode use --with-debug=full switch.
If you want debug soundcard detection try --with-debug=detect switch.
If you have kernel source code in another directory than /usr/src/linux,
use --with-kernel=<kernel_directory>.
Example: ./configure --with-isapnp=yes --with-debug=full
4) Run 'make install'.
5) Run the './snddevices' script to create new sound devices in /dev directory.
Skip this step, if you have a kernel with the DEVFS support.
6) Edit your /etc/modules.conf (see the kmod support section below).
7) Run 'modprobe snd-xxxx' where xxxx is the name of your card.
Note: If you have a ISA PnP soundcard you need to first run the isapnp
program from isapnptools package to initialize your
soundcard. You can also use the native ISA PnP support by
using the --with-isapnp=yes configuration switch, in which
case you do not need the isapnptools package.
You can also look at the utils/alsasound file. This script is designed for
the RedHat distribution, but it can be used with other distributions which
use System V style rc init scripts.
Ja, hvor kan jeg laste ned OSS da?
OSS er med kjernen, så du kan sansynligvisprøve å laste modulen med
modprobe i810_audio
Du kan også poste resultatet av kommandoen "/sbin/lsmod".. Om lydkortet ble lastet vil det vise der nemlig...
Om du vil bruke alsa-driverne er det lettest å laste de ned fra freshrpms.net, pass på at du finner rett versjon for kjernen din (se versjonen med "uname -r")
Ok, takker for svar ibrotha.
Jeg bruker kjernen 2.4.20-8
Her er innholdet som var listet opp i /sbin/lsmod:
[root@dhcppc1 root]# /sbin/lsmod
Module                  Size  Used by    Not tainted
i810_audio             27720   1  (autoclean)
ac97_codec             13640   0  (autoclean) [i810_audio]
soundcore               6404   2  (autoclean) [i810_audio]
binfmt_misc             7400   1
parport_pc             19076   1  (autoclean)
lp                      8996   0  (autoclean)
parport                37056   1  (autoclean) [parport_pc lp]
autofs                 13268   0  (autoclean) (unused)
tg3                    50696   1
ipt_REJECT              3928   6  (autoclean)
iptable_filter          2412   1  (autoclean)
ip_tables              15096   2  [ipt_REJECT iptable_filter]
sg                     36524   0  (autoclean)
sr_mod                 18136   0  (autoclean)
ide-scsi               12208   0
scsi_mod              107160   3  [sg sr_mod ide-scsi]
ide-cd                 35708   0
cdrom                  33728   0  [sr_mod ide-cd]
ohci1394               20168   0  (unused)
ieee1394               48780   0  [ohci1394]
nls_iso8859-1           3516   1  (autoclean)
nls_cp437               5116   1  (autoclean)
vfat                   13004   1  (autoclean)
fat                    38808   0  (autoclean) [vfat]
keybdev                 2944   0  (unused)
mousedev                5492   1
hid                    22148   0  (unused)
input                   5856   0  [keybdev mousedev hid]
usb-uhci               26348   0  (unused)
usbcore                78784   1  [hid usb-uhci]
ext3                   70784   1
jbd
Har du ett forslag om hva jeg skal gjøre videre?
Det ser jo ut som alt er lastet rett... Kanskje du må stille volumet for kortet, se om du finner et mixer program og skru på lyden i det...
Er ikke helt sikkert på hva mixer program du skal bruke (har alsa selv), men du kan prøve med "xmixer", eller finn et program med "locate mixer | grep bin"
Nei, nå vet jeg fanken ikke hva jeg skal gjøre :grumpy: nå har jeg prøv nesten alt! Det siste jeg gjorde nå var at jeg la inn xmixer og der stod det på max lyd på alt, og jeg leita opp lyd-mixeren i red hat 9 og der skrudde jeg opp på max, sjekka _igjen_ at det stod på "skru på lydtjener"og det gjorde det. Nå vet jeg ikke hva jeg skal gjøre.
Jeg kan selfølgelig legge inn rh på nytt, men det vil jeg seff helst sleppe pga alt jeg har gjort og makket med på den versjonen som jeg har innlagt nå.
