BLue Screen!
Gv3.sys har med cpu å gjøre, du må oppgradere driveren.
Linken er for xp, men instruksjonene for å oppdatere driveren er lik.
http://support.microsoft.com/kb/888399
Fra annet forum
Gv3.sys has to do with his computers CPU. If you do not at least investigate as to why this happened you could potentially damage your CPU and thus make your computer a brick until the CPU is replaced. Try finding an update for that driver in google.
To resolve this problem, use the following methods to restore your processor driver to the correct driver. The correct driver, Intelppm.sys, was included with Windows XP SP2.
To determine which processor driver is installed, follow these steps:
Click Start, click Run, type devmgmt.msc, and then press ENTER.
In Device Manager, expand Processors.
Right-click Intel Pentium M processor, and then click Properties.
Click the Driver tab.
Click Driver Details.
If your Windows XP SP2 system is using the Gv3.sys processor driver, you must update to the Intelppm.sys processor driver to correct this problem. To do this, follow these steps.
Right-click Intel Pentium M processor, and then click Update Driver.
The Driver Update Wizard will start.
If you are prompted Can Windows connect to Windows Update to search for software?, click No, not at this time, and then click Next.
Click Install the software automatically (Recommended), and then click Next.
Click Finish.
You must restart your computer to complete the installation.
Endret av arjato
