Samsung 9-serie (ZX310), ultratynn lekkerbisk.
b-real
The 13.3-inch 9 Series features a LED-backlit screen, offering users the highest quality visual experience expected from Samsung, thanks to SuperBright Plus display with 400- nit brightness. Digital images and multimedia are brought to life on the 9 Series, assisted by a 100,000:1 contrast ratio and true-to-life color reproduction (16 million colors), enriching the computing experience for end users.
Additionally, the wide 160-degree viewing angle allows users to appreciate breathtaking screen images from a variety of vantages points, making the 9 Series easy to use whether in a user’s lap, on a desk or shared in a communal space. The laptop’s ambient light sensor adjusts the display brightness based on surrounding lighting conditions and reduces user eye strain. This innovative feature is complemented by an automatically adjusting backlit keyboard that adapts to darker light conditions with greater illumination.
Innovation Inside
The 9 Series integrates the second generation Intel® CoreTM i5 processor, affording users the latest in performance computer technology. Intel HD graphics, combined with the new processor, deliver crystal-clear visuals, vibrant colors and smooth high-definition (HD) video and audio playback.
Ensuring users are ready anytime anywhere, the 9 Series makes use of Samsung’s new power-efficient lithium polymer batteries, and achieves up to 6.5 hours of battery life on average. Lithium polymer batteries extend the life of the product with double the lifespan for up to three years or 1,000 charging cycles. Additionally, various charging settings, like a “Battery Life Extender Mode” and “Express Charging Mode” empower users with options to get the most from their experience.
Signature Samsung Technology
Samsung’s Support Center ensures all content stays safe and can help troubleshoot any particular problem. Accessible with a keyboard shortcut, the Support Center helps users manage their system settings or arrange for a tech-support web chat. Samsung’s Back-up & Recovery Solution also allows users to create and restore back-ups of system data on the device, or on a network or removable storage device.
Lastly, focusing on convenience and connectivity, the new 9 Series boasts USB 3.0, Bluetooth 3.0, built-in WiMax and utilizes the latest in Wi-Fi and USB Sleep & Charge technologies.
The Samsung 9 Series is scheduled to be available in February 2011, starting at $1,599. All Samsung mobile PC products are available through Samsung resellers and distribution channels, which can be located by calling 1-800-SAMSUNG or by visiting www.samsung.com.
Key Specs:
  • CPU: Second Generation Intel® CoreTM i5 Processor 2537M (1.40 GHz, 3MB; turbo up to 2.3 GHz)
  • Operating System: Genuine Windows® 7 Home Premium (64 bit) / Windows® 7 Professional (64 bit)
  • Memory: 4GB DDR3
  • Storage (max): 128GB Solid State Drive (SSD)
  • Screen: 13.3-inch HD LED-backlit SuperBright Plus display (400 nit)
  • Resolution: 1366×768
  • Graphics: Intel HD GT2 Integrated Graphics
  • Speakers: 3 watt (1.5W x 2) stereo speakers and 1.5 watt sub-woofer
  • Battery: Lithium Polymer; up to 6.5 hours
  • Wireless: 802.11b/g/n; WiMaxi
  • Weight: 2.89 lbs. (1.3KG)
  • Weight: 2.89 lbs.(1.3KG)
Video-"hands on".
Dette her var virkelig porno.
Men batteri-tiden var kanskje det som skuffet mest egentlig men forsatt bedre en Macbook Air sine 5 timer.
Endret av b-real
Gubben fra minipcpro sier at den skal bli tilgjengelig i februar.
1600 dollar (ca. 13000 NOK) var litt i drøyeste laget for min del, selv om det er snakk om toppmodellen. Det så uten tvil ut som en fantastisk maskin, og hadde den vært tilgjengelig for en pris ned mot 8000 NOK hadde jeg sannsynligvis slått til.
  • 2 måneder senere...
Noen som har fått klådd på denne nå da?
Vurderes sterkt som reisefølge, men skulle gjerne fått litt mer info fra noen som har testet litt.
Prisen er kanskje litt høy, men MacBook Air koster vel det samme med dårligere specs. Air har vel høyere oppløsning, noe som forøvrig skuffer litt på Samsung 9-serie.
