Tilkoblingsproblemer i OpenVPN2
Fri Jan 07 17:10:08 2011 TLS Error: Unroutable control packet received from 77.41.30.172:1194 (si=3 op=P_CONTROL_V1)
Fri Jan 07 17:10:10 2011 TLS Error: Unroutable control packet received from 77.41.30.172:1194 (si=3 op=P_CONTROL_V1)
Fri Jan 07 17:10:11 2011 TLS: Initial packet from 77.41.30.172:1194, sid=15454e96 007e392f
Fri Jan 07 17:10:11 2011 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Fri Jan 07 17:10:12 2011 VERIFY OK: depth=1, /C=RU/ST=NA/L=Moscow/O=civplayers.ru/CN=openvpn-test/[email protected]
Fri Jan 07 17:10:12 2011 VERIFY OK: depth=0, /C=RU/ST=NA/O=civplayers.ru/CN=openvpn-test/[email protected]
Fri Jan 07 17:10:12 2011 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Fri Jan 07 17:10:12 2011 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Jan 07 17:10:12 2011 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Fri Jan 07 17:10:12 2011 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Jan 07 17:10:12 2011 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Fri Jan 07 17:10:12 2011 [openvpn-test] Peer Connection Initiated with 77.41.30.172:1194
Fri Jan 07 17:10:14 2011 SENT CONTROL [openvpn-test]: 'PUSH_REQUEST' (status=1)
Fri Jan 07 17:10:14 2011 AUTH: Received AUTH_FAILED control message
Fri Jan 07 17:10:14 2011 TCP/UDP: Closing socket
Fri Jan 07 17:10:14 2011 SIGTERM[soft,auth-failure] received, process exiting
Slik ser da loggen ut, noen som kan forklare hva "Unroutable control packet received from 77.41.30.172:1194 (si=3 op=P_CONTROL_V1)" betyr?
OpenVPN requires client and server to have more or less synchronized time. Therefore make sure that router has correct time. To check it use command date and if you get info about year 1970, you should enable NTP client. Also, ntp server has to be outside of your VPN as time should be corrected before VPN is established. If you have syslog enabled (to local server, or the server outside your VPN), errors like TLS Error: Unroutable control packet received from server_ip:1194 may indicate this problem. (This error message may appear if your certificates are not valid or have expired, too.)
Kilde
Kilde
Takker for den! Har sjekket sertifikatet, var innstallert og gyldig til 2020, har også lagt inn Meinberg NTP Server uten at dette hjalp:S Systemtida mi er johelt riktig... Kan det være at det går å sette NTP-serveren opp imot VPN-serveren jeg skal koble til? Er en russisk server så kan jo være at dem har annen tidssone :)
