Upcoming kabinetter 2011
Ed Hunter
Skrevet i dag, 16:17
Kommer Obsidian 650D uten vindu?
Dette fant jeg i farta, men jeg regner med at de vil lansere et sidepanel uten vindu.
Old 01-10-2011, 11:48 AM
Redbeard Official Corsair Rep., 5.2 Years
Redbeard is offline
Quote:
Originally Posted by Megalomaniac View Post
Thank for the dimensions Redbeard, they seem good, fit under most desks (under 21'), perfect for a midtower.
1) What is the expected acoustic profile? How loud will it be at full throttle?
1a) Will you have dust filters, removable?
2) Do you have plans to install a side fan for GPU cooing? (would be nice if you had a pre drilled hole for that with a dust filter, no fan required, but the option to have one)
3) Will the hard drives have rubber grommets, what kind? From the side? or from the bottom (as in the hard drive is on the tray)
4) What is on the bottom below the hard drive cage?
5) Will the PSU have rubber standoffs both on the floor and on the back of the case (where the PSU is screwed in) to reduce vibrations?
Thank you
1) It's fairly quiet at full throttle, a bit louder than the 600T due to the faster fans, but still pretty quiet. The good news is that it's quieter than 600T when the fan controller is on low.
1a) Yes.
2) Looking into a mesh panel option that can be swapped out with the window.
3) From the side.
4) A plastic stand - that's empty underneath so you can shove PSU cables under there if you want.
5) Not on the back of the case, possible on the standoffs. I'll check into it - I haven't seen it lately. Even though I've never seen a PSU's "vibration" cause system noise (our fans are rubber mounted into the PSUs already) it's an easy enough thing to check.
R.
Fractal design gjør det bra om dagen og annonserer enda en mini versjon, nemlig Arc Mini.
Arc Mini er et kabinett med mATX formfaktor, med fokus på kjøling og eleganse.
Fractal Design Arc Miditower:
Case size (WxHxD): 230x460x515mm with front and top bezel in place
Fractal Design Arc Minitower:
Case size (WxHxD): 210x395x486mm with front and top bezel in place
Key features
* Stylish, minimalistic front panel with alu-look
* Optimized for performance, massive cooling and water cooling support
* A total of 7(!) fan slots (2x 120mm in front, 2x 120/140mm in top, 1x 120mm in bottom, 1x 120mm in rear,1x 120/140mm in side panel)
* Three fans included (1x 120mm in front, 1x 120mm in rear and 1x 140mm in top)
* Support for dual 120mm radiator in top*
* 6x white painted HDD trays, with silicone mounting
* Upper HDD cage is removable and rotatable
* USB3 support in front panel
* Excellent cable routing and cable routing covers
* Easily removable front panel with clip on fan slots
* Extra, vertically mounted expansion slot, suitable for fan controllers or non-input expansion cards
Kilde Fractal-design.com
Endret av Rockbell
Noen som vet om det kommer kabinett som tar flere disker enn Lian Li Modular Cube Case i nærmeste fremtid?
Spørs hvor mye du er villig til betale det :)
Du får jo kabinettet som tar 50-80disker av rack men koster deretter.
Er du villig til legge litt penger på bordet får du også litt større kabinetter (6-10k)
MountainMods bygger på bestilling, enten utifra standard modellene eller etter dine specs.
F.eks med 30x5,25" i fronten så har du jo fint plass til 80disker i hotswap rammer, men blir en skummel pris hehe.
Eksempel på kabinett derfra
Endret av cruzader
Antec oppdaterer flere gode favoritter.
P183 V3
P193 V3
Nine Hundred Two V3
Twelve Hundred V3.
Felles nyheter for alle 4 er:
  • Front panel USB 3.0
  • Intern 2.5" SSD drive bay
  • Hull i hovedkortplate for lett montering av cpu kjøler
Link
  • 2 uker senere...
