Android JSON problem
Holder på å lage en Android app som skal hente noe data fra Google map. Dataen mottaes som JSON.
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import org.apache.http.HttpResponse;
import org.apache.http.client.ClientProtocolException;
import org.apache.http.client.methods.HttpGet;
import org.apache.http.impl.client.DefaultHttpClient;
import org.json.JSONArray;
import android.util.Log;
public class GoogleMapRequests
private static final String urlLocation = "http://maps.googleapis.com/maps/api/geocode/json?address=";
private static final String urlDistance = "http://maps.googleapis.com/maps/api/directions/json?origin=";
private static String result = null;
private static String line = null;
private static HttpGet httpGet = null;
private static DefaultHttpClient client = null;
private static HttpResponse response = null;
private static BufferedReader br = null;
private static StringBuilder sb = null;
private static InputStream is = null;
private static JSONArray sendRequest(String googleMapUrl)
	client = new DefaultHttpClient();
	try
		httpGet = new HttpGet(googleMapUrl);
	catch(Exception e)
		Log.e("log_tag", "httpGet Error: "+e.toString());
	try
		response = client.execute(httpGet);
	catch(ClientProtocolException cpeException)
		cpeException.printStackTrace();
	catch(IOException ioException)
		ioException.printStackTrace();
	try
		is = response.getEntity().getContent();
		br = new BufferedReader(new InputStreamReader(is, "iso-8859-1"));
		sb = new StringBuilder();
		while((line = br.readLine()) != null)
			sb.append(line+"\n");
		is.close();
		result = sb.toString();
	catch(Exception e)
		Log.e("log_tag", "Error converting to string: "+e.toString());
	JSONArray jArray = null;
	try
		jArray = new JSONArray(result);
	catch(Exception e)
		Log.e("log_tag", "Error parsing to JSON: "+e.toString());
		jArray = null;
	return jArray;
public static JSONArray getLocation(String location)
	return sendRequest(urlLocation+location+"&sensor=false");
Dataen som mottas når String location=norge ser slik ut:
 "status": "OK",
 "results": [ {
   "types": [ "country", "political" ],
   "formatted_address": "Norway",
   "address_components": [ {
     "long_name": "Norway",
     "short_name": "NO",
   "geometry": {
     "location": {
       "lat": 60.4720240,
       "lng": 8.4689460
     "location_type": "APPROXIMATE",
     "viewport": {
       "southwest": {
         "lat": 47.1204866,
         "lng": -24.3142579
       "northeast": {
         "lat": 69.9406045,
         "lng": 41.2521499
     "bounds": {
       "southwest": {
         "lat": 57.8097000,
         "lng": 4.0649000
       "northeast": {
         "lat": 71.3078000,
         "lng": 31.3550000
Dataen som mottaes fra google ser jo rett ut, og har også validert den uten noen problem i diverse JSON validatorer på nettet.
Problemet oppstår når stringen med data skal legges inn i en JSONArray.
try
Av en eller annen grunn godtar den ikke stringen og jeg får opp følgende error i Log:
org.json.JSONException: Value {"results":[{"formatted_address":"Norway"...org.json.JSONObject cannot be converted to JSONArray. Noen som vet hvor problemet er?
Endret av Frezz
Har funnet ut av problemet. Hadde misforstått hvordan JSONArray virker. For dere som måtte være interessert, så måtte jeg endre koden til:
try
JSONObject jObj = new JSONObject(result);
String jsonStatus = jObj.getString("status");
jArray = jObj.getJSONArray("results");
if(jsonStatus.compareTo("OK") != 0)
	jArray = null;
