TheCatIsALie Skrevet 21. desember 2010 Rapporter Del Skrevet 21. desember 2010 (endret) Begynte på FEAR idag. Burde kunne få veldig god fps, selv med høyeste grafikkinstillinger. Dette får jeg også, men på helt random går den ned.. og ned.. og ned. Daler hele tiden. Har spillet ett problem med nyere hardware? EDIT: Tatt fra: http://www.overclock.net/pc-games/164094-fear-vista-low-fps.html I think I had this problem on FEAR awhile back. Check out in device manager--->Human Interface Devices. Try and disable as many of the usb human interface devices as you can. You'll probably have like 5-6 of them there. You won't be able to disable all of them, since you probably run devices on some of them. I disabled 3 of them (and still have them disabled actually with seemingly no ill effect), and it fixed my issue with FEAR completely. It was a few months back, but if I remember correctly, that was my exact issue, crap FEAR performance but only after a few minutes. Try it, that should fix you guys up . Endret 21. desember 2010 av Jevrio Lenke til kommentar
