Trådløst nettverk på fujitsu siemens amilo virker ikke
Hei,
jeg prøver å få trådløst nettverk på en fujitsu siemens amilo til å virke.
Med kabel virker det fint, men det ser ikke ut som om den finner det trådløse nettverkskortet.
lspci :
00:00.0 RAM memory: nVidia Corporation C51 Host Bridge (rev a2)
00:00.1 RAM memory: nVidia Corporation C51 Memory Controller 0 (rev a2)
00:00.2 RAM memory: nVidia Corporation C51 Memory Controller 1 (rev a2)
00:00.3 RAM memory: nVidia Corporation C51 Memory Controller 5 (rev a2)
00:00.4 RAM memory: nVidia Corporation C51 Memory Controller 4 (rev a2)
00:00.5 RAM memory: nVidia Corporation C51 Host Bridge (rev a2)
00:00.6 RAM memory: nVidia Corporation C51 Memory Controller 3 (rev a2)
00:00.7 RAM memory: nVidia Corporation C51 Memory Controller 2 (rev a2)
00:02.0 PCI bridge: nVidia Corporation C51 PCI Express Bridge (rev a1)
00:03.0 PCI bridge: nVidia Corporation C51 PCI Express Bridge (rev a1)
00:04.0 PCI bridge: nVidia Corporation C51 PCI Express Bridge (rev a1)
00:09.0 RAM memory: nVidia Corporation MCP51 Host Bridge (rev a2)
00:0a.0 ISA bridge: nVidia Corporation MCP51 LPC Bridge (rev a3)
00:0a.1 SMBus: nVidia Corporation MCP51 SMBus (rev a3)
00:0a.3 Co-processor: nVidia Corporation MCP51 PMU (rev a3)
00:0b.0 USB Controller: nVidia Corporation MCP51 USB Controller (rev a3)
00:0b.1 USB Controller: nVidia Corporation MCP51 USB Controller (rev a3)
00:0d.0 IDE interface: nVidia Corporation MCP51 IDE (rev f1)
00:0e.0 IDE interface: nVidia Corporation MCP51 Serial ATA Controller (rev f1)
00:10.0 PCI bridge: nVidia Corporation MCP51 PCI Bridge (rev a2)
00:10.1 Audio device: nVidia Corporation MCP51 High Definition Audio (rev a2)
00:14.0 Bridge: nVidia Corporation MCP51 Ethernet Controller (rev a3)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
05:00.0 VGA compatible controller: nVidia Corporation G73 [GeForce Go 7600] (rev a1)
07:06.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller (rev c0)
Module Size Used by
parport_pc 26058 0
ppdev 5556 0
rfcomm 33811 4
binfmt_misc 6599 1
snd_hda_codec_realtek 217971 1
sco 7998 2
bnep 9542 2
l2cap 37008 16 rfcomm,bnep
joydev 8735 0
snd_hda_intel 22107 2
snd_hda_codec 87552 2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep 5040 1 snd_hda_codec
snd_pcm 71475 2 snd_hda_intel,snd_hda_codec
snd_seq_midi 4588 0
nouveau 516986 2
snd_rawmidi 17783 1 snd_seq_midi
ir_lirc_codec 3092 0
lirc_dev 9393 1 ir_lirc_codec
ir_sony_decoder 1889 0
snd_seq_midi_event 6047 1 snd_seq_midi
ir_jvc_decoder 1950 0
snd_seq 47174 2 snd_seq_midi,snd_seq_midi_event
ir_rc6_decoder 2334 0
ttm 56633 1 nouveau
ir_rc5_decoder 1950 0
drm_kms_helper 30168 1 nouveau
snd_timer 19067 2 snd_pcm,snd_seq
snd_seq_device 5744 3 snd_seq_midi,snd_rawmidi,snd_seq
rc_rc6_mce 1146 0
ir_nec_decoder 2014 0
btusb 10969 2
mceusb 11494 0
drm 168054 4 nouveau,ttm,drm_kms_helper
bluetooth 50500 9 rfcomm,sco,bnep,l2cap,btusb
snd 49006 13 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
ir_core 14654 9 ir_lirc_codec,ir_sony_decoder,ir_jvc_decoder,ir_rc6_decoder,ir_rc5_decoder,rc_rc6_mce,ir_nec_decoder,mceusb
video 18712 0
output 1883 1 video
psmouse 59033 0
agpgart 32011 2 ttm,drm
soundcore 880 1 snd
serio_raw 4022 0
k8temp 3228 0
i2c_algo_bit 5168 1 nouveau
snd_page_alloc 7120 2 snd_hda_intel,snd_pcm
i2c_nforce2 5179 0
lp 7342 0
parport 31492 3 parport_pc,ppdev,lp
firewire_ohci 21106 0
firewire_core 46643 1 firewire_ohci
crc_itu_t 1383 1 firewire_core
pata_amd 8746 0
sata_nv 19420 2
forcedeth 49433 0
sudo lshw -C network gir ingenting
gode forslag ?
Marvin
  • 2 uker senere...
Hvis det fungerte fint i Windows at det trådløse nettverkskortet skrudde seg på automatisk, så skal det vel ikke være noe problem i Linux heller.
Jeg mener å huske at på min Fujistsu Siemens som jeg ikke har brukt på en stund, men som jeg har installert Arch på, så skrur det trådløse nettverkskortet seg på uannsett, uten noe tull. Kan ikke huske i farta at jeg har installert noe ekstra heller.
Du er sikker på at du ikke har vært borti den trådløse nettverkskort knappen da? :p
