Screenshot av Linux-desktop (Modem Warning)
har vært lite aktivitet i denne tråden i det siste. her er en oppdatering =)
gått tilbake til unity fra gnome3+shell av den enkle grunn at jeg ikke gadd å gjøre det hele om igjen når jeg bytta til ssd i eee maskina.
conky fila mi ser sånn ut:
background yes
font ubuntu:size=8
xftfont ubuntu:size=8
use_xft yes
xftalpha 0.6
update_interval 1.0
total_run_times 0
own_window yes
own_window_type override
own_window_transparent yes
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
double_buffer yes
draw_shades no
draw_outline yes
draw_borders no
draw_graph_borders no
minimum_size 200
maximum_width 270
default_color ffffff
default_shade_color 000000
draw_outline no
alignment top_right
gap_x 10
gap_y 10
no_buffers yes
cpu_avg_samples 2
override_utf8_locale yes
uppercase no
use_spacer none
TEXT
${goto 40}${font Purisa:size=22}${time %H:%M:%S}
${goto 40}${time %A}
${goto 40}${time %d.}
${goto 40}${time %B}
${font ubuntu:size=6}
${image $HOME/.b2.png -p 12,30 -s 220x220}
${goto 50}SYSTEM
${goto 50}Host: ${nodename}
${goto 50}Kernel: $kernel $machine
${goto 50}Uptime: $uptime_short
${goto 50}Battery: ${battery_percent BAT0}% ${battery_time BAT0}
${goto 50}PROCCESSOR
${goto 50}CPU 1:${goto 80}${cpubar cpu0 5,65} ${cpu cpu0}% @ ${freq_g cpu0} Ghz
${goto 50}CPU 2:${goto 80}${cpubar cpu1 5,65} ${cpu cpu1}% @ ${freq_g cpu1} Ghz
${goto 50}HDD/MEMORY/WLAN
${goto 50}Root:${goto 80}${fs_bar 5,65 /} ${fs_used /} / ${fs_size /}
${goto 50}RAM:${goto 80}${membar 5,65} $mem / $memmax
${goto 50}Swap:${goto 80}${swapbar 5,65} $swap / $swapmax
${goto 50}Wlan:${goto 80}${wireless_link_bar 5,65 wlan0} ${wireless_essid wlan0} @ ${wireless_bitrate wlan0}
${goto 50}PROCESSES ${goto 150}MEM ${goto 200}CPU
${goto 50}CPU TIME $stippled_hr
${goto 50}${top name 1} ${goto 147}${top mem 1} ${goto 198}${top cpu 1}
${goto 50}${top name 2} ${goto 147}${top mem 2} ${goto 198}${top cpu 2}
${goto 50}${top name 3} ${goto 147}${top mem 3} ${goto 198}${top cpu 3}
${goto 50}${top name 4} ${goto 147}${top mem 4} ${goto 198}${top cpu 4}
${goto 50}NETWORK ${goto 150}Download ${goto 200}Upload
${goto 50}Wlan $stippled_hr
${goto 50}Speed: ${goto 150}${downspeed wlan0} ${goto 200}${upspeed wlan0}
${goto 50}LAN $stippled_hr
${goto 50}Speed: ${goto 150}${downspeed eth0} ${goto 200}${upspeed eth0}
Endret av kjeLL//
  • 2 uker senere...
background yes
font ubuntu:size=8
use_xft yes
xftalpha 0.6
update_interval 1.0
total_run_times 0
own_window yes
double_buffer yes
draw_shades no
draw_outline yes
draw_borders no
minimum_size 200
maximum_width 270
draw_outline no
alignment top_right
gap_x 10
gap_y 10
no_buffers yes
cpu_avg_samples 2
uppercase no
use_spacer none
TEXT
${goto 50}SYSTEM
Hvordan får man det derre panelet du har på høyresiden der med cpu info og slikt?
background yes
font ubuntu:size=8
use_xft yes
xftalpha 0.6
update_interval 1.0
total_run_times 0
own_window yes
double_buffer yes
draw_shades no
draw_outline yes
draw_borders no
minimum_size 200
maximum_width 270
draw_outline no
alignment top_right
gap_x 10
gap_y 10
no_buffers yes
cpu_avg_samples 2
uppercase no
use_spacer none
TEXT
${goto 50}SYSTEM
Med conky, google it ;)
Han har også lagt ved config fila til conky i posten sin som du ser
du vill også trenge dette bildet om du skal ha det helt likt. forbred deg på å sitte å knote en stund før du får den til å passe din skjerm om den ikke er 1024x600, på acer maskina er defult batt 1 og ikke 0 osv. så du må nok konfigurere uansett.
  • 3 uker senere...
Fedora 15:
Gnome 3 er litt spesiell. Utseende er stilig, men skulle gjerne hatt ikoner på skrivebordet.
Mulighet for å bytte hvilken skjerm som skal være primær hadde også vært kjekt.
Edit: Har installert tweak advanced settings som lar meg skru på desktop icons osv. Så nå begynner Gnome 3 og bli mer "brukervennlig" for en PC bruker. Rett ut av boksen føles det optimalisert for nettbrett.
Har også fått til å bytte primærskjerm ved å fikle litt med skjerminstillinger.
Endret av Bjohansen
Fedora 15:
Du kan velge hvilken skjerm som skal være "default".. Iallefall i nVidia sitt kontrollpanel.
AWN og awn-applets-all må installeres. Gnome panel har jeg tatt bort det som går an, den siste har jeg fjernet alt på, gjort usynlig og satt til at den skal skjule seg i toppen, vet ikke om det går å fjerne den helt.
Theme: Ambiance Human, her har jeg justert bakgrunnen til å nesten være gjennomsiktig.
Style: Lucido
Behaviour: Panel Mode
Size of icons: 24 (siden jeg har en liten 12" gjelder det å spare plass.
Icon effect har jeg satt til spotlight, men det er vel en smakssak.
Expand the panel er krysset av.
Siden setter man inn en separator der man vil at "panelet" skal bøye seg ned og bli gjennomsiktig, og en ny separator der den skal gå opp igjen. Pluss en expander for å flytte den til ene kanten. Her har jeg bare satt inn litt shortcuts og en klokke, og så task manager mellom to separators og en expander for å få programmene på den gjennomsiktige delen.
Bildet: Vel, jeg og moren min dro på tur nordover i sverige i helgen.... :tease:
Send PM om dere vil ha det, oppgi oppløsningen dere trenger.
  • Liker 3
  • 3 uker senere...
  • 4 uker senere...
