[Løst] hvordan installere spotify på linux?
Hei,
Kan noen hjelpe meg å innstallere spotify på xubuntu?
Har dette på en eldre laptop og dette fungerer fint, men er ikke kjent med linux - måten å gjøre ting på.
Trenger en step by step instruksjon.
Leste noe tråder på forumet her men terminologien til llinux er ukjent for meg så langt.
Hvis noe kan ta seg tid til å hjelpe meg hadde det vært fint. På den måten blir jeg også bedre kjent med linux.
mvh bjørn roger.
Endret av bjørn roger
Eneste jeg finner på spotify er dette: (og det sa meg ikke stort)
A sneak peek into Spotify’s secret labs
Spotify Previews is a new section that showcases a few of the fun ideas and projects that our developers have been working on - mostly in their spare time, during hack days or in the middle of the night when they can’t sleep. Some of these are pet projects, some are prototypes but they’re all designed to make Spotify even more enjoyable.
The projects here are unsupported by Spotify so they may not work as planned or be removed at any time, but if you like what we’re doing let us know and if they prove popular enough they may well become regular Spotify features.
Spotify for Linux
This is a preview build of Spotify for Linux. As a preview release this version is still unsupported, but we’re running it ourselves and will try to make sure it keeps pace with its Mac and Windows siblings, there are issues regarding decoding of local music on the Linux platform so we haven’t included support for local files in this version. As we haven’t found a reliable way to display ads yet, this version is only available to Spotify Premium and Unlimited subscribers.
So how do you get it? We’ve packaged it for Debian Squeeze/Ubuntu 10.04 package and for Fedora 13, i386 and x86_64.
Debian
# 1. Add this line to your list of repositories by
# editing your /etc/apt/sources.list
deb http://repository.spotify.com stable non-free
# 2. Run apt-get update
# 3. (optional) If you want to verify the downloaded packages,
# you will need to add our public key
gpg --keyserver wwwkeys.de.pgp.net --recv-keys 4E9CFF4E
gpg --export 4E9CFF4E |sudo apt-key add -
# 4. Run apt-get install spotify-client-qt spotify-client-gnome-support
Feodora 13
Run the following commands:
rpm -ivh https://www.spotify.com/wp-content/uploads/ \
previews/spotify-release-1-1.noarch.rpm
yum install spotify
Dette er en dårlig guide for helt ferske. Skal prøve å beskrive den litt mer detaljert.
1. Start terminal fra menyene i Ubuntu:
Programmer - Tilbehør - Terminal (har engelsk versjon, så mulig det ikke er helt riktig).
2. I terminal skriver du:
sudo gedit /etc/apt/sources.list
3. Legg til linjene helt nederst:
#Spotify
4. Lagre.
5. Friviillig, men ikke strengt nødvendlig for at det skal fungere, skriv følgende i terminal:
6 I terminal, skriv dette:
sudo apt-get install spotify-client-qt spotify-client-gnome-support
Forresten: Ikke la deg skremme av dette, vanligvis er det langt enklere nå å installere noe i Linux, men antar at det ennå er slik med Spotify fordi det fortsatt er Alpha :-)
Endret av RattleBattle
Hei endrebjo.
Skal prøve din metode også siden jeg ikke får det til å virke helt.
Har ivhertfall inntallert gedit og skrivd følgende kommando med feilmelding på slutten.
bro@bro-laptop:~/Skrivebord$ sudo gedit /etc/apt/sources.list
bro@bro-laptop:~/Skrivebord$ gpg --keyserver wwwkeys.de.pgp.net --recv-keys 4E9CFF4E gpg --export 4E9CFF4E |sudo apt-key add -
gpg: katalogen «/home/bro/.gnupg» ble opprettet
gpg: ny konfigurasjonsfil «/home/bro/.gnupg/gpg.conf» ble opprettet
gpg: ADVARSEL: valgene i «/home/bro/.gnupg/gpg.conf» er ikke aktive under denne kjøringen
gpg: nøkkelknippet «/home/bro/.gnupg/secring.gpg» ble opprettet
gpg: nøkkelknippet «/home/bro/.gnupg/pubring.gpg» ble opprettet
gpg: "gpg" not a key ID: skipping
gpg: "--export" not a key ID: skipping
gpg: ber om nøkkelen 4E9CFF4E fra hkp server wwwkeys.de.pgp.net
gpg: /home/bro/.gnupg/trustdb.gpg: trustdb created
gpg: nøkkel 4E9CFF4E: offentlig nøkkel «Spotify Public Repository Signing Key <[email protected]>» importert
gpg: nøkkel 4E9CFF4E: «Spotify Public Repository Signing Key <[email protected]>» ikke endret
gpg: no ultimately trusted keys found
gpg: Totalt antall behandlet: 2
gpg: importert: 1
gpg: uendret: 1
gpg: ingen gyldig OpenPGP-data funnet.
bro@bro-laptop:~/Skrivebord$ sudo apt-get install spotify-client-qt-spotify-client-gnome-support
Leser pakkelister ... Ferdig
Skaper oversikt over avhengighetsforhold
Leser tilstandsinformasjon ... Ferdig
E: Klarte ikke å finne pakken spotify-client-qt-spotify-client-gnome-support
bro@bro-laptop:~/Skrivebord$ apt-get install spotify-client-qt spotify-client-gnome-support
E: Kunne ikke åpne låsefila /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
bro@bro-laptop:~/Skrivebord$ ^C
Eventuelt mye enklere for en som ikke er kjent med terminalen:
- Åpne 'Synaptic Package Manager' (ligger under Applications -> System)
- Innstillinger -> Arkiv
- Trykk på fanen 'Annnen programvare'
- Legg til...
- Lim inn: deb http://repository.spotify.com stable non-free
- OK, oppdater, blabla
- Finn spotify i listen i Synaptics og installer
Hei
Gjorde dette nå men når jeg oppdaterte list fikk jeg denne feilmeldinga:
W: GPG error: http://repository.spotify.com stable Release: De følgende signaturene kunne ikke verifiseres fordi den offentlige nøkkelen ikke er tilgjengelig: NO_PUBKEY 4F9946354E9CFF4E
Du er egentlig nesten i mål med både terminal-måten og GUI-måten.
I terminalen har du en liten feil i følgende linje:
som skulle vært
Og du skulle sannsynligvis kjørt:
sudo apt-get update
før du prøvde install-kommandoene.
I Synaptic er jeg nødt til å se screenshot av fanene 'Annen programvare' og 'Bekreftelse' for å se hva som er rart. Sertifikatene skal i utgangspunktet hentes automagisk, men kanskje det er rotet fra terminalen som klusser det til.
Doh, du bruker jo xubuntu, da er det vel mousepad som gjelder. Beklager, er ikke helt kjent med all bundled software i *buntuvariantene.
Hei.
Det er riktig at jeg bruker xubunte. Nedstrippet verson som går lett på eldre pc.
Vet ikke helt hva du mente med "mousepad" men fikk ihvertfall installert selv om ikke sertifikata var godkjent.
Ser at prosessorbruken ligger oppe på 70-80% når jeg bruker spotify, men kan vel ikke vente annet av en gammel p3 prosessor for mobile.
Er det noen instillinger jeg kan gjøre for å få mindre prosessorbruk?
mvh bjørn r
