magnuszor Skrevet 1. desember 2010 Del Skrevet 1. desember 2010 Guten tag! Mitt ellers svært kjære fibernett fra LOS har gått betraktelig dårlig den siste mnd'n. Jeg har en forbindelse, men den er ustabil, og svært treg i forhold til hva vi betaler for. Kjørte en ping-session mot www.db.no. Jeg sitter på kabel, ikke trådløst. Reply from 81.93.163.115: bytes=32 time=482ms TTL=247 Reply from 81.93.163.115: bytes=32 time=1261ms TTL=250 Reply from 81.93.163.115: bytes=32 time=559ms TTL=250 Reply from 81.93.163.115: bytes=32 time=560ms TTL=247 Request timed out. Reply from 81.93.163.115: bytes=32 time=415ms TTL=247 Reply from 81.93.163.115: bytes=32 time=737ms TTL=247 Reply from 81.93.163.115: bytes=32 time=488ms TTL=250 Reply from 81.93.163.115: bytes=32 time=406ms TTL=247 Reply from 81.93.163.115: bytes=32 time=324ms TTL=250 Reply from 81.93.163.115: bytes=32 time=354ms TTL=247 Reply from 81.93.163.115: bytes=32 time=273ms TTL=250 Reply from 81.93.163.115: bytes=32 time=774ms TTL=247 Reply from 81.93.163.115: bytes=32 time=412ms TTL=250 Reply from 81.93.163.115: bytes=32 time=271ms TTL=250 Reply from 81.93.163.115: bytes=32 time=491ms TTL=247 Reply from 81.93.163.115: bytes=32 time=431ms TTL=250 Reply from 81.93.163.115: bytes=32 time=611ms TTL=247 Reply from 81.93.163.115: bytes=32 time=431ms TTL=247 Reply from 81.93.163.115: bytes=32 time=961ms TTL=250 Reply from 81.93.163.115: bytes=32 time=532ms TTL=247 Reply from 81.93.163.115: bytes=32 time=529ms TTL=250 Reply from 81.93.163.115: bytes=32 time=828ms TTL=250 Reply from 81.93.163.115: bytes=32 time=562ms TTL=247 Reply from 81.93.163.115: bytes=32 time=714ms TTL=250 Reply from 81.93.163.115: bytes=32 time=341ms TTL=247 Reply from 81.93.163.115: bytes=32 time=307ms TTL=250 Reply from 81.93.163.115: bytes=32 time=407ms TTL=247 Reply from 81.93.163.115: bytes=32 time=645ms TTL=250 Reply from 81.93.163.115: bytes=32 time=1134ms TTL=247 Reply from 81.93.163.115: bytes=32 time=648ms TTL=247 Reply from 81.93.163.115: bytes=32 time=988ms TTL=250 Reply from 81.93.163.115: bytes=32 time=1186ms TTL=247 Request timed out. Reply from 81.93.163.115: bytes=32 time=435ms TTL=250 Reply from 81.93.163.115: bytes=32 time=566ms TTL=247 Request timed out. Reply from 81.93.163.115: bytes=32 time=416ms TTL=247 Reply from 81.93.163.115: bytes=32 time=312ms TTL=247 Som dere ser, så er det hele rimelig ustabilt. Hva kan være årsaken til dette, og enda viktigere, hvordan kan problemet løses? 2 Lenke til kommentar
magnuszor Skrevet 2. desember 2010 Forfatter Del Skrevet 2. desember 2010 Bump! 2 Lenke til kommentar
TheCatIsALie Skrevet 11. januar 2011 Del Skrevet 11. januar 2011 Utorrent og andre programmer kan påvirke ping om aktiv. Og om andre bruker linja. Lenke til kommentar
