nicklasa Skrevet 1. juli 2003 Del Skrevet 1. juli 2003 hei .... jeg lurte på hva forskjellen på disse tingene er : 1. router 2. HUB 3. switch Håper på svar snarest Lenke til kommentar
magikern Skrevet 1. juli 2003 Del Skrevet 1. juli 2003 1.router Links a local network to a remote network. For example, your company's network probably uses a router to connect to the Internet. Can be used to connect a LAN to a LAN, a WAN to a WAN, or a LAN to the Internet. 2.Hub A connection device for networks. Allows multiple segments or computers to connect and share packets of information. 3.Switch A device to segment networks into different subnets. Segmenting the network into different subnets keeps one network from overloading with traffic. Lenke til kommentar
