SilverBlade Skrevet 24. november 2010 Del Skrevet 24. november 2010 Hei har satt opp to stasjonær pc, en som har AMD prosessor og en med INTEL prosessor. Det jeg lurur på er hva bør jeg satse på?? AMD eller INTEL, prisen blir det samme. AMD: •518692 AMD Phenom II X4 965 Black Edition Quad Core, 3,4Ghz, AM3, 8MB, 125W, Boxed •593865 ASUS Crosshair IV Formula, Socket-AM3 ATX, AMD890FX+SB850, DDR3, 4xPCIe(2.0)x16, SATA 6Gb/s, USB 3.0, SupremeFX X-FI •340676 Corsair TX 650W PSU ATX 12V V2.2, 80 Plus, Standard. 2x 6+2-pin PCIe, 8x SATA, 120mm Vifte •491282 Corsair XMS3 DDR3 1600MHz 4GB CL9 Kit w/2x 2GB XMS3 modules, CL9-9-9-24, for Core i5 and i7, 1.65V, Intel XMP •336044 D-Link DWA-140 Wireless N USB adapter, 802.11n (draft 2.0) •585861 Fractal Design 120mm Silent Vifte 120 x 120 x 25mm, 1000 RPM, 38.3 CFM, 15 dBA, 3-pin •605521 Fractal Design Define R3 Black Pearl Vifter: 1x 120mm Front, 1x 120mm Bak, Lydabsorberende, ATX, mATX, mITX •580546 HIS Radeon HD 5850 1GB GDDR5 iCooler V PCI-Express 2.0, 2xDVI, native-HDMI, DisplayPort, HDCP •499989 Microsoft Windows 7 Home Premium NO OEM, 64bit •573264 Samsung DVD±RW burner, SH-S223C 22x DVD, DVDRAM, SATA, Black, Bulk •575186 Western Digital Caviar® GreenPower™ 1TB Sata 3 Gb/s, 64MB Cache INTEL: •494703 ASUS Maximus III GENE, Socket-1156 mATX, P55, DDR3, 2xPCIe(2.0)x16, SupremeFX X-FI, ROG Connect •340676 Corsair TX 650W PSU ATX 12V V2.2, 80 Plus, Standard. 2x 6+2-pin PCIe, 8x SATA, 120mm Vifte •491282 Corsair XMS3 DDR3 1600MHz 4GB CL9 Kit w/2x 2GB XMS3 modules, CL9-9-9-24, for Core i5 and i7, 1.65V, Intel XMP •336044 D-Link DWA-140 Wireless N USB adapter, 802.11n (draft 2.0) •585861 Fractal Design 120mm Silent Vifte 120 x 120 x 25mm, 1000 RPM, 38.3 CFM, 15 dBA, 3-pin •605521 Fractal Design Define R3 Black Pearl Vifter: 1x 120mm Front, 1x 120mm Bak, Lydabsorberende, ATX, mATX, mITX •580546 HIS Radeon HD 5850 1GB GDDR5 iCooler V PCI-Express 2.0, 2xDVI, native-HDMI, DisplayPort, HDCP •604498 Intel Core™ i5 Quad Processor i5-760 Quad Core, 2.80Ghz, Socket 1156, 8MB, 95W, Boxed w/fan •499989 Microsoft Windows 7 Home Premium NO OEM, 64bit •573264 Samsung DVD±RW burner, SH-S223C 22x DVD, DVDRAM, SATA, Black, Bulk •575186 Western Digital Caviar® GreenPower™ 1TB Sata 3 Gb/s, 64MB Cache Alt er hentet fra komplett. Hva ville dere gå for? Tar i mot all kritik Takk:) Lenke til kommentar
Martin HaTh Skrevet 24. november 2010 Del Skrevet 24. november 2010 FYI, du har et mATX HK i intel builden din. Lenke til kommentar
roffenn Skrevet 24. november 2010 Del Skrevet 24. november 2010 Amd Men du kan kansje bytte ut skjermkortet Lenke til kommentar
Martin HaTh Skrevet 24. november 2010 Del Skrevet 24. november 2010 Vel, skjermkortet holder nok, uansett hva du skal. Alternativet blir jo 5870, evt vente på 6970, selv om den prisen kan bli ... interessant. Men du bør nok bytte ut Intel HKet ditt, selv kjøpte jeg akkurat Asus P7P55d-e pro, med samme CPU som du har satt opp. Kan ikke si jeg er missfornøyd. Lenke til kommentar
srbz Skrevet 24. november 2010 Del Skrevet 24. november 2010 Det er lite forskjell på AMD og Intel om dagen. Jeg ville gått for AMD, fordi HK har bedre støtte for crossfire enn noe Intel-HK på socket 1156, om crossfire noen gang skulle bli aktuelt. Lenke til kommentar
Lambern Skrevet 24. november 2010 Del Skrevet 24. november 2010 Kan jo kikke på hd 6870 også. Yter nesten som 5870, og en del over 5850, til rundt 2000 kr Lenke til kommentar
mads95 Skrevet 24. november 2010 Del Skrevet 24. november 2010 Kan jo kikke på hd 6870 også. Yter nesten som 5870, og en del over 5850, til rundt 2000 kr støtter dette forslaget.. Lenke til kommentar
Martin HaTh Skrevet 24. november 2010 Del Skrevet 24. november 2010 Det er lite forskjell på AMD og Intel om dagen. Jeg ville gått for AMD, fordi HK har bedre støtte for crossfire enn noe Intel-HK på socket 1156, om crossfire noen gang skulle bli aktuelt. Fordi det kan kjøre x16 med 2 kort? Bare så det er sagt er ytelsesforskjellen mellom x8 og x16 (i alle fall i spill) minimal. http://www.tomshardware.com/reviews/pcie-geforce-gtx-480-x16-x8-x4,2696.html Lenke til kommentar
srbz Skrevet 24. november 2010 Del Skrevet 24. november 2010 Fordi det kan kjøre x16 med 2 kort? Bare så det er sagt er ytelsesforskjellen mellom x8 og x16 (i alle fall i spill) minimal. http://www.tomshardware.com/reviews/pcie-geforce-gtx-480-x16-x8-x4,2696.html Du så side 5 i den testen? Bare det er nok for meg, når prisen likevel er den samme for begge oppsettene i dette tilfellet. Lenke til kommentar
SilverBlade Skrevet 24. november 2010 Forfatter Del Skrevet 24. november 2010 Vel, skjermkortet holder nok, uansett hva du skal. Alternativet blir jo 5870, evt vente på 6970, selv om den prisen kan bli ... interessant. Men du bør nok bytte ut Intel HKet ditt, selv kjøpte jeg akkurat Asus P7P55d-e pro, med samme CPU som du har satt opp. Kan ikke si jeg er missfornøyd. så dette blir en bedre INTEL oppsett?? Har byttet HovedKort •513218 ASUS P7P55D-E PRO, Socket-1156 ATX, P55, DDR3, 2xPCIe(2.0)x16, GbLAN, SATA 6Gb/s, USB 3.0 •340676 Corsair TX 650W PSU ATX 12V V2.2, 80 Plus, Standard. 2x 6+2-pin PCIe, 8x SATA, 120mm Vifte •491282 Corsair XMS3 DDR3 1600MHz 4GB CL9 Kit w/2x 2GB XMS3 modules, CL9-9-9-24, for Core i5 and i7, 1.65V, Intel XMP •336044 D-Link DWA-140 Wireless N USB adapter, 802.11n (draft 2.0) •585861 Fractal Design 120mm Silent Vifte 120 x 120 x 25mm, 1000 RPM, 38.3 CFM, 15 dBA, 3-pin •605521 Fractal Design Define R3 Black Pearl Vifter: 1x 120mm Front, 1x 120mm Bak, Lydabsorberende, ATX, mATX, mITX •580546 HIS Radeon HD 5850 1GB GDDR5 iCooler V PCI-Express 2.0, 2xDVI, native-HDMI, DisplayPort, HDCP •604498 Intel Core™ i5 Quad Processor i5-760 Quad Core, 2.80Ghz, Socket 1156, 8MB, 95W, Boxed w/fan •499989 Microsoft Windows 7 Home Premium NO OEM, 64bit •573264 Samsung DVD±RW burner, SH-S223C 22x DVD, DVDRAM, SATA, Black, Bulk •575186 Western Digital Caviar® GreenPower™ 1TB Sata 3 Gb/s, 64MB Cache Lenke til kommentar
SilverBlade Skrevet 24. november 2010 Forfatter Del Skrevet 24. november 2010 Er skjermkortet bra?? skal bruke det til spill som COD BO osv. Hvis ikke det er bra, finn en link til et skjerkort som er bedre, men vil ikke stige over 2000kr Lenke til kommentar
Lambern Skrevet 24. november 2010 Del Skrevet 24. november 2010 (endret) som tidligere nevnt: hd 6870 edit: leif Endret 24. november 2010 av Lambern Lenke til kommentar
SilverBlade Skrevet 24. november 2010 Forfatter Del Skrevet 24. november 2010 som tidligere nevnt: hd 6870 edit: leif det ser ut som et veldig br kort, har fått mange bra komentarer. trur jeg bytter til det kortet Lenke til kommentar
Martin HaTh Skrevet 24. november 2010 Del Skrevet 24. november 2010 Ja, da blir det nok bra. Og ja, det vil klare cod BO, jeg har selv et 4870, som ligger ganske lavt under 6870, og jeg merker ikke noe lag. Lenke til kommentar
SilverBlade Skrevet 24. november 2010 Forfatter Del Skrevet 24. november 2010 Ja, da blir det nok bra. Og ja, det vil klare cod BO, jeg har selv et 4870, som ligger ganske lavt under 6870, og jeg merker ikke noe lag. men synes du at jeg bør ta Intel eller AMD?? hovedkortet på INTEL er byttet til ASUS P7P55D-E PRO og har byttet Skjermkort på AMD og INTEL til hd 6870 Hva trur du?? Lenke til kommentar
Martin HaTh Skrevet 25. november 2010 Del Skrevet 25. november 2010 Intelen har litt bedre ytelse enn AMDen, men jeg tror det er minimale forskjeller overall. Velg det som er billigst. Lenke til kommentar
Lambern Skrevet 25. november 2010 Del Skrevet 25. november 2010 (endret) Eneste forskjellen jeg kan se er at AMD oppsettet støtter CF fullt ut. Prosessorene er vel ganske jevne, iallefall når det kommer til spilling. Kan tenks at i5 har et lite overtak, men det er ikke mye. Det går foresten gjetord om at Samsung Spinpoint F3 er en veldig rask snurredisk. Kan jo bytte ut GreenPower disken din med en slik kanskje. GreenPower ofrer vistnok ytelse for å spare på energibruken... edit: kan tenkes at det er lurt å gå for en litt sterkere PSU hvis du vil kjøre CF. kan jo regne på det her http://www.extreme.outervision.com/psucalculatorlite.jsp Endret 25. november 2010 av Lambern Lenke til kommentar
fjoera Skrevet 25. november 2010 Del Skrevet 25. november 2010 Det går foresten gjetord om at Samsung Spinpoint F3 er en veldig rask snurredisk. Kan jo bytte ut GreenPower disken din med en slik kanskje. GreenPower ofrer vistnok ytelse for å sapre på energibruken.., Ja,gå for spinpoint hvis du ikke betaler strømregninga sjøl! Lenke til kommentar
SilverBlade Skrevet 25. november 2010 Forfatter Del Skrevet 25. november 2010 edit: kan tenkes at det er lurt å gå for en litt sterkere PSU hvis du vil kjøre CF. Hva står CF for? Lenke til kommentar
Lambern Skrevet 25. november 2010 Del Skrevet 25. november 2010 CF = CrossFire X, dvs to eller flere amd/ati grafikkort koblet sammen Lenke til kommentar
