Noen her inne som har peiling på FMC på Flight Simulator X?
Se der ja! Det er ikke korrekt installert. Du manglere flere av gauge filene. Mest sansynlig har du installert FS9 versjonen av den, som ikke vil fungere i FSX uten litt fikling med .gau og aircraft.cfg filene.
Hadde forresten feil link. Her er rett: http://wilcopub.com/index.cfm?fuseaction=support_737pic
Her er løsningen og (fra samme side):
Under FSX, no gauges appear in 2D or 3D cockpit. Some switches do not work.
If you are using 737PIC under Windows 7/Vista, make sure to have purchased and installed the 737 Pilot in Command Upgrade for Windows 7/Vista available from here.
Under FSX, be sure to have the following Microsoft tools installed : FSX SP1, VS 2005.
We recommend to launch the aircraft in 2D cockpit, not in Virtual Cockpit.
Altså, det er helt utrolig at det er mulig å gjøre noe slikt, men du må altså kjøpe en upgrade for å få det til å funke med FSX og Vista/Windows 7.
http://www.wilcopub.com/index.cfm?fuseaction=737pic_pricing
EDIT2: Enda mer info om W7/Vista:
How to install and setup an add-on under Windows 7 / VISTA (32/64bits OS) ?
First, install the add-on using Full Administrator Rights.
Then, go into program files\microsoft games\
Highlight Flight Simulator X folder and right-click on it
Select the SECURITY tab
Click on your username (not on Administrator 1)
Click on the 'edit' option (it should have a pic of a shield on the button with edit next to it)
Then you should be prompted by Vista security module, click on 'ALLOW'
Then tick the 'Full Control' box and press 'OK'
Installation of our add-ons can now start.
We do not support the use of our FS2004 add-ons under Windows Vista/7 (although they may work).
Make sure to run the installation of the add-on and of Flight Simulator with full Administrator rights by right-clicking on the application file and selecting the "As Administrator" feature.
At the first add-on installation, make sure to accept the DLL Warning after the aircraft selection.
We don't support the use of our add-ons under Windows XP64 and Vista 64.
Endret av Yaricks
