oleronning Skrevet 14. november 2010 Del Skrevet 14. november 2010 Hei! Jeg har nettopp installert Boxee på min MacBook som kjører Ubuntu Maverick. Programmet funker som skal det skal helt til jeg prøver å spille av en film. Da krasjer det, og jeg havner tilbake på skrivebordet mitt. Jeg legger ved .log-filen slik at noen kanskje skjønner litt mer enn det jeg gjør. På forhånd takk! - Ole boxee.txt Lenke til kommentar
mikeys Skrevet 15. november 2010 Del Skrevet 15. november 2010 % grep ERROR boxee.txt 01:09:42 T:3079034752 M:1663967232 ERROR: GLX: Same window as before, refreshing context 01:09:42 T:3079034752 M:1663967232 ERROR: Texture manager unable to load file: special://xbmc/media/Splash.png 01:09:42 T:3079034752 M:1644466176 ERROR: Control has invalid animation type (no condition or no type) 01:09:43 T:3079034752 M:1635672064 ERROR: Detection of DVD-ROM media failed. 01:09:43 T:3079034752 M:1634328576 ERROR: HAL: seems that Hal daemon is not running: The name org.freedesktop.Hal was not provided by any .service files 01:09:43 T:3079034752 M:1634328576 ERROR: HAL: no Hal context 01:09:44 T:3079034752 M:1624899584 ERROR: (pthread_mutex_destroy(&m_mutex)): [XCriticalSection.cpp:84] 16 01:09:44 T:3079034752 M:1624899584 ERROR: Control has invalid animation type (no condition or no type) 01:09:44 T:2783923056 M:1624772608 ERROR: CBoxeeServerDirectory::GetTvShowSubscriptions, could not get subscriptions (browse) 01:09:46 T:3079034752 M:1624039424 ERROR: (pthread_mutex_destroy(&m_mutex)): [XCriticalSection.cpp:84] 16 01:09:46 T:3079034752 M:1624039424 ERROR: Control has invalid animation type (no condition or no type) 01:09:49 T:2690075504 M:1602351104 ERROR: GetDelay - snd_pcm_delay, alsa error: -5 - Input/output error 01:09:49 T:2690075504 M:1602478080 ERROR: GetDelay - snd_pcm_delay, alsa error: -5 - Input/output error 01:09:49 T:2690075504 M:1601462272 ERROR: GetDelay - snd_pcm_delay, alsa error: -5 - Input/output error hal kjører ikke eller boxee har problemer med hal. Har du sjekket at hal kjører? boxee finner ikke DVD mediet. Får du spillt av DVDer i andre programmer? Har du installert det du trenger for å lese krypterte DVDer? Lenke til kommentar
oleronning Skrevet 15. november 2010 Forfatter Del Skrevet 15. november 2010 Takk for raskt svar! DVD-romen funker, det er jeg helt sikker på. Jeg har isntallert hal. dette får jeg når jeg kjører følgende kode: ole@MB-Ubuntu:~$ sudo /usr/sbin/hald --verbose=yes 00:08:19.057 hald.c:673: hal 0.5.14 00:08:19.057 hald.c:674: using child timeout 250s 00:08:19.057 hald.c:683: Will daemonize 00:08:19.057 hald.c:684: Becoming a daemon det funker derimot ikke med /etc/init.d/hal restart: sudo: /etc/init.d/hal: command not found Lenke til kommentar
kpolberg Skrevet 15. november 2010 Del Skrevet 15. november 2010 Heter ikke servicen hald da? Lenke til kommentar
oleronning Skrevet 15. november 2010 Forfatter Del Skrevet 15. november 2010 sudo: /etc/init.d/hald: command not found kanskje den ikke kjører? selv om jeg har installert den.. jeg får beskjed om at nyeste hal er installert hvis jeg prøver med apt-get install hal Lenke til kommentar
mikeys Skrevet 16. november 2010 Del Skrevet 16. november 2010 Du kan sjekke om hald kjører. ps -A | grep hald Men i Ubuntu skal services som blir installert bli satt til å kjøre ved oppstart når man installerer dem. Så hald skal kjøre hvis den er installert. Har du prøvd å restarte hald med sudo service hald restart Mener at det er den "riktige" måten å gjøre det på i nyere Ubuntu. Lenke til kommentar
oleronning Skrevet 16. november 2010 Forfatter Del Skrevet 16. november 2010 (endret) ole@MB-Ubuntu:~$ ps -A | grep hald 24927 ? 00:00:37 hald 24928 ? 00:00:00 hald-runner 24960 ? 00:00:00 hald-addon-inpu 24962 ? 00:00:00 hald-addon-rfki 24973 ? 00:00:00 hald-addon-gene 24975 ? 00:00:12 hald-addon-stor 24977 ? 00:00:12 hald-addon-stor 24978 ? 00:00:58 hald-addon-stor 24979 ? 00:00:00 hald-addon-cpuf 24980 ? 00:00:00 hald-addon-acpi ole@MB-Ubuntu:~$ sudo service hald restart hald: unrecognized service ole@MB-Ubuntu:~$ sudo apt-get install hal Reading package lists... Done Building dependency tree Reading state information... Done hal is already the newest version. The following package was automatically installed and is no longer required: python-sip Use 'apt-get autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded. Endret 16. november 2010 av oleronning Lenke til kommentar
