Raz Skrevet 29. juni 2003 Del Skrevet 29. juni 2003 ..har en slik funksjon: Abit NF7 V2.0 EPoX EP-8RDA3+ Og har det noen effekt på ytelse? Lenke til kommentar https://www.diskusjon.no/topic/127408-hva-er-hypertransport-io-subsystem-og-hvilke-hovedkort/
formann Skrevet 29. juni 2003 Del Skrevet 29. juni 2003 Hypertransport er en bus teknologi som brukes på alle nForce2 baserte kort. Dette er hentet fra www.hypertransport.org: "HyperTransport is a new high speed, high performance point-to-point link for integrated circuits. HyperTransport provides a universal connection that reduces the number of buses within the system, provides a high-performance link for embedded applications and enables highly scalable multiprocessing systems. It enables the chips inside of PCs, networking and communications devices to communicate with each other up to 24 times faster than with existing technologies. Compared with existing system interconnects that provide bandwidth up to 266MB/sec (PCI 32-bit 66MHZ), HyperTransport's bandwidth of 6.4GB/sec represents better than a 20-fold increase in performance. HyperTransport provides an extremely fast connection that complements externally visible bus standards like the Peripheral Component Interconnect (PCI), as well as emerging technologies like Infiniband. HyperTransport is the connection that provides the bandwidth that the new Infiniband standard requires to communicate with memory and system components inside of next-generation servers and devices that will power the backbone infrastructure of the telecomm industry. HyperTransport is targeted primarily at the information technology and telecomm industries, but any application in which high speed, low latency and scalability is necessary can potentially take advantage of HyperTransport. HyperTransport also has a unique daisy-chainable feature, giving the opportunity to connect multiple HyperTransport input/output bridges to a single channel. HyperTransport supports up to 32 devices per channel and can mix and match components with different bus widths and speeds. " Lenke til kommentar https://www.diskusjon.no/topic/127408-hva-er-hypertransport-io-subsystem-og-hvilke-hovedkort/#findComment-1015877
Raz Skrevet 29. juni 2003 Forfatter Del Skrevet 29. juni 2003 Takk Formann! Da trenger jeg ikke å bekymre meg om det når jeg velger blant de nforce 2 korta som finnes Lenke til kommentar https://www.diskusjon.no/topic/127408-hva-er-hypertransport-io-subsystem-og-hvilke-hovedkort/#findComment-1016193
