"Riktig" måte å bytte trådløs router på?
nor50
Det enkleste er bare å nappe utav nettverkskablene som står i D-linken også putte de inni Asusen, absolutt ingen vits å skru av pcene da de får en ny ip automatisk.
Prøvde det i går og routeren ville etter lang tid at det skulle logges på 192.168.1.1 men det tok i alle fall en hsalvtime uten at noe skjedde.
Fikk denne meldinga etterhvert:
You failed to access to the web page that you want to view.
Reason for failed connection :
* You have set the wrong dynamic or static IP address for your RT-N16.
We suggest you: (Need account and password of administrator.)
* Please check the cable between the WAN port of RT-N16 and Internet is connected correctly or not.
Go to "Account Setting" page and check your account and password again.
Go to WAN type detecting page and RT-N16 will detect your WAN type automatically.
* Please contact your ISP(Internet Service Provider) to find out the root cause of DHCP failure.
* Plese reconfigure the IP address for your RT-N16, and ensure that it is different from your gateway IP address.
* Please check whether your IP、DNS Settings are correct.
* Plese reconfigure the local IP address for your RT-N16, and ensure that it is different from your WAN's gateway.Ex: 192.168.X.X,X is the number between 2 to 254.
* If these diagnosis can not solve your problem, please Go to Setting page of the RT-N16 and you can check and config your setting by yourself.
Hvis du har internett via GET eller andre TV-kabelselskap, så slå av kabelmodemet 5 minutter for å få IP-adresse til den nye routeren.
Slå også av og på datamaskinen.
Ellers burde resten være plug & play.
Takk, det gjorde susen!
