BSOD på ny pc trenger noe veiledning
Hei jeg kjøpte meg ny pc for noen få uker siden,først virket den veldig bra men nå når jeg spiller så hender det ganske ofte at pcn fryser og skjermen blir grågrønn,og det eneste som hjelper er å restarte em restart kanppen..Detta er helt ufattelig at en så ny pc alerede skal oppføre seg sånn.Jeg har ikke overklokket eller tukklet noe med biosen,det eneste jeg har gjordt er å legge inn nye skjermkort drivere.jeg kjørte WinDBG og dette er hva resultatet er:
Microsoft ® Windows Debugger Version 6.12.0002.633 AMD64
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\110110-12698-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/downloads/symbols
Executable search path is: srv*c:\symbols*http://msdl.microsoft.com/downloads/symbols
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02c67000 PsLoadedModuleList = 0xfffff800`02ea4e50
Debug session time: Mon Nov 1 15:06:12.790 2010 (UTC + 1:00)
System Uptime: 0 days 0:00:05.898
Loading Kernel Symbols
Loading User Symbols
Mini Kernel Dump does not contain unloaded driver list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa80068ae6d8, 0, 0}
Probably caused by : hardware
Followup: MachineOwner
2: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa80068ae6d8, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_GenuineIntel
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`033696f0 fffff800`02f21a89 : fffffa80`068ae6b0 fffffa80`0552fb60 00000000`00000006 00000000`00000001 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`03369c10 fffff800`02e03667 : fffffa80`068ae6b0 fffff800`02e7c5f8 fffffa80`0552fb60 00000002`00000005 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`03369c40 fffff800`02d6bc45 : fffff800`02ede360 fffffa80`06507aa8 fffffa80`06507aa0 fffffa80`0552fb60 : nt!WheapProcessWorkQueueItem+0x57
fffff880`03369c80 fffff800`02ce4961 : fffff880`0112ee00 fffff800`02d6bc20 fffffa80`0552fb60 42cf42cf`5c4f5c4f : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`03369cb0 fffff800`02f7bc06 : 552c552c`e443e443 fffffa80`0552fb60 00000000`00000080 fffffa80`05513040 : nt!ExpWorkerThread+0x111
fffff880`03369d40 fffff800`02cb5c26 : fffff880`0316a180 fffffa80`0552fb60 fffff880`031750c0 4d9e4d9e`05c805c8 : nt!PspSystemThreadStartup+0x5a
fffff880`03369d80 00000000`00000000 : fffff880`0336a000 fffff880`03364000 fffff880`03f49540 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_MAE_PRV
2: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
2: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
2: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
Jeg kjørte også bluscreenviewer og den sa:Caused by adress:ntoskrnl.exe+4a587c.
Min pc er Komplett gamer i70 med følgende komponenter:
Antec Twelve Hundred Big Tower Sort
Corsair HX 1000W PSU
Intel Core? i7 Quad Processor i7-930,Quad Core, 2.8Ghz,
ASUS P6T Deluxe V2, X58, Socket-1366
Corsair XMS3 DDR3 1600MHz 6GB CL9
XFX Radeon HD 5870 1GB GDDR5
Western Digital Caviar® GreenPower? 1TB
Corsair SSD Nova Series 2,5" 64GB
Windows Ultimate 7 Norsk 64 bit
Jeg kjørte memtest86 men den fant igen feil på minnet.Dete begynner å bli frustreredne.og nå nå sliter jeg plutselig med å finne oppstartshardisken under boot i bios,den er under harddrives,men når jeg skal velge booting prioritet så står kun en av harddiskene...Denna pcn har vært et mareritt siden jeg fikk den.Først måtte jeg levere den TO ganger på reperasjon der Begge gangene så måtte de bytte deffekte skjermkort.Etter det virket den super bra i en uke og så oppdaterte jeg skjermkort driverne og så var problemene der i gjenn.Mest irriterende er selfølgelig gråskjermen under spilling/filmer.
