Dette er jo nice da (customized smartphone.) synapse-phones
Dette er den riktige veien, leveres med root/åpen bootloader   :dribble:
http://synapse-phones.com/order.php
The Starting Specs are:Operating System:    Android 2.2
Processor:    1Ghz
Display:    10.16cm, 4,0-inch SuperLCD multitouch-sensitive screen with 480x800 WVGA resolution
Speakerphone:    Three built-in microphones
(Telephone, camera and noise-reduction)
Sensors:    Proximity sensor
Ambient light sensor
Accelerometer sensor
Compass
GPS:    AGPS
Buttons:    Four capacitive buttons under the screen
Power button
Two volume buttons on the left side
Camera button on the right side
Bluetooth:    2.1
Expansion Slot:    microSD memory card(SD 2.0 compatible)
Up to 32GB card support.
Body material:    Aluminium with ambientlight
In Box Content:    Main unit
Battery (as selected)
MicroUSB Cable
Charger (Voltage range/frequency: 100-240V AC, 50-60Hz)
RF Brochure
Product Safety & Warranty Statement
Quick Start Guide
Hva tror dere?
