BSoD: DRIVER_POWER_STATE_FAILURE ved dvalemodus
I det siste har jeg fått Blue Screen of Death hver gang jeg setter maskinen min i dvalemodus. Error-meldingen den ene gangen sa:
***STOP: 0x0000009F (0x00000003, 0x857687F0, 0x82F67AE0, 0x8606B838)
En annen gang sa den:
***STOP: 0x0000009F (0x00000003, 0x857687F0, 0x82F60AE0, 0xB6c54240)
Spesifikasjonene mine er:
· OS - Windows 7
· x86 (32-bit)
· Original installed operating system was Windows Vista
· The Windows 7 the OS is a full retail version but Windows Vista came pre-installed (OEM?)
· The computer (hardware) is from around 24th of April, 2008
· I installed Windows 7 in April or around there this year (2010) - I have not re-installed Windows 7 but Vista i'm not sure about.
· The CPU is an Intel Core 2 Duo T8100 @ 2.10GHz. If more info may be required, here is what AIDA32 says:
___________________________________________________
CPU Properties
CPU Type	Unknown, 2100 MHz
CPU Alias	Katmai, A80525
Original Clock	2100 MHz
L1 Code Cache	32 KB
L1 Data Cache	32 KB
L2 Cache	3 MB (Built-In, Half-Speed)
Multi CPU
CPU #0	Intel(R) Core(TM)2 Duo CPU 	T8100 @ 2.10GHz, 2094 MHz
CPU #1	Intel(R) Core(TM)2 Duo CPU 	T8100 @ 2.10GHz, 2094 MHz
CPU Physical Info
Package Type	242 Contact SEC Cartridge
Package Size	12.82 cm x 6.28 cm x 1.64 cm
Transistors	9.5 million
Process Technology	5M, 0.25 um, CMOS
Die Size	128 mm2
Core Voltage	2.00 V / 2.05 V
I/O Voltage	3.3 V
Typical Power	17 - 23 W (depending on clock speed)
Maximum Power	25.3 - 34.5 W (depending on clock speed)
____________________________________________________
· The Video Card is a NVIDIA GeForce 8600M GT
· AIDA32 says:
Motherboard Properties
Motherboard ID	<DMI>
Motherboard Name	Dell Inc. XPS M1530
Motherboard Manufacturer
Company Name	Dell Computer Corporation
Product Information	http://www.dell.com
BIOS Download	http://support.dell.com
· Power Supply - brand & wattage: Sorry i don't know, i have a laptop. The computer is a Dell XPS m1530.
Endret av iRelax
  • 1 måned senere...
