infectedtech: The AAPEN Project
AAPEN er kort for Adaptive Array of Power Efficient Nodes, og er ett prosjekt jeg holder paa med paa Murdoch University, School of Information Technology, som befinner seg I Perth, paa vestkysten av Australia.
I god tradisjon tro tenkte jeg det var passende aa poste build-loggen av prosjektet her :)
Many great components, an awesome primary node make :)
All hardware and electrical design of this project is licensed under the TAPR Open Hardware NCL.
Which mean you may copy freely; but not use for any commercial use without explicit permission to do so, any non-commercial use follows standard Open Source conventions. Free as in speech, not as in beer.
Kommentartraaden finner du her.
MvH,
[infected]
Endret av [Infected]
  • Liker 7
For enclosure, the Antec 4U22ATX has been chosen. This is a cheap yet solid rack mount case, with a reasonable price point, not to mention easily available without having to ship from the other coast.
Unboxing the Antec 4U22ATX, the 4 Rack Unit (RU) rack mountable housing destined for the primary node.
The Antec in all its glory..
The insides of the case.
Antec has not skimped on the fans, Yate Loon make some great fans.
Mainboard
Gigabyte 890FXA-UD7
Unboxing..
As it turns out, the 890FXA-UD7 is longer than standard full size ATX (its "XL-ATX" apparently, whatever that is), what a bummer!
The board has to be exchanged for a more 'standard' ATX friendly one..
MvH
[infected]
  • Liker 3
Denne gangen er det lagring og komponenter til primaernoden som staar for tur.
The drive cage.
Samsung TruDirect DVD writer.
Quad 2.5" SATA drive backplane.
2x PQI 64GB SandForce powered SSD's, one 32GB A-RAM SSD, and one Seagate 320GB XT hybrid drive..
The PQI's and A-RAM are all MLC's, not to mention the PQI's come with 64MB dram cache. The XT has a 4GB SLC read cache, and a nifty 32MB dram cache. This should make for some interesting comparisons ;)
The A-RAM getting comfy with the drive bay.
The MLC SSD trifecta.
Each drives sits happily in its respective cage :)
The 2nd drive cage will soon be filled with 7.2K rpm 500GB drives to be used for general purpose storage.
The 1040SAS Quartet Mobile Backplane, and its assorted cables..
Backplanes and DVD writer mounted.. FDD is missing for now.. damn, where did that black floppy drive go?
A rather flashy photograph of how the drive bay looks..
A nice pic of the rear end of the cage, too bad my camera handles flash so poorly.
The ever so classic modular bay promotional picture!
The AMD X6 1055T six-core processor.
16 Gigabytes of DDR3 1333MHz memory, in a 4x4GB configuration.
CUDA Accelerator
The EVGA GTS450 with 1GB of memory selected for this build.
EVGA GTS450, the GF106 should clock in at about 600 gigaflops.
More images to come :)
MvH
[infected]
  • Liker 4
The New Mainboard
Thanks to the great service at http://www.msy.com.au/ replacing the UD7 with the more ATX friendly UD5 was no problem :)
Nothing much included, but a few SATA and IDE/floppy cables.
The 890FXA-UD5 in all its glory
The Powerplant
As power plant, the HX650 from Corsair has been selected.
The contents of the box. This power supply is 95% modular, leaving only the 24pin ATX and the ATX12V connector.
The ratings of the Corsair CMPSU-650HX
The CPU Heatsink
The heat sink comes with some random thermal goop.
Bobba Fett Original Space Gold gets rid of that with ease :)
The CPU
The AMD Phenom II 1055T six-core processor in all its glory.
Some quality thermal goop to choose from.. Arctic Silver 5 seem best suited for this job.
An extremely flashy image of the 1055T mounted.
The AS5 has been applied.
CPU all sorted.
Memory Bonanza
16 gigabytes of DDR3 1333MHz..
The memory specs.
All banks filled, and the board is maxed out.
The EVGA GTS450 in all its glory.
Mounted.
MvH
[infected]
  • Liker 4
  • 2 uker senere...
Tid for en aldri saa liten oppdatering.. saa mye aa gjore disse dager, lite tid til noen ting :(
A poorly lit rats nest!
Most of the small wiring cleaned up
Time for some poorly lit SATA cables!
And even more cables..
General Purpose Storage
The Western Digital 500GB 7.2k RPM drive with 16MB dram cache.
These four will be configured for RAID10 for both redundancy and performance :)
The Black Edition in all its glory
Ready for mounting..
All mounted :)
The top backplane is powered from the board's SATA controller
Storage Controller
The Adaptec 1430SA PCIe 4 port SATA controller has finally arrived :)
And mounted.
The last few drives
Finalizing the storage for Polly.
Another Seagate Momentus XT 320GB hybrid drive.
Two A-RAM 32GB Indilinx Barefoot powered SSD's
SATA cables..
Mounting the Barefoot's in the 2.5" to 3.5" bracket.
Mounting the SSD's in the floppy bay.
The drive cable salad..
The LED lightshow of the Adaptec controller.
Polly storage system:
  • 2x Seagate Momentus XT 320GB hybrid drives (RAID1)
    2x PQI 64GB SandForce SSD's (RAID0)
    2x A-RAM 32GB Barefoot SSD's (RAID0)
    4x Western Digital 500GB 7.2K Black Edition (RAID10)
The drive bays in operation.
The very feature-full (not to mention ultra-reliable) Gigabyte BIOS in all its glory :)
Det var alt for denne gang, naa er det paa tide aa leke litt med RAID ;)
MvH
[infected]
  • Liker 3
Og for de der ute som liker tall :new_woot:
Seagate Momentus XT 320GB (JMicron Technology Corp. JMB362/JMB363):
single: Timing buffered disk reads: 284 MB in 3.01 seconds = 94.47 MB/sec
raid 1: Timing buffered disk reads: 204 MB in 3.01 seconds = 67.88 MB/sec
PQI S528 64GB (JMicron Technology Corp. JMB362/JMB363):
single: Timing buffered disk reads: 734 MB in 3.00 seconds = 244.47 MB/sec
raid 0: Timing buffered disk reads: 1100 MB in 3.00 seconds = 366.30 MB/sec
WD Black 500GB (Adaptec Serial ATA II RAID 1430SA):
single: Timing buffered disk reads: 276 MB in 3.01 seconds = 91.74 MB/sec
raid 10: Timing buffered disk reads: 464 MB in 3.01 seconds = 154.17 MB/sec
A-RAM Pro 32GB (JMicron Technology Corp. JMB362/JMB363):
single: Timing buffered disk reads: 552 MB in 3.01 seconds = 183.57 MB/sec
raid 0: Timing buffered disk reads: 548 MB in 3.00 seconds = 182.42 MB/sec
(mdraid 2.6.9-x86_64, Slackware 13.1)
The A-RAM's raid 0 performance makes me lol :)
MvH
[infected]
  • 2 uker senere...
Primaernoden er stort sett klargjort, paa tide aa sette sammen Node Array'et :)
Hardware
First the obligatory hardware shot!
  • * 8x J&W Minix 785G AM3 Micro-ITX
    * 32GB DDR2 800MHz memory (4GB per. node)
    * 2x Corsair TX650 Power Supply Units
    * D-Link 24 port Gigabit switch
    * Various models of AMD processing units
Preparations
All nodes have been prepped and ready.
Giving the nodes a full round of memtest.
Constructing the Stacks
The nodes will be configured in two arrays of four nodes.
The mounting system is constructed from stainless steel rods cut to appropriate length, coupled with pvc reticulation tubing from Bunnings Warehouse ;)
Node number one.
Crossbars improve the structural integrity.
The node stack.
The first stack contain: 2x AMD 600e quad-cores and 2x AMD dual-core processing units.
Glorious 16 Gigabytes of memory :D
Constructing the secondary stack.
Secondary Node Array completed :)
All hardware and electrical design of this project is licensed under the TAPR Open Hardware NCL. (Which mean you may copy freely; but not use for any commercial use without explicit permission to do so, any non-commercial use follows standard Open Source conventions. Free as in speech, not as in beer.)
Det var alt for denne gang, flere bilder snart :)
MvH
[infected]
  • Liker 5
  • 3 uker senere...
Preparing the Enclosure
Stripping the Antec 4U22ATX case..
What is the first thing to do when you receive your brand new rack mount case?
Thats right, you drill it to shits!
Sometimes the drill just wont 'cut it', time to bring out the heavier guns.
Brand new rack mount case? Not anymore!
The AAPEN Electrical System
Constructing the ATX power plugs by hand.
Just a few of all high-current connection blocks required by the project..
Eventually the ATX plugs are coming together.
Over 250 meters of assorted high-current power cable..
Modifying the Power Supply
Two Corsair TX650 power supply units.
Unboxing.
The TX650 unboxed.
Warranty void if removed.
If you love high end hardware, you should probably look away now.
Peek inside the Corsair (CWT) TX650 power supply unit.
Sleeved cables are just so "2009" :)
The PSU all prepped.
The Node Arrays..
The infectedtech AAPEN nodes.
Link til Kommentartraaden :)
MvH
[infected]
  • Liker 3
  • 2 uker senere...
Tid for en aldri saa liten update igjen, det som staar for tur naa er det sentrale strom fordelings-systemet i AAPEN, forovrig kan det nevnes at AAPEN er open-source, all programvare er lisensiert under GPL Version 3, hardware, design og hw-spesifikasjoner er lisensiert under TAPR NCL (ala. GPL for HW) og kan kopieres og benyttes fritt til alt ikke kommersielt bruk.
A package from one of my very favourite electronics vendors, Altronics.
Lots and lots of relays. These relays are designed specifically for use in high-current high-temperature industrial installations.
And yet another batch of relays.. earlier tested types and models etc.
Constructing the AAPEN relay clusters.
Wiring up the relay clusters.
The solder used on the relays is certainly not RoHS compliant ;) Still, solder with a high lead content makes better joints with the copper conductor, and this is very important considering the very high currents in the system. Just got to make sure to wash hands afterwards ;)
The wires used are 32x 0.2mm (17awg) and rated for use in high-current applications.
Heat shrink, this stuff requires a very high tempearture to shrink, using the butane iron's furnace is great for this.
And more wires. In total about 64 meters of high-current wiring, alongside 10-15 meters of low current wire is required for each cluster.
The completed relay cluster.
Taking the AAPEN Relay Clusters for a test run. Looks good :)
Bench testing to ensure the currents and voltages experienced in the system is within the ATX 2.2 specifications.
(Actually, all AAPEN components and wiring is rated at very minimum twice that of the ATX2.2 specs... :))
The voltages look really good as well :)
Det var alt for naa, vil ogsaa minne om kommentartraaden.
MvH
[infected]
  • 3 uker senere...
Blir bare en liten update denne gangen, paa foresporsler blir denne og neste
update av det mer tekniske slaget, der jeg vil forklare litt mer bagrunnen i hvordan
AAPEN virker og hva jeg har tenkt ved utviklingen av plattformen.
Denne updaten er dedikert til programvaren som kjores paa AAPEN, programvaren er skrevet
i C og Perl, der C er benyttet til de underliggende funksjonslaget, mens Perl er brukt til
selve interfacet i AAPEN. AAPEN vil bli sluppet i en Linux distro (kalt AAPEN Linux) basert
paa Slackware Linux, selv om programvaren i seg selv kan kjores paa de aller fleste POSIX
plattformer (*nix) med stotte for de nodvendige Perl modulene, samnt stotte for ANSI C bibliotekene.
MvH
[infected]
  • Liker 3
  • 6 måneder senere...
  • 3 uker senere...
Lang tid med lite updates her, men naa som semesteret endelig har startet opp igjen etter ferien
er det kanskje paa tide med en aldri saa liten update fra denne kanten ogsaa :)
The stacks..
Preparing the enclosure
Test fit
Top view
Front view
Lots of wires
Attaching the quick connectors
Cheers!
  • 2 uker senere...
Tid for enda en aldri saa liten oppdatering..
The 4RU enclosure, prepped and ready.
Mounting the Relay control board, the board used is from Denkovi Electronics.
Wiring up.
The high current industrial realy cluster. there will be a considerable amount of Amperes passing thru here..
High current wiring. everything is rated for the load, and then some.
Sampling the layout.
So many wires.. where will they all go? I forget.
Top view of the relay cluster.
Wiring up the control board.
Selfless self promotion. :cool:
All work and no beer, well is no way to work at all is it. Cheers!
Kommentartraaden
  • 2 uker senere...
  • 2 uker senere...
En aldri saa liten oppdatering, denne gangen er det balanserings-systemet som staar for tur, dette sorger for aa holde spenningene i systemet stabile, selv under en variabel last.
The AAPEN Power Balancing system, also known as the AAPB. Special thanks to Khaled Daabaj, phd computer engineering, for helping me with the math on this one.
The capacitors..
Wiring up
Heatshrinking
The completed product.
Mounted
MvH
[infected]
  • 1 måned senere...
En aldri saa liten update, denne gangen med fokus paa testing :)
Inspection Guidelines..
Datablad er alltid morsomt
Ser fint ut
Fint, fint
Varmt
Fint
IB kontrolleren markerer som den varmeste delen av noden
Stromfordelingssystemet varmeste delen av arrayet
Point of reference
og helt til slutt, en liten video tatt under testen :)
http://www.youtube.com/watch?v=27rT1P35sTw
Mvh
[infected]
  • 1 måned senere...
  • 3 uker senere...
En liten update denne gangen, for det meste random bilder tatt under forbedredelse for ny kabling samt installasjon av IB etc. :)
Campbeltown Loch, only good for killing braincells and degreasing CPU's.
Diverse maalinger for kanalene kan tas opp for enda mer testing :!:
Stromsystemet og strombalanseringssystemet
Bilde foran av nodene for modifiseringer av stack'ene
En Node Stack (stack #2) slik de ser ut for modifiseringer.. (1.0a)
Nevermind har ogsaa faatt en aldri saa liten oppgradering. Fra NAS til NAS + SAN :w00t:
Adaptec SAS 31605 saa naa blir visst filserveren med i AAPEN ogsaa :yes:
Oppgradering til infiniband! tonnevis med bilder kommer :w00t:
Er slutten av enda ett semester naa (AAPEN has reached ALPHA!), etter siste innspurt med dokumenter og last-minute edits seff, saa naa god ferie med tid til aa jobbe litt mer med koden, samt kanskje poste noen flere updates ogsaa :!:
Og helt til slutt, tro det eller ei, AAPEN har naadd ALPHA!! :eek:
Har ogsaa noen heller spennende ting linet upp paa hardware fronten for semesteret som kommer, saa om du ikke har noe bedre ting aa ta deg til, folg med videre! :)
Forslag eller tips? Kommentartraaden
Mvh
[infected]
  • 2 uker senere...
Oppgradere nodene til infiniband, part 1;
Forste som trengs er ett par PCIe ribbon kabler
En liten haug med IB HCA'er
Preparere HCA'ene
Prepare nodene
Litt prototyping :hmm:
Litt forstyrrelser :)
Og demontering..
Stay tuned!
Mvh
[infected]
  • 2 uker senere...
Oppgradere nodene til infiniband, part 2;
Begynne aa ta ting fra hverandre
IB kontrollerene klar til montering
Tilpasse IB kablene, dette kommer til aa bli trangt
Annen vinkel
Testing, testing og mere testing. En skikkelig testplan, er coupe de grace, ivertfall i folge min supervisor :)
Forste node i stack'en preparert, klargjore neste
Ett detaljskudd :)
Ikke helt enkelt aa faa bilde av IB kontrolleren gjemt bort der
Bilde fra toppen, detaljarbeid dette
Bilde fra front
Test, test og mere test
Saa de obligatoriske timene med bench og burn testing, alt maa selvfolgelig logges :w00t:
Mvh
[infected]
