TFC Admiral - Nye Feser radiatorer!
Dette ser meget bra ut!
Information:
Let us introduce our new radiator line. As most people have
seem radiators for liquid cooling have not changed in forever.
Every manufacturer follows a similar template. Well not anymore, here at TFC we are breaking the mold! New technology is being implemented and allowing more options and features. All the ADMIRAL series radiators are based off this new technology. Due to this unification of technology across the entire radiator line you can recognize an ADMIRAL radiator at first glance. A lighter design
allows larger sizes to be created and lets you push the
envelope even further! No more industry standard design
here, just pure performance and quality. These are the
things we built TFC on and what we push into every new
product line. The ADMIRAL serues is no exception.
Key features:
EXTREME PERFORMANCE
Our newly developed technology
brings you increased cooling
power to your system.
Better materials, the newest
technology and a cool design promise
and outstanding product
FRAME SOLUTIONS
The newly designed frame is based on
aluminium. It reduces the overall weight
and can be anodized in different colors.
Side parts are detachable and provide
more customization abilities e.g. for
vertical mount and optional docking
feet.
AIR FLOW OPTIMIZED
By using rounded waterchannel tubes,
the passing air surrounds them
completely and picks up the heat more
effectively off the fins.
The round tubes and fins reduce
the noise of the airstream
TURBO WHIRL ENHANCEMENT
Waterchannel tubes are twisted and
corrugated which improves the flow
speed and increases the turbulences
of the water inside the tubes. This
technology enhances the cooling
performance dramatically.
ROHS COMPLIANT
All substances have been checked and
are compliant with ROHS guidelines.
Radiator components are connected
and laser welded without the use of
hazardous materials.
We save the environment.
NOISELESS SILENT OPERATION
By using larger fin spacing and large
spacings between the watercooling
pipes the air flow rate is increased and
gives you the option to use fans at a
lower speed. The lower the speed, the
lower the noise level.
HIGH FLOW OPTIMIZED
The radiators are especially designed
to run with High Flow system
configurations. We recommend High
Flow Systems to maximize your heat
dissipation
MAXIMUM SYSTEM COMPATIBILITY
The radiator inlet and outlet ports are
G1/4" threaded, helping to give you
multiple fitting options.
The ADMIRAL can replace any previous
radiator you were using in your system
loop.
PERFECT HEAT TRANSMISSION
The fins and tubes are made out of two
coldpressed pipes. There is no
soldering which could the hinder the heat
transfer. The thermal conductivity
between the inner core tube and outer
fins tube is better.
EASY INSTALLATION
Enough screws are provided to install
the radiator properly. You can place
the radiator wherever you want. The
position (vertical / horizontal) will not
effect the cooling performance.
ENERGY EFFICIENT
Due to the ability of using low speed
fans, and less water resistance for the
pump, the operating system saves
energy consumption.
PATENDED DESIGN
This new designed radiator gives the
opportunity to use inlet and outlet port
from different sides and opens up
new ideas for installation. It is possible
to use two different types of fans with
the 140/120 radiator series.
SECURITY SYSTEMS
Every radiator has been tested for
leaks and proper heat dissipation
before it gets the quality approval and
leaves our warehouse. Every radiator
has it's own serial number and
proves that you bought an original
TFC ADMIRAL RADIATOR.
MADE IN GERMANY
Every piece on the radiator is
manufactured in Germany. If you take a
closer look you will find the perfection in
every small and single detail. Before the radiator leaves our facilities it has been
checked by five different employees to
guarantee one of the finest and most
reliable watercooling radiators.
Endret av Diabolicelf
Admiral kommer med 4 serier, hver med flerne størrelser:
MONSTA 140
140 - 280 - 420 - 560 - 700 (!)
23 tubes
STANDARD 140
140 - 280 - 420 - 560 - 700 (her også!)
17 tubes
STANDARD 120
120 - 240 - 360 - 480
14 tubes
SLIM 120
7 tubes
Litt mer om TFC Admiral Monsta 140 700
Opp til 10 140/120 vifter
23 tubes
16,55m / 54,30 feet cooling path
600 ml væske
754 x 144 x 101 mm
www.tfc-admiral.com
hw-lab.com
Ser ut til at de kommer til USA i oktober og til Europa i november
Bilder:
Designet på disse radiatorene må jeg si er meget meget fint :love:
De ser voldsomt lekre ut! :thumbup:
Skal også bli spennende å se ytelsen på disse,
hvis de yter så godt som de påstår kan jo dette bli veldig bra!
men de er jo nesten verdt å kjøpe bare pga utseendet :love:
godt mulig at jeg ender opp med en 480 eller 560 monsta :cool:
er vannkanalene i radiatoren sirkulære ? skeptisk jeg og... mest trolig er det billigere produksjons teknikk og ikke bedre kjøleevne, radiatorens kontaktflate mot luft må da totalt sett bety mindre areal. På en annen side vil det bli mere turbulens som fører til mere termisk konduktivitet på kjøleoverflaten men betyr merestøy...
  • 4 uker senere...
