DC Universe Online
Dette var litt synd egentlig. På WoW f.eks tar de vedlikehold og små patcher som dette på et fast tidspunkt på onsdager, lite gøy for de av oss som vil sitte hjemme og kose oss på en fredagskveld.
Husk nå at det er stor forskjell mellom disse spillene, wow har vært ute i 6år+, DCUO har nettopp blitt sluppet. Tro meg var mye tull etter release dagen til wow også.
Oppdaterte patch notes:
General:
Improved Client performance and stability.
Addressed an issue where other characters may appear to "warp" onscreen.
The time it takes to get to Character Selection on launch has been reduced.
Audio:
Audio should no longer drop after cutscenes if you have your Music volume set to 0.
Chat:
The player’s Voice Chat Channel should now be selected according to the following priority, from highest to lowest:
Alert
Group
Custom
League
Player Appearance:
Equipping a new weapon should no longer cause your weapon appearance to disappear.
Swapping weapons with your weapon style locked should no longer cause the weapon appearance to change.
Movement:
Player character animations should no longer have the chance of getting stuck when weaponizing objects.
Missions:
Adjusted difficulty of content in the Venom Lab to level 7 to better match the surrounding content.
No Joke quest is now available at level 18 instead of 19.
A Crook’s Best Friend mission is now available at level 18 instead of 19.
Something’s Fishy… quest is now available at level 22 instead of 23.
Road to Hell quest is now available at level 22 instead of 23.
Fateful Omen quest is now available at level 26 instead of 27.
Hardcorps quest is now available at level 26 instead of 27.
UI:
Pressing the "Accept" button on the Server Selection screen multiple times should no longer result in odd ssues with Character Creation movies and UI.
Den fortjente en egen post:
Det er forresten Power Girl som gjelder :p
:p
Må bruke tiden til noe, har nettopp pløyet gjennom 53 sider med character screenshots i mangel av server :p
mange...intressante designs.
Hehe, jeg holder på med akkurat det samme. Mye bra. VANVITTIG mye dårlig :p
Spawn clone #21309 anyone?
Endret av Aurvan
