Ubuntu og IFL90 hovedkort temp problemer
Jeg prøvde å installere temp og fan speed monitor programer til min pc men får ikke opp alt.
Den fant Core temp og HDD temp men ikke resten.
Min pc er en Multicom Compal IFL90+ 15.4" GeForce® 8600M GT 512MB.
Jeg mangler:
  • CPU Fan
  • Case Fan
  • Sys temp
  • CPU temp
Her er svaret jeg fekk etter jeg brukte sensors-detect, håper noen her kan hjelpe meg å få opp resten av infoen.
# sensors-detect revision 5818 (2010-01-18 17:22:07 +0100)
# System: - N/A (laptop)
# Board: - IFL90
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): y
Silicon Integrated Systems SIS5595... No
VIA VT82C686 Integrated Sensors... No
VIA VT8231 Integrated Sensors... No
AMD K8 thermal sensors... No
AMD Family 10h thermal sensors... No
AMD Family 11h thermal sensors... No
Intel Core family thermal sensor... Success!
(driver `coretemp')
Intel Atom thermal sensor... No
Intel AMB FB-DIMM thermal sensor... No
VIA C7 thermal sensor... No
VIA Nano thermal sensor... No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): y
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor'... No
Trying family `SMSC'... No
Trying family `VIA/Winbond/Nuvoton/Fintek'... No
Trying family `ITE'... No
Probing for Super-I/O at 0x4e/0x4f
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no): y
Probing for `National Semiconductor LM78' at 0x290... No
Probing for `National Semiconductor LM79' at 0x290... No
Probing for `Winbond W83781D' at 0x290... No
Probing for `Winbond W83782D' at 0x290... No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no): y
Using driver `i2c-i801' for device 0000:00:1f.3: Intel 82801H ICH8
Module i2c-i801 loaded successfully.
Module i2c-dev loaded successfully.
Next adapter: nouveau-0000:01:00.0-2 (i2c-0)
Do you want to scan it? (YES/no/selectively): y
Client found at address 0x50
Probing for `Analog Devices ADM1033'... No
Probing for `Analog Devices ADM1034'... No
Probing for `SPD EEPROM'... No
Probing for `EDID EEPROM'... Yes
(confidence 8, not a hardware monitoring chip)
Next adapter: nouveau-0000:01:00.0-0 (i2c-1)
Next adapter: SMBus I801 adapter at 1c00 (i2c-2)
Probing for `SPD EEPROM'... Yes
Probing for `EDID EEPROM'... No
Client found at address 0x52
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `coretemp':
* Chip `Intel Core family thermal sensor' (confidence: 9)
To load everything that is needed, add this to /etc/modules:
#----cut here----
# Chip drivers
coretemp
#----cut here----
If you have some drivers built into your kernel, the list above will
contain too many modules. Skip the appropriate ones!
Do you want to add these lines automatically to /etc/modules? (yes/NO)y
Successful!
Monitoring programs won't work until the needed modules are
loaded. You may want to run '/etc/init.d/module-init-tools start'
to load them.
Unloading i2c-dev... OK
Unloading i2c-i801... OK
Endret av Kimlorentz
