Joomla problem!
Warning: strtotime() [function.strtotime]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Paris' for '2.0/DST' instead in C:\xampp\htdocs\joo\libraries\joomla\utilities\date.php on line 56
Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Paris' for '2.0/DST' instead in C:\xampp\htdocs\joo\libraries\joomla\utilities\date.php on line 198
Anyone? det pisser meg :(
