Nytt lydkort, hvilke passer?
Hei, eg har en pc bestående av desse delene:
ntall Varenr. Beskrivelse
1.00 518692 AMD Phenom II X4 965 Black Edition
Quad Core, 3,4Ghz, AM3, 8MB, 125W, Boxed
1.00 461645 Cooler Master HAF 922 Midi Tower Sort
Vifter: 1x 200mm Front, 1x 200mm Topp, 1x 120mm Ba
1.00 513307 Gigabyte GA-790FXTA-UD5, Socket-AM3
AMD 790FX+SB750, ATX, DDR3 , SATA 6Gb, USB3.0, 2xG
1.00 518211 Crucial DDR3 BallistiX 1600MHz 4GB CL8
Kit w/2x 2GB BallistiX modules, CL8-8-8-24, 1.65V
1.00 518434 Linksys WMP600N-EU Dual-Band PCI
300Mbps draft-802.11n, 2.4GHZ - 5GHZ
1.00 386812 Chieftec Super Series 750W PSU
ATX 12V V2.3, 80 Plus, Modular, 2x 6pin+2x 6+2pin
1.00 498840 PowerColor Radeon HD 5870 1GB GDDR5
PCI-Express 2.0, 2xDVI-I, HDMI, DisplayPort
1.00 494649 Cooler Master Hyper 212 Plus CPU Cooler
Support Socket Intel 755/1156/1366, AMD 939/940/AM
1.00 494479 Lite-On DVD+RW burner IHAS124-19
SuperAllWrite, 24x8x16DVD+RW, SATA, Black
1.00 391645 Western Digital Caviar® Black? 500GB
, Sata 3 Gb/s, 32MB Cache, 7200RPM
Tenker eg skal kjøpe meg et lydkort, hvilke passer til dette oppsettet? Vil helst ha et som fungerer bra til gaming og som koster under 1000kr.
Noen forslag?
Takker på forhånd
mvh olaf1
