andsti Skrevet 28. september 2010 Del Skrevet 28. september 2010 Vet ikke hva det korekte ordet for dette er, men ser det brukes stue-pc og mini-pc mange steder.. det jeg hvertfall lurer på, har ikke tenkt å bruke mange penger.. men greit å få en grei sak, for en 3000 omtrent.. det som er viktig er at den kan spille av 1080i, har sett litt på forskjellige; http://www.komplett.no/k/ki.aspx?sku=456067 http://www.komplett.no/k/ki.aspx?sku=598169 http://www.komplett.no/k/ki.aspx?sku=513207 Alt dette står jo om den MSI Wind Box...: HDMI Capability The Wind Box offers the high resolution and multi-media HDMI function, so you can choose to enjoy the widescreen experience at anytime. The accuracy of colors and images will leave any viewer totally speechless. Full HD Entertainment Function The Wind Box understands High Definition regardless its size. The 1080P Full HD display function can show you what “realism” really is by putting you right inside the classiest theater. 7.1Channel Audio Output The latest 7.1 Channel Audio Output offers a multi-channel and surrounding experience while playing a media player or gaming. It doesn’t matter if you are listening to the latest hit music or watching a DVD, the DE200 will offer the most precise sound.(SPDIF adaptor needed for PS) Gigabit LAN High Speed Transfer The Gigabit LAN provides a stable and high speed transfer of files for the Wind Box, while insuring a smooth transaction of images, music, or sounds over the internet without delay. Wireless Internet Connection Wireless Connection with the IEEE802.11b standards can achieve up to 11Mbps, automatically searches for the best internet connection in the region. The highest transfer speed can be up to 54Mbps~108Mbps(802.11n). Lenke til kommentar
DEagleson Skrevet 28. september 2010 Del Skrevet 28. september 2010 Eier ASRock Ion 330 selv (Ikke den bedre Pro utgaven du linket til med medfølgende fjernkontroll.) og er veldig fornøyd. Oppgraderte den til 4gb RAM der 512mb dedikert til Ion GPUen eller Nvidia Geforce 9400m som den egentlig heter. Den kjører Windows 7 Home Premium og nyeste versjon av XBMC og filmarkivet mitt ligger på en 4TB Western Digital Sharespace. Men det følger ikke med operativsystem så hvis du ikke vil installere OS selv er nok MSI sitt alternativ best. Er ikke helt kjent med ATI sin støtte i XBMC men tror nok det vil fungere helt fint. Acer boksen er nok litt slapp med sin slappe Atom N270 som bare har en kjerne mens de to andre har to kjerner. Lenke til kommentar
andsti Skrevet 28. september 2010 Forfatter Del Skrevet 28. september 2010 Tusen takk for svar! Må nok ha med OS, så skal titte litt nærmere på MSI Lenke til kommentar
DEagleson Skrevet 28. september 2010 Del Skrevet 28. september 2010 Anbefaler iallefall enten XBMC eller Boxee som media center program. Gratis og spiller av alle tenkelige format (HD ved hjelp av DXVA dekoding fra GPU) så her er ikke Intel Atom noe problem. Lenke til kommentar
andsti Skrevet 28. september 2010 Forfatter Del Skrevet 28. september 2010 OKey, takk skal du ha! Lenke til kommentar
