ConeX Skrevet 25. september 2010 Del Skrevet 25. september 2010 (endret) La oss gå rett på sak.. A problem has been detected and Windows has been shut down to prevent damageto your computer. The problem seems to be caused by the following file: tcpApreB.sy PAGE_FAULT_IN_NONPAGED_AREA If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any Windows updates you might need. If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode. Technical Information: *** STOP: 0x00000050 (0xfffff8e0020159bc, 0x0000000000000001, 0xfffff80002dac2c2, 0x00000000001e0005) *** tcpApreB.sy - Address 0xfffff88008212640 base at 0xfffff88008003000 DateStamp 0x4a00cccd Når jeg googler tcpApreB.sy, finner jeg absolutt ingenting!? PAGE_FAULT_IN_NONPAGED_AREA finner jeg en god del om, men ingenting jeg har prøvd til nå har fikset det. A problem has been detected and Windows has been shut down to prevent damageto your computer. The problem seems to be caused by the following file: discache.sys PAGE_FAULT_IN_NONPAGED_AREA If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any Windows updates you might need. If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode. Technical Information: *** STOP: 0x00000050 (0xfffff8000200313a, 0x0000000000000008, 0xfffff8000200313a, 0x0000000000000000) *** discache.sys - Address 0xfffff8800422a9d0 base at 0xfffff88003f29000 DateStamp 0x4a5bc52e Denne fikk jeg tidligere, har lest at man burde sjekke systemet for ymse skadelige programmer. Det har jeg gjort ved å bruke Spybot S&D, noen andre anbefalinger? Jeg har: Installert alle drivere på nytt. (fra produsent) Kontrollert harddiskene. (Maxtor, Maxtor Power Max Diagnostic) Memtest. Feilen oppstår helt random, det kan være når jeg sitter å leser på nettet, spiller eller når den ikke gjør noe i det hele tatt. Jeg vil prøve å unngå å måtte formatere, ettersom jeg har akkurat konfigurert div. programmer i forhold til skole etc. Jeg vil også nevne at i går (da jeg tror det var fikset) kjørte jeg en rekke benchmarks for å presse systemet litt, uten en eneste krasj. Endret 25. september 2010 av ConeX Lenke til kommentar
ei57 Skrevet 25. september 2010 Del Skrevet 25. september 2010 Du kan jo prøve og kjøre en registry cleaner (f.eks. CCleaner) og se om problemet blir borte. Hjelper ikke det kan du Google stopp-koden 0x00000050 og ta med OS i søket. Det er noen sider der ute som kan være til hjelp. Jeg ville dog vært forsiktig med å klikke på linker som skal løse problemet. Om ikke feilen ligger i registry, kan du ha en minnefeil. Lenke til kommentar
ConeX Skrevet 26. september 2010 Forfatter Del Skrevet 26. september 2010 (endret) Takk for tilbakemelding. Har kjørt CCleaner og den fjernet litt groms, STOP kode 0x00000050 har jeg ikke sett noe mer til. Men nå etter å ha kun installert en hot fix til ati driveren får jeg en DRIVER_CORRUPTED_EXPOOL "STOP: 0x000000c5. (raspppoe.sys) A problem has been detected and Windows has been shut down to prevent damageto your computer. The problem seems to be caused by the following file: raspppoe.sys DRIVER_CORRUPTED_EXPOOL If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any Windows updates you might need. If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode. Technical Information: *** STOP: 0x000000c5 (0x00000000001e65f3, 0x0000000000000002, 0x0000000000000000, 0xfffff80002dff0bf) *** raspppoe.sys - Address 0xfffffa8006bdfba0 base at 0xfffff88003e55000 DateStamp 0x4a5bcce9 For meg så ser du ut som om det er minnebrikkene (evt. hovedkortet). Men er det mulig å sjekke minnebrikkene med memtest86 når jeg har 8 gb ram uten å måtte ta ut 4 av dem? Vil helst unngå det slik at jeg kan ta det mens jeg skal ut på tur. Har brukt HCI MemTest 4.0 men det kjøres i Windows, er ikke det en ulempe når man skal teste RAM? Endret 26. september 2010 av ConeX Lenke til kommentar
ConeX Skrevet 27. september 2010 Forfatter Del Skrevet 27. september 2010 Ny i dag! A problem has been detected and Windows has been shut down to prevent damageto your computer. The problem seems to be caused by the following file: ntoskrnl.exe DRIVER_CORRUPTED_EXPOOL If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any Windows updates you might need. If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode. Technical Information: *** STOP: 0x000000c5 (0x00000000001ea123, 0x0000000000000002, 0x0000000000000001, 0xfffff80002da790d) Noen forslag til test programmer av RAM som kan teste mer enn 4 gb? Lenke til kommentar
ConeX Skrevet 27. september 2010 Forfatter Del Skrevet 27. september 2010 (endret) Nå har jeg kjørt memtest på 4gb av gangen uten en eneste feil. Forslag? Endret 27. september 2010 av ConeX Lenke til kommentar
ei57 Skrevet 27. september 2010 Del Skrevet 27. september 2010 (endret) Du har fått vekk STOP kode 0x00000050 og har etter det installert en hotfix for ATI-driveren. Etter det har du fått en ny STOP kode 0x000000c5 og DRIVER_CORRUPTED_EXPOOL i tillegg. Jeg har null peil på ATI-kort, men jeg ville sjekket driverne til skjermkortet. Jeg har sett at en del har hatt problem med noen av dem og har gått tilbake til tidligere versjoner. Endret 27. september 2010 av ei57 Lenke til kommentar
ConeX Skrevet 28. september 2010 Forfatter Del Skrevet 28. september 2010 Etter å ha kjørt de 2 parene jeg har med RAM brikker individuelt uten som noen som helst feil, tenkte jeg at det ville være lurt å teste alle 4 samtidig. Da jeg satt på testen var jeg allerede på vei ut døra for å spise middag, da jeg kom tilbake 30 minutter senere var det over 400 000 errors. ("PASS" hadde ikke gått mer enn 16%!) Jeg tenkte med en gang at det ikke kunne stemme, så jeg valte å starte hele testen på nytt. (reboot) Da testen starter rakk den så vidt å bli ferdig med 4 tester før hele skjermen var blod rød av feilmeldinger. (Den ville aldri stoppe å vise feilmeldinger) Så jeg valgte å starte om nok en gang, å siden har den gått helt fint.. stått i 6,5 time uten en eneste feil. (3 Passes) [ECC: OFF | Cache: ON | Test: Std] Hva gjør jeg nå? Lenke til kommentar
ConeX Skrevet 29. september 2010 Forfatter Del Skrevet 29. september 2010 Kan det være at jeg må stille opp spenningen på minnet? Lenke til kommentar
Malvado Skrevet 29. september 2010 Del Skrevet 29. september 2010 Ja. Når man får litt vilkårlige feil på minnet og det ikke kan spores til en enkel minnebrikke (dvs når man ikke kjører med alle brikkene samtidlig) så er det ofte tegn på at hovedkortet har problemer med minnemengden, som regel har det løst seg ved å slakke på timingsene. Øker man volten bruker brikkene å fungere mer stabilt, men i tillegg så har jeg erfart at man gjerne kan stille på de store verdiene (dvs 15+) og øke disse et par hakk, Tras og Trc er det jeg personlig bruker å justere opp. Funker det ikke å øke volt og slakke på disse to verdiene prøver du deg litt fram, du kommer desverre til å bruke litt tid til testing av minnet før du kommer fram til noe som fungerer. Om det fortsatt er ustabilt selv med veldig slakke timings og økt volt så er det nok hk som sliter (eller at minnebrikkene ikke er identiske). Lenke til kommentar
sveibuen Skrevet 29. september 2010 Del Skrevet 29. september 2010 Kanskje du må sette timings å volt manuelt:) å kanskje en BIOS oppdatering hjelper? Lenke til kommentar
